MSP430F2418器件的库头文件里找不到DAC12模块的寄存器定义,如何使用DAC12模块功能,请教各位如何解决?谢谢!
这个是头文件,在IAR 6.10版本里打开的,没有找到DAC模块部分。求帮助!谢谢!
* Standard register and bit definitions for the Texas Instruments
* MSP430 microcontroller.
* This file supports assembler and C development for
* MSP430x241x devices (excluding MSP430x2410).
* Texas Instruments, Version 1.4
* Rev. 1.0, Initial Version
* Rev. 1.1 added TLV in INFO Memory
* Rev. 1.2, added definitions for Interrupt Vectors xxIV
* Rev. 1.3, added missing Port7/8
* Rev. 1.4, fixed define: TAG_ADC12_1 to 0x08
#ifndef __msp430x241x
#define __msp430x241x
#define __MSP430_HEADER_VERSION__ 1149
#ifdef __IAR_SYSTEMS_ICC__
#ifndef _SYSTEM_BUILD
#pragma system_include
#endif
#endif
#if (((__TID__ >> 8) & 0x7F) != 0x2b) /* 0x2b = 43 dec */
#error msp430f2418.h file for use with ICC430/A430 only
#endif
#include "in430.h"
#pragma language=extended
#define DEFC(name, address) __no_init volatile unsigned char name @ address;
#define DEFW(name, address) __no_init volatile unsigned short name @ address;
#if __REGISTER_MODEL__ == __REGISTER_MODEL_REG20__
#define DEFA(name, address) __no_init void __data20 * volatile name @ address;
#else
#define DEFA(name, address) __no_init volatile unsigned short name @ address; /* only short access is allowed from C in small memory model */
#endif
#define DEFXC volatile unsigned char
#define DEFXW volatile unsigned short
#define DEFXA void __data20 * volatile
#else
#define DEFXA volatile unsigned short /* only short access is allowed from C in small memory model */
#endif
#endif /* __IAR_SYSTEMS_ICC__ */
#ifdef __IAR_SYSTEMS_ASM__
#define DEFC(name, address) sfrb name = address;
#define DEFW(name, address) sfrw name = address;
#define DEFA(name, address) sfrl name = address;
#endif /* __IAR_SYSTEMS_ASM__*/
#ifdef __cplusplus
#define READ_ONLY
#else
#define READ_ONLY const
#endif
* STANDARD BITS
#define BIT0 (0x0001u)
#define BIT1 (0x0002u)
#define BIT2 (0x0004u)
#define BIT3 (0x0008u)
#define BIT4 (0x0010u)
#define BIT5 (0x0020u)
#define BIT6 (0x0040u)
#define BIT7 (0x0080u)
#define BIT8 (0x0100u)
#define BIT9 (0x0200u)
#define BITA (0x0400u)
#define BITB (0x0800u)
#define BITC (0x1000u)
#define BITD (0x2000u)
#define BITE (0x4000u)
#define BITF (0x8000u)
* STATUS REGISTER BITS
#define C (0x0001u)
#define Z (0x0002u)
#define N (0x0004u)
#define V (0x0100u)
#define GIE (0x0008u)
#define CPUOFF (0x0010u)
#define OSCOFF (0x0020u)
#define SCG0 (0x0040u)
#define SCG1 (0x0080u)
/* Low Power Modes coded with Bits 4-7 in SR */
#ifndef __IAR_SYSTEMS_ICC__ /* Begin #defines for assembler */
#define LPM0 (CPUOFF)
#define LPM1 (SCG0+CPUOFF)
#define LPM2 (SCG1+CPUOFF)
#define LPM3 (SCG1+SCG0+CPUOFF)
#define LPM4 (SCG1+SCG0+OSCOFF+CPUOFF)
/* End #defines for assembler */
#else /* Begin #defines for C */
#define LPM0_bits (CPUOFF)
#define LPM1_bits (SCG0+CPUOFF)
#define LPM2_bits (SCG1+CPUOFF)
#define LPM3_bits (SCG1+SCG0+CPUOFF)
#define LPM4_bits (SCG1+SCG0+OSCOFF+CPUOFF)
#include "in430.h"
#define LPM0 __bis_SR_register(LPM0_bits) /* Enter Low Power Mode 0 */
#define LPM0_EXIT __bic_SR_register_on_exit(LPM0_bits) /* Exit Low Power Mode 0 */
#define LPM1 __bis_SR_register(LPM1_bits) /* Enter Low Power Mode 1 */
