用的都是官方的代码
/* --COPYRIGHT--,BSD_EX
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* MSP430 CODE EXAMPLE DISCLAIMER
* MSP430 code examples are self-contained low-level programs that typically
* demonstrate a single peripheral function or device feature in a highly
* concise manner. For this the code may rely on the device's power-on default
* register values and settings such as the clock configuration and care must
* be taken when combining code from several examples to avoid potential side
* effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
* for an API functional library-approach to peripheral configuration.
* --/COPYRIGHT--*/
// MSP-FET430P440 Demo - LCD, Display "6543210" on STK/EVK LCD
// Description: Displays "6543210" on MSP-EVK430S320 LCD.
// ACLK = LFXT1 = 32768Hz, MCLK = SMCLK = default DCO = 32 x ACLK = 1048576Hz
// //* An external watch crystal between XIN & XOUT is required for ACLK *//
// Connections MSP430 -> LCD
// T.I. MSP-EVK430S320
// MSP430F449 6.5 digit 4 mux LCD
// #T218010
// | | COM3 |-----|2 COM4 |
// --|RST COM2 |-----|1 COM3 |
// | COM1 |-----|3 COM2 |
// | COM0 |-----|4,20 COM1 |
// -|XIN SEG0 |-----|19 |
// 32kHz| SEG1 |-----|18 |
// -|XOUT SEG2 |-----|17 |
// | SEG3 |-----|16 |
// | SEG4 |-----|15 |
// | SEG5 |-----|14 |
// | SEG6 |-----|13 |
// | SEG7 |-----|12 |
// +-|R33 SEG8 |-----|11 |
// 1M | SEG9 |-----|10 |
// +-|R23 SEG10|-----|9 |
// 1M | SEG11|-----|8 |
// +-|R13 SEG12|-----|7 |
// 1M | SEG13|-----|6 |
// +-|R03 SEG14|-----|5 (bits C,E,H |
// | | | | of digit 7)|
// Vss --------------- --------------
// M. Buccini / H. Grewal
// Texas Instruments Inc.
// Feb 2005
// Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.21A
#include <msp430.h>
const char digit[10] =
0xB7, /* "0" LCD segments a+b+c+d+e+f */
0x12, /* "1" */
0x8F, /* "2" */
0x1F, /* "3" */
0x3A, /* "4" */
0x3D, /* "5" */
0xBD, /* "6" */
0x13, /* "7" */
0xBF, /* "8" */
0x3F /* "9" */
int main(void)
volatile unsigned int i; // Use volatile to prevent removal
// by compiler optimization
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
FLL_CTL0 |= XCAP14PF; // Configure load caps
for (i = 0; i < 10000; i++); // Delay for 32 kHz crystal to
// stabilize
LCDCTL = LCDON + LCD4MUX + LCDSG0_4; // LCD on, 4-Mux, segments S0-S27
BTCTL = BT_fLCD_DIV128; // LCD clock freq is ACLK/128
P5SEL = 0xFC; // Select P5.2-7 as Com and Rxx
for (;;)
unsigned char x;
for (x=0; x<7; x++)
LCDMEM[x] = digit[x]; // Display "6543210"
