CCS出毛病了
我以前装过CCS V6没问题,后来搞安卓重新装过JDK等。今天用到ccs,打开后发现不能编译。卸载后一直无法安装,就从别人那拷装好的ccs,发现运行失败,非常郁闷。这是我的运行日志,请大家帮我看一下。安装目录在 c/ti
非常感谢!
!SESSION 2014-12-24 21:03:10.478 -----------------------------------------------
eclipse.buildId=M20120914-1540
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments:  -product com.ti.ccstudio.branding.product
Command-line arguments:  -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
!ENTRY org.eclipse.ui 4 4 2014-12-24 21:03:18.875
!MESSAGE The proxied handler for 'com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler' could not be loaded
!ENTRY org.eclipse.ui 4 0 2014-12-24 21:03:18.887
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler".
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:347)
	at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:316)
	at org.eclipse.core.commands.Command.isEnabled(Command.java:862)
	at org.eclipse.core.commands.Command.setHandler(Command.java:1025)
	at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:459)
	at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:249)
	at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:120)
	at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:112)
	at org.eclipse.ui.internal.handlers.HandlerPersistence.readHandlersFromRegistry(HandlerPersistence.java:313)
	at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:219)
	at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:167)
	at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:186)
	at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:61)
	at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103)
	at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:174)
	at org.eclipse.ui.internal.Workbench$49.runWithException(Workbench.java:1892)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: java.lang.NoClassDefFoundError: com/ti/debug/engine/events/types/IObjectEventListener
	at com.ti.ccstudio.debug.ui.commands.AbstractDebugHandler.<init>(AbstractDebugHandler.java:42)
	at com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler.<init>(ShowPreferencesHandler.java:29)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at java.lang.Class.newInstance0(Unknown Source)
	at java.lang.Class.newInstance(Unknown Source)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
	... 43 more
Caused by: java.lang.ClassNotFoundException: com.ti.debug.engine.events.types.IObjectEventListener
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at java.lang.ClassLoader.loadClass(Unknown Source)
	at java.lang.ClassLoader.loadClassInternal(Unknown Source)
	... 52 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-12-24 21:03:18.889
!MESSAGE Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler".
!STACK 0
	... 52 more
!ENTRY org.eclipse.ui 4 4 2014-12-24 21:03:18.895
!MESSAGE The proxied handler for 'com.ti.ccstudio.debug.ui.commands.FindSymbol' could not be loaded
!ENTRY org.eclipse.ui 4 0 2014-12-24 21:03:18.896
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.ui.commands.FindSymbol".
	at com.ti.ccstudio.debug.ui.commands.FindSymbol.<init>(FindSymbol.java:26)
	... 43 more
	... 52 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-12-24 21:03:18.897
!MESSAGE Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.ui.commands.FindSymbol".
!STACK 0
	... 52 more
!ENTRY org.eclipse.ui 2 0 2014-12-24 21:03:19.658
!MESSAGE Warnings while parsing the viewer contributions from the 'org.eclipse.ui.popupMenus' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2014-12-24 21:03:19.658
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.CBreakpointPropertiesRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.EnableDisableBreakpointRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.ui.actions.RulerCreateBreakpointInteractiveAction'
!SUBENTRY 1 org.eclipse.ui 2 0 2014-12-24 21:03:19.659
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.asm.CBreakpointPropertiesRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.asm.EnableDisableBreakpointRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.ui.actions.asm.RulerCreateBreakpointInteractiveAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.dsf.ui', id='AUTOGEN:::org.eclipse.cdt.dsf.debug.ui.disassemblyRulerActions/org.eclipse.debug.ui.actions.RulerAddBreakpointAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.dsf.ui', id='org.eclipse.cdt.dsf.debug.ui.disassembly.commands.rulerToggleBreakpoint'
!ENTRY org.eclipse.osgi 4 0 2014-12-24 21:03:21.825
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: com/ti/xpcom/XPCOMException
	at com.ti.ccstudio.debug.ui.profileClockStatus.ProfileClockStatusBar.createControl(ProfileClockStatusBar.java:36)
	at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:98)
	at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java:210)
	at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
	at org.eclipse.jface.action.ToolBarManager.createControl(ToolBarManager.java:111)
	at org.eclipse.ui.internal.menus.TrimContributionManager$ToolBarTrimProxy.dock(TrimContributionManager.java:88)
	at org.eclipse.ui.internal.menus.TrimContributionManager.update(TrimContributionManager.java:265)
	at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:3874)
	at org.eclipse.ui.internal.WorkbenchWindow.setLayoutDataForContents(WorkbenchWindow.java:3885)
	at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(WorkbenchWindow.java:1157)
	at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultContents(WorkbenchWindowConfigurer.java:623)
	at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContents(WorkbenchWindowAdvisor.java:300)
	at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindow.java:1043)
	at org.eclipse.jface.window.Window.create(Window.java:431)
	at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java:1216)
	at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
	at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
Caused by: java.lang.ClassNotFoundException: com.ti.xpcom.XPCOMException
	... 46 more
!ENTRY org.eclipse.core.jobs 2 2 2014-12-24 21:03:22.411
!MESSAGE Job found still running after platform shutdown.  Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$10
!ENTRY org.eclipse.core.jobs 2 2 2014-12-24 21:03:22.414
!ENTRY org.eclipse.core.jobs 2 2 2014-12-24 21:03:22.415
!ENTRY org.eclipse.core.jobs 2 2 2014-12-24 21:03:22.417
!ENTRY org.eclipse.core.jobs 2 2 2014-12-24 21:03:22.419
!ENTRY org.eclipse.core.jobs 2 2 2014-12-24 21:03:22.421
!ENTRY org.eclipse.core.jobs 2 2 2014-12-24 21:03:22.423