#define LPM1_EXIT __bic_SR_register_on_exit(LPM1_bits) /* Exit Low Power Mode 1 */
#define LPM2 __bis_SR_register(LPM2_bits) /* Enter Low Power Mode 2 */
#define LPM2_EXIT __bic_SR_register_on_exit(LPM2_bits) /* Exit Low Power Mode 2 */
#define LPM3 __bis_SR_register(LPM3_bits) /* Enter Low Power Mode 3 */
#define LPM3_EXIT __bic_SR_register_on_exit(LPM3_bits) /* Exit Low Power Mode 3 */
#define LPM4 __bis_SR_register(LPM4_bits) /* Enter Low Power Mode 4 */
#define LPM4_EXIT __bic_SR_register_on_exit(LPM4_bits) /* Exit Low Power Mode 4 */
#endif /* End #defines for C */
* CPU
#define __MSP430_HAS_MSP430X_CPU__ /* Definition to show that it has MSP430X CPU */
* PERIPHERAL FILE MAP
* SPECIAL FUNCTION REGISTER ADDRESSES + CONTROL BITS
#define IE1_ (0x0000u) /* Interrupt Enable 1 */
DEFC( IE1 , IE1_)
#define WDTIE (0x01) /* Watchdog Interrupt Enable */
#define OFIE (0x02) /* Osc. Fault Interrupt Enable */
#define NMIIE (0x10) /* NMI Interrupt Enable */
#define ACCVIE (0x20) /* Flash Access Violation Interrupt Enable */
#define IFG1_ (0x0002u) /* Interrupt Flag 1 */
DEFC( IFG1 , IFG1_)
#define WDTIFG (0x01) /* Watchdog Interrupt Flag */
#define OFIFG (0x02) /* Osc. Fault Interrupt Flag */
#define PORIFG (0x04) /* Power On Interrupt Flag */
#define RSTIFG (0x08) /* Reset Interrupt Flag */
#define NMIIFG (0x10) /* NMI Interrupt Flag */
#define IE2_ (0x0001u) /* Interrupt Enable 2 */
DEFC( IE2 , IE2_)
#define UC0IE IE2
#define UCA0RXIE (0x01)
#define UCA0TXIE (0x02)
#define UCB0RXIE (0x04)
#define UCB0TXIE (0x08)
#define IFG2_ (0x0003u) /* Interrupt Flag 2 */
DEFC( IFG2 , IFG2_)
#define UC0IFG IFG2
#define UCA0RXIFG (0x01)
#define UCA0TXIFG (0x02)
#define UCB0RXIFG (0x04)
#define UCB0TXIFG (0x08)
#define UC1IE_ (0x0006u) /* USCI 1 Interrupt Enable */
DEFC( UC1IE , UC1IE_)
#define UCA1RXIE (0x01)
#define UCA1TXIE (0x02)
#define UCB1RXIE (0x04)
#define UCB1TXIE (0x08)
#define UC1IFG_ (0x0007u) /* ISCI 1 Interrupt Flags */
DEFC( UC1IFG , UC1IFG_)
#define UCA1RXIFG (0x01)
#define UCA1TXIFG (0x02)
#define UCB1RXIFG (0x04)
#define UCB1TXIFG (0x08)
* ADC12
#define __MSP430_HAS_ADC12__ /* Definition to show that Module is available */
#define ADC12CTL0_ (0x01A0u) /* ADC12 Control 0 */
DEFW( ADC12CTL0 , ADC12CTL0_)
#define ADC12CTL1_ (0x01A2u) /* ADC12 Control 1 */
DEFW( ADC12CTL1 , ADC12CTL1_)
#define ADC12IFG_ (0x01A4u) /* ADC12 Interrupt Flag */
DEFW( ADC12IFG , ADC12IFG_)
#define ADC12IE_ (0x01A6u) /* ADC12 Interrupt Enable */
DEFW( ADC12IE , ADC12IE_)
#define ADC12IV_ (0x01A8u) /* ADC12 Interrupt Vector Word */
DEFW( ADC12IV , ADC12IV_)
#define ADC12MEM_ (0x0140u) /* ADC12 Conversion Memory */
#define ADC12MEM (ADC12MEM_) /* ADC12 Conversion Memory (for assembler) */
#else
#define ADC12MEM ((int*) ADC12MEM_) /* ADC12 Conversion Memory (for C) */
#endif
#define ADC12MEM0_ (0x0140u) /* ADC12 Conversion Memory 0 */
DEFW( ADC12MEM0 , ADC12MEM0_)
#define ADC12MEM1_ (0x0142u) /* ADC12 Conversion Memory 1 */
DEFW( ADC12MEM1 , ADC12MEM1_)
#define ADC12MEM2_ (0x0144u) /* ADC12 Conversion Memory 2 */
DEFW( ADC12MEM2 , ADC12MEM2_)
#define ADC12MEM3_ (0x0146u) /* ADC12 Conversion Memory 3 */
DEFW( ADC12MEM3 , ADC12MEM3_)
#define ADC12MEM4_ (0x0148u) /* ADC12 Conversion Memory 4 */
DEFW( ADC12MEM4 , ADC12MEM4_)
