Other Parts Discussed in Thread: MSP430G2553
将下面的代码屏蔽后,串口正常输出,
CCR0 = 500-1; // 500ns
CCTL0 = CCIE; // CCR0 interrupt enabled
TACTL = TASSEL_2 + MC_1 + TAIE; // SMCLK, upmode, interrupt
将代码解屏蔽就会输出固定字符如:
9A CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA CA ...
求解?
代码如下:
#include "msp430g2553.h"
void UartSendChar(char ch)
while (!(IFG2&UCA0TXIFG)); // USCI_A0 TX buffer ready?
UCA0TXBUF = ch;
static unsigned int s_SysTicks = 0;
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
BCSCTL1 = CALBC1_1MHZ;
DCOCTL = CALDCO_1MHZ;
P1SEL = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
P1SEL2 = BIT1 + BIT2;
UCA0CTL1 |= UCSSEL_2; // SMCLK
UCA0BR0 = 104; // 1MHz 9600
UCA0BR1 = 0; // 1MHz 9600
UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
__enable_interrupt();
unsigned char i = 0;
unsigned char j = 0;
for ( ; ;)
UartSendChar(0xaa);
UartSendChar(i);
UartSendChar(0xbb);
UartSendChar(j);
i++;
j += 2;
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A0 (void)
s_SysTicks++;