#define ADC12MEM5_ (0x014Au) /* ADC12 Conversion Memory 5 */
DEFW( ADC12MEM5 , ADC12MEM5_)
#define ADC12MEM6_ (0x014Cu) /* ADC12 Conversion Memory 6 */
DEFW( ADC12MEM6 , ADC12MEM6_)
#define ADC12MEM7_ (0x014Eu) /* ADC12 Conversion Memory 7 */
DEFW( ADC12MEM7 , ADC12MEM7_)
#define ADC12MEM8_ (0x0150u) /* ADC12 Conversion Memory 8 */
DEFW( ADC12MEM8 , ADC12MEM8_)
#define ADC12MEM9_ (0x0152u) /* ADC12 Conversion Memory 9 */
DEFW( ADC12MEM9 , ADC12MEM9_)
#define ADC12MEM10_ (0x0154u) /* ADC12 Conversion Memory 10 */
DEFW( ADC12MEM10 , ADC12MEM10_)
#define ADC12MEM11_ (0x0156u) /* ADC12 Conversion Memory 11 */
DEFW( ADC12MEM11 , ADC12MEM11_)
#define ADC12MEM12_ (0x0158u) /* ADC12 Conversion Memory 12 */
DEFW( ADC12MEM12 , ADC12MEM12_)
#define ADC12MEM13_ (0x015Au) /* ADC12 Conversion Memory 13 */
DEFW( ADC12MEM13 , ADC12MEM13_)
#define ADC12MEM14_ (0x015Cu) /* ADC12 Conversion Memory 14 */
DEFW( ADC12MEM14 , ADC12MEM14_)
#define ADC12MEM15_ (0x015Eu) /* ADC12 Conversion Memory 15 */
DEFW( ADC12MEM15 , ADC12MEM15_)
#define ADC12MCTL_ (0x0080u) /* ADC12 Memory Control */
#define ADC12MCTL (ADC12MCTL_) /* ADC12 Memory Control (for assembler) */
#else
#define ADC12MCTL ((char*) ADC12MCTL_) /* ADC12 Memory Control (for C) */
#endif
#define ADC12MCTL0_ (0x0080u) /* ADC12 Memory Control 0 */
DEFC( ADC12MCTL0 , ADC12MCTL0_)
#define ADC12MCTL1_ (0x0081u) /* ADC12 Memory Control 1 */
DEFC( ADC12MCTL1 , ADC12MCTL1_)
#define ADC12MCTL2_ (0x0082u) /* ADC12 Memory Control 2 */
DEFC( ADC12MCTL2 , ADC12MCTL2_)
#define ADC12MCTL3_ (0x0083u) /* ADC12 Memory Control 3 */
DEFC( ADC12MCTL3 , ADC12MCTL3_)
#define ADC12MCTL4_ (0x0084u) /* ADC12 Memory Control 4 */
DEFC( ADC12MCTL4 , ADC12MCTL4_)
#define ADC12MCTL5_ (0x0085u) /* ADC12 Memory Control 5 */
DEFC( ADC12MCTL5 , ADC12MCTL5_)
#define ADC12MCTL6_ (0x0086u) /* ADC12 Memory Control 6 */
DEFC( ADC12MCTL6 , ADC12MCTL6_)
#define ADC12MCTL7_ (0x0087u) /* ADC12 Memory Control 7 */
DEFC( ADC12MCTL7 , ADC12MCTL7_)
#define ADC12MCTL8_ (0x0088u) /* ADC12 Memory Control 8 */
DEFC( ADC12MCTL8 , ADC12MCTL8_)
#define ADC12MCTL9_ (0x0089u) /* ADC12 Memory Control 9 */
DEFC( ADC12MCTL9 , ADC12MCTL9_)
#define ADC12MCTL10_ (0x008Au) /* ADC12 Memory Control 10 */
DEFC( ADC12MCTL10 , ADC12MCTL10_)
#define ADC12MCTL11_ (0x008Bu) /* ADC12 Memory Control 11 */
DEFC( ADC12MCTL11 , ADC12MCTL11_)
#define ADC12MCTL12_ (0x008Cu) /* ADC12 Memory Control 12 */
DEFC( ADC12MCTL12 , ADC12MCTL12_)
#define ADC12MCTL13_ (0x008Du) /* ADC12 Memory Control 13 */
DEFC( ADC12MCTL13 , ADC12MCTL13_)
#define ADC12MCTL14_ (0x008Eu) /* ADC12 Memory Control 14 */
DEFC( ADC12MCTL14 , ADC12MCTL14_)
#define ADC12MCTL15_ (0x008Fu) /* ADC12 Memory Control 15 */
DEFC( ADC12MCTL15 , ADC12MCTL15_)
/* ADC12CTL0 */
#define ADC12SC (0x001) /* ADC12 Start Conversion */
#define ENC (0x002) /* ADC12 Enable Conversion */
#define ADC12TOVIE (0x004) /* ADC12 Timer Overflow interrupt enable */
#define ADC12OVIE (0x008) /* ADC12 Overflow interrupt enable */
#define ADC12ON (0x010) /* ADC12 On/enable */
#define REFON (0x020) /* ADC12 Reference on */
#define REF2_5V (0x040) /* ADC12 Ref 0:1.5V / 1:2.5V */
#define MSC (0x080) /* ADC12 Multiple SampleConversion */
#define SHT00 (0x0100u) /* ADC12 Sample Hold 0 Select 0 */
#define SHT01 (0x0200u) /* ADC12 Sample Hold 0 Select 1 */
#define SHT02 (0x0400u) /* ADC12 Sample Hold 0 Select 2 */
#define SHT03 (0x0800u) /* ADC12 Sample Hold 0 Select 3 */
#define SHT10 (0x1000u) /* ADC12 Sample Hold 0 Select 0 */
#define SHT11 (0x2000u) /* ADC12 Sample Hold 1 Select 1 */
#define SHT12 (0x4000u) /* ADC12 Sample Hold 2 Select 2 */
#define SHT13 (0x8000u) /* ADC12 Sample Hold 3 Select 3 */
#define MSH (0x080)
#define SHT0_0 (0*0x100u) /* ADC12 Sample Hold 0 Select Bit: 0 */
#define SHT0_1 (1*0x100u) /* ADC12 Sample Hold 0 Select Bit: 1 */
#define SHT0_2 (2*0x100u) /* ADC12 Sample Hold 0 Select Bit: 2 */
#define SHT0_3 (3*0x100u) /* ADC12 Sample Hold 0 Select Bit: 3 */
#define SHT0_4 (4*0x100u) /* ADC12 Sample Hold 0 Select Bit: 4 */
#define SHT0_5 (5*0x100u) /* ADC12 Sample Hold 0 Select Bit: 5 */
#define SHT0_6 (6*0x100u) /* ADC12 Sample Hold 0 Select Bit: 6 */
#define SHT0_7 (7*0x100u) /* ADC12 Sample Hold 0 Select Bit: 7 */
#define SHT0_8 (8*0x100u) /* ADC12 Sample Hold 0 Select Bit: 8 */
#define SHT0_9 (9*0x100u) /* ADC12 Sample Hold 0 Select Bit: 9 */
#define SHT0_10 (10*0x100u) /* ADC12 Sample Hold 0 Select Bit: 10 */
#define SHT0_11 (11*0x100u) /* ADC12 Sample Hold 0 Select Bit: 11 */
#define SHT0_12 (12*0x100u) /* ADC12 Sample Hold 0 Select Bit: 12 */
#define SHT0_13 (13*0x100u) /* ADC12 Sample Hold 0 Select Bit: 13 */
#define SHT0_14 (14*0x100u) /* ADC12 Sample Hold 0 Select Bit: 14 */
#define SHT0_15 (15*0x100u) /* ADC12 Sample Hold 0 Select Bit: 15 */
#define SHT1_0 (0*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 0 */
#define SHT1_1 (1*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 1 */
#define SHT1_2 (2*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 2 */
#define SHT1_3 (3*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 3 */
#define SHT1_4 (4*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 4 */
#define SHT1_5 (5*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 5 */
#define SHT1_6 (6*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 6 */
#define SHT1_7 (7*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 7 */
#define SHT1_8 (8*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 8 */
#define SHT1_9 (9*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 9 */
#define SHT1_10 (10*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 10 */
#define SHT1_11 (11*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 11 */
#define SHT1_12 (12*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 12 */
#define SHT1_13 (13*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 13 */
#define SHT1_14 (14*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 14 */
#define SHT1_15 (15*0x1000u) /* ADC12 Sample Hold 1 Select Bit: 15 */
/* ADC12CTL1 */
#define ADC12BUSY (0x0001u) /* ADC12 Busy */
#define CONSEQ0 (0x0002u) /* ADC12 Conversion Sequence Select 0 */
#define CONSEQ1 (0x0004u) /* ADC12 Conversion Sequence Select 1 */
#define ADC12SSEL0 (0x0008u) /* ADC12 Clock Source Select 0 */
#define ADC12SSEL1 (0x0010u) /* ADC12 Clock Source Select 1 */
#define ADC12DIV0 (0x0020u) /* ADC12 Clock Divider Select 0 */
#define ADC12DIV1 (0x0040u) /* ADC12 Clock Divider Select 1 */
#define ADC12DIV2 (0x0080u) /* ADC12 Clock Divider Select 2 */
#define ISSH (0x0100u) /* ADC12 Invert Sample Hold Signal */
#define SHP (0x0200u) /* ADC12 Sample/Hold Pulse Mode */
#define SHS0 (0x0400u) /* ADC12 Sample/Hold Source 0 */
#define SHS1 (0x0800u) /* ADC12 Sample/Hold Source 1 */
#define CSTARTADD0 (0x1000u) /* ADC12 Conversion Start Address 0 */
#define CSTARTADD1 (0x2000u) /* ADC12 Conversion Start Address 1 */
#define CSTARTADD2 (0x4000u) /* ADC12 Conversion Start Address 2 */
#define CSTARTADD3 (0x8000u) /* ADC12 Conversion Start Address 3 */
#define CONSEQ_0 (0*2u) /* ADC12 Conversion Sequence Select: 0 */
#define CONSEQ_1 (1*2u) /* ADC12 Conversion Sequence Select: 1 */
#define CONSEQ_2 (2*2u) /* ADC12 Conversion Sequence Select: 2 */
#define CONSEQ_3 (3*2u) /* ADC12 Conversion Sequence Select: 3 */
#define ADC12SSEL_0 (0*8u) /* ADC12 Clock Source Select: 0 */
#define ADC12SSEL_1 (1*8u) /* ADC12 Clock Source Select: 1 */
#define ADC12SSEL_2 (2*8u) /* ADC12 Clock Source Select: 2 */
#define ADC12SSEL_3 (3*8u) /* ADC12 Clock Source Select: 3 */
#define ADC12DIV_0 (0*0x20u) /* ADC12 Clock Divider Select: 0 */
#define ADC12DIV_1 (1*0x20u) /* ADC12 Clock Divider Select: 1 */
#define ADC12DIV_2 (2*0x20u) /* ADC12 Clock Divider Select: 2 */
#define ADC12DIV_3 (3*0x20u) /* ADC12 Clock Divider Select: 3 */
#define ADC12DIV_4 (4*0x20u) /* ADC12 Clock Divider Select: 4 */
#define ADC12DIV_5 (5*0x20u) /* ADC12 Clock Divider Select: 5 */
#define ADC12DIV_6 (6*0x20u) /* ADC12 Clock Divider Select: 6 */
#define ADC12DIV_7 (7*0x20u) /* ADC12 Clock Divider Select: 7 */
#define SHS_0 (0*0x400u) /* ADC12 Sample/Hold Source: 0 */
#define SHS_1 (1*0x400u) /* ADC12 Sample/Hold Source: 1 */
#define SHS_2 (2*0x400u) /* ADC12 Sample/Hold Source: 2 */
#define SHS_3 (3*0x400u) /* ADC12 Sample/Hold Source: 3 */
#define CSTARTADD_0 (0*0x1000u) /* ADC12 Conversion Start Address: 0 */
#define CSTARTADD_1 (1*0x1000u) /* ADC12 Conversion Start Address: 1 */
#define CSTARTADD_2 (2*0x1000u) /* ADC12 Conversion Start Address: 2 */
#define CSTARTADD_3 (3*0x1000u) /* ADC12 Conversion Start Address: 3 */
#define CSTARTADD_4 (4*0x1000u) /* ADC12 Conversion Start Address: 4 */
#define CSTARTADD_5 (5*0x1000u) /* ADC12 Conversion Start Address: 5 */
#define CSTARTADD_6 (6*0x1000u) /* ADC12 Conversion Start Address: 6 */
#define CSTARTADD_7 (7*0x1000u) /* ADC12 Conversion Start Address: 7 */
#define CSTARTADD_8 (8*0x1000u) /* ADC12 Conversion Start Address: 8 */
#define CSTARTADD_9 (9*0x1000u) /* ADC12 Conversion Start Address: 9 */
#define CSTARTADD_10 (10*0x1000u) /* ADC12 Conversion Start Address: 10 */
#define CSTARTADD_11 (11*0x1000u) /* ADC12 Conversion Start Address: 11 */
#define CSTARTADD_12 (12*0x1000u) /* ADC12 Conversion Start Address: 12 */
#define CSTARTADD_13 (13*0x1000u) /* ADC12 Conversion Start Address: 13 */
#define CSTARTADD_14 (14*0x1000u) /* ADC12 Conversion Start Address: 14 */
#define CSTARTADD_15 (15*0x1000u) /* ADC12 Conversion Start Address: 15 */
/* ADC12MCTLx */
#define INCH0 (0x0001u) /* ADC12 Input Channel Select Bit 0 */
#define INCH1 (0x0002u) /* ADC12 Input Channel Select Bit 1 */
#define INCH2 (0x0004u) /* ADC12 Input Channel Select Bit 2 */
#define INCH3 (0x0008u) /* ADC12 Input Channel Select Bit 3 */
#define SREF0 (0x0010u) /* ADC12 Select Reference Bit 0 */
#define SREF1 (0x0020u) /* ADC12 Select Reference Bit 1 */
#define SREF2 (0x0040u) /* ADC12 Select Reference Bit 2 */
#define EOS (0x0080u) /* ADC12 End of Sequence */
#define INCH_0 (0) /* ADC12 Input Channel 0 */
#define INCH_1 (1) /* ADC12 Input Channel 1 */
#define INCH_2 (2) /* ADC12 Input Channel 2 */
#define INCH_3 (3) /* ADC12 Input Channel 3 */
#define INCH_4 (4) /* ADC12 Input Channel 4 */
#define INCH_5 (5) /* ADC12 Input Channel 5 */
#define INCH_6 (6) /* ADC12 Input Channel 6 */
#define INCH_7 (7) /* ADC12 Input Channel 7 */
#define INCH_8 (8) /* ADC12 Input Channel 8 */
#define INCH_9 (9) /* ADC12 Input Channel 9 */
#define INCH_10 (10) /* ADC12 Input Channel 10 */
#define INCH_11 (11) /* ADC12 Input Channel 11 */
#define INCH_12 (12) /* ADC12 Input Channel 12 */
#define INCH_13 (13) /* ADC12 Input Channel 13 */
#define INCH_14 (14) /* ADC12 Input Channel 14 */
#define INCH_15 (15) /* ADC12 Input Channel 15 */
#define SREF_0 (0*0x10u) /* ADC12 Select Reference 0 */
#define SREF_1 (1*0x10u) /* ADC12 Select Reference 1 */
#define SREF_2 (2*0x10u) /* ADC12 Select Reference 2 */
#define SREF_3 (3*0x10u) /* ADC12 Select Reference 3 */
#define SREF_4 (4*0x10u) /* ADC12 Select Reference 4 */
#define SREF_5 (5*0x10u) /* ADC12 Select Reference 5 */
#define SREF_6 (6*0x10u) /* ADC12 Select Reference 6 */
#define SREF_7 (7*0x10u) /* ADC12 Select Reference 7 */
/* ADC12IV Definitions */
#define ADC12IV_NONE (0x0000u) /* No Interrupt pending */
#define ADC12IV_ADC12OVIFG (0x0002u) /* ADC12OVIFG */
#define ADC12IV_ADC12TOVIFG (0x0004u) /* ADC12TOVIFG */
#define ADC12IV_ADC12IFG0 (0x0006u) /* ADC12IFG0 */
#define ADC12IV_ADC12IFG1 (0x0008u) /* ADC12IFG1 */
#define ADC12IV_ADC12IFG2 (0x000Au) /* ADC12IFG2 */
#define ADC12IV_ADC12IFG3 (0x000Cu) /* ADC12IFG3 */
#define ADC12IV_ADC12IFG4 (0x000Eu) /* ADC12IFG4 */
#define ADC12IV_ADC12IFG5 (0x0010u) /* ADC12IFG5 */
#define ADC12IV_ADC12IFG6 (0x0012u) /* ADC12IFG6 */
#define ADC12IV_ADC12IFG7 (0x0014u) /* ADC12IFG7 */
#define ADC12IV_ADC12IFG8 (0x0016u) /* ADC12IFG8 */
#define ADC12IV_ADC12IFG9 (0x0018u) /* ADC12IFG9 */
#define ADC12IV_ADC12IFG10 (0x001Au) /* ADC12IFG10 */
#define ADC12IV_ADC12IFG11 (0x001Cu) /* ADC12IFG11 */
#define ADC12IV_ADC12IFG12 (0x001Eu) /* ADC12IFG12 */
#define ADC12IV_ADC12IFG13 (0x0020u) /* ADC12IFG13 */
#define ADC12IV_ADC12IFG14 (0x0022u) /* ADC12IFG14 */
#define ADC12IV_ADC12IFG15 (0x0024u) /* ADC12IFG15 */
* Basic Clock Module
#define __MSP430_HAS_BC2__ /* Definition to show that Module is available */
#define DCOCTL_ (0x0056u) /* DCO Clock Frequency Control */
DEFC( DCOCTL , DCOCTL_)
#define BCSCTL1_ (0x0057u) /* Basic Clock System Control 1 */
DEFC( BCSCTL1 , BCSCTL1_)
#define BCSCTL2_ (0x0058u) /* Basic Clock System Control 2 */
DEFC( BCSCTL2 , BCSCTL2_)
#define BCSCTL3_ (0x0053u) /* Basic Clock System Control 3 */
DEFC( BCSCTL3 , BCSCTL3_)
#define MOD0 (0x01) /* Modulation Bit 0 */
#define MOD1 (0x02) /* Modulation Bit 1 */
#define MOD2 (0x04) /* Modulation Bit 2 */
#define MOD3 (0x08) /* Modulation Bit 3 */
#define MOD4 (0x10) /* Modulation Bit 4 */
#define DCO0 (0x20) /* DCO Select Bit 0 */
#define DCO1 (0x40) /* DCO Select Bit 1 */
#define DCO2 (0x80) /* DCO Select Bit 2 */
#define RSEL0 (0x01) /* Range Select Bit 0 */
#define RSEL1 (0x02) /* Range Select Bit 1 */
#define RSEL2 (0x04) /* Range Select Bit 2 */
#define RSEL3 (0x08) /* Range Select Bit 3 */
#define DIVA0 (0x10) /* ACLK Divider 0 */
#define DIVA1 (0x20) /* ACLK Divider 1 */
#define XTS (0x40) /* LFXTCLK 0:Low Freq. / 1: High Freq. */
#define XT2OFF (0x80) /* Enable XT2CLK */
#define DIVA_0 (0x00) /* ACLK Divider 0: /1 */
#define DIVA_1 (0x10) /* ACLK Divider 1: /2 */
#define DIVA_2 (0x20) /* ACLK Divider 2: /4 */
#define DIVA_3 (0x30) /* ACLK Divider 3: /8 */
#define DCOR (0x01) /* Enable External Resistor : 1 */
#define DIVS0 (0x02) /* SMCLK Divider 0 */
#define DIVS1 (0x04) /* SMCLK Divider 1 */
#define SELS (0x08) /* SMCLK Source Select 0:DCOCLK / 1:XT2CLK/LFXTCLK */
#define DIVM0 (0x10) /* MCLK Divider 0 */
#define DIVM1 (0x20) /* MCLK Divider 1 */
#define SELM0 (0x40) /* MCLK Source Select 0 */
#define SELM1 (0x80) /* MCLK Source Select 1 */
#define DIVS_0 (0x00) /* SMCLK Divider 0: /1 */
#define DIVS_1 (0x02) /* SMCLK Divider 1: /2 */
#define DIVS_2 (0x04) /* SMCLK Divider 2: /4 */
#define DIVS_3 (0x06) /* SMCLK Divider 3: /8 */
#define DIVM_0 (0x00) /* MCLK Divider 0: /1 */
#define DIVM_1 (0x10) /* MCLK Divider 1: /2 */
#define DIVM_2 (0x20) /* MCLK Divider 2: /4 */
#define DIVM_3 (0x30) /* MCLK Divider 3: /8 */
#define SELM_0 (0x00) /* MCLK Source Select 0: DCOCLK */
#define SELM_1 (0x40) /* MCLK Source Select 1: DCOCLK */
#define SELM_2 (0x80) /* MCLK Source Select 2: XT2CLK/LFXTCLK */
#define SELM_3 (0xC0) /* MCLK Source Select 3: LFXTCLK */
#define LFXT1OF (0x01) /* Low/high Frequency Oscillator Fault Flag */
#define XT2OF (0x02) /* High frequency oscillator 2 fault flag */
#define XCAP0 (0x04) /* XIN/XOUT Cap 0 */
#define XCAP1 (0x08) /* XIN/XOUT Cap 1 */
#define LFXT1S0 (0x10) /* Mode 0 for LFXT1 (XTS = 0) */
#define LFXT1S1 (0x20) /* Mode 1 for LFXT1 (XTS = 0) */
#define XT2S0 (0x40) /* Mode 0 for XT2 */
#define XT2S1 (0x80) /* Mode 1 for XT2 */
#define XCAP_0 (0x00) /* XIN/XOUT Cap : 0 pF */
#define XCAP_1 (0x04) /* XIN/XOUT Cap : 6 pF */
#define XCAP_2 (0x08) /* XIN/XOUT Cap : 10 pF */
#define XCAP_3 (0x0C) /* XIN/XOUT Cap : 12.5 pF */
#define LFXT1S_0 (0x00) /* Mode 0 for LFXT1 : Normal operation */
#define LFXT1S_1 (0x10) /* Mode 1 for LFXT1 : Reserved */
#define LFXT1S_2 (0x20) /* Mode 2 for LFXT1 : VLO */
#define LFXT1S_3 (0x30) /* Mode 3 for LFXT1 : Digital input signal */
#define XT2S_0 (0x00) /* Mode 0 for XT2 : 0.4 - 1 MHz */
#define XT2S_1 (0x40) /* Mode 1 for XT2 : 1 - 4 MHz */
#define XT2S_2 (0x80) /* Mode 2 for XT2 : 2 - 16 MHz */
#define XT2S_3 (0xC0) /* Mode 3 for XT2 : Digital input signal */
* Comparator A
#define __MSP430_HAS_CAPLUS__ /* Definition to show that Module is available */
#define CACTL1_ (0x0059u) /* Comparator A Control 1 */
DEFC( CACTL1 , CACTL1_)
#define CACTL2_ (0x005Au) /* Comparator A Control 2 */
DEFC( CACTL2 , CACTL2_)
#define CAPD_ (0x005Bu) /* Comparator A Port Disable */
DEFC( CAPD , CAPD_)
#define CAIFG (0x01) /* Comp. A Interrupt Flag */
#define CAIE (0x02) /* Comp. A Interrupt Enable */
#define CAIES (0x04) /* Comp. A Int. Edge Select: 0:rising / 1:falling */
#define CAON (0x08) /* Comp. A enable */
#define CAREF0 (0x10) /* Comp. A Internal Reference Select 0 */
#define CAREF1 (0x20) /* Comp. A Internal Reference Select 1 */
#define CARSEL (0x40) /* Comp. A Internal Reference Enable */
#define CAEX (0x80) /* Comp. A Exchange Inputs */
#define CAREF_0 (0x00) /* Comp. A Int. Ref. Select 0 : Off */
#define CAREF_1 (0x10) /* Comp. A Int. Ref. Select 1 : 0.25*Vcc */
#define CAREF_2 (0x20) /* Comp. A Int. Ref. Select 2 : 0.5*Vcc */
#define CAREF_3 (0x30) /* Comp. A Int. Ref. Select 3 : Vt*/
#define CAOUT (0x01) /* Comp. A Output */
#define CAF (0x02) /* Comp. A Enable Output Filter */
#define P2CA0 (0x04) /* Comp. A +Terminal Multiplexer */
#define P2CA1 (0x08) /* Comp. A -Terminal Multiplexer */
#define P2CA2 (0x10) /* Comp. A -Terminal Multiplexer */
#define P2CA3 (0x20) /* Comp. A -Terminal Multiplexer */
#define P2CA4 (0x40) /* Comp. A +Terminal Multiplexer */
#define CASHORT (0x80) /* Comp. A Short + and - Terminals */
#define CAPD0 (0x01) /* Comp. A Disable Input Buffer of Port Register .0 */
#define CAPD1 (0x02) /* Comp. A Disable Input Buffer of Port Register .1 */
#define CAPD2 (0x04) /* Comp. A Disable Input Buffer of Port Register .2 */
#define CAPD3 (0x08) /* Comp. A Disable Input Buffer of Port Register .3 */
#define CAPD4 (0x10) /* Comp. A Disable Input Buffer of Port Register .4 */
#define CAPD5 (0x20) /* Comp. A Disable Input Buffer of Port Register .5 */
#define CAPD6 (0x40) /* Comp. A Disable Input Buffer of Port Register .6 */
#define CAPD7 (0x80) /* Comp. A Disable Input Buffer of Port Register .7 */
* Flash Memory
#define __MSP430_HAS_FLASH2__ /* Definition to show that Module is available */
#define FCTL1_ (0x0128u) /* FLASH Control 1 */
DEFW( FCTL1 , FCTL1_)
#define FCTL2_ (0x012Au) /* FLASH Control 2 */
DEFW( FCTL2 , FCTL2_)
#define FCTL3_ (0x012Cu) /* FLASH Control 3 */
DEFW( FCTL3 , FCTL3_)
#define FCTL4_ (0x01BEu) /* FLASH Control 4 */
DEFW( FCTL4 , FCTL4_)
#define FRKEY (0x9600u) /* Flash key returned by read */
#define FWKEY (0xA500u) /* Flash key for write */
#define FXKEY (0x3300u) /* for use with XOR instruction */
#define ERASE (0x0002u) /* Enable bit for Flash segment erase */
#define MERAS (0x0004u) /* Enable bit for Flash mass erase */
#define EEI (0x0008u) /* Enable Erase Interrupts */
#define EEIEX (0x0010u) /* Enable Emergency Interrupt Exit */
#define WRT (0x0040u) /* Enable bit for Flash write */
#define BLKWRT (0x0080u) /* Enable bit for Flash segment write */
#define SEGWRT (0x0080u) /* old definition */ /* Enable bit for Flash segment write */
#define FN0 (0x0001u) /* Divide Flash clock by 1 to 64 using FN0 to FN5 according to: */
#define FN1 (0x0002u) /* 32*FN5 + 16*FN4 + 8*FN3 + 4*FN2 + 2*FN1 + FN0 + 1 */
#ifndef FN2
#define FN2 (0x0004u)
#endif
#ifndef FN3
#define FN3 (0x0008u)
#endif
#ifndef FN4
#define FN4 (0x0010u)
#endif
#define FN5 (0x0020u)
#define FSSEL0 (0x0040u) /* Flash clock select 0 */ /* to distinguish from USART SSELx */
#define FSSEL1 (0x0080u) /* Flash clock select 1 */
#define FSSEL_0 (0x0000u) /* Flash clock select: 0 - ACLK */
#define FSSEL_1 (0x0040u) /* Flash clock select: 1 - MCLK */
#define FSSEL_2 (0x0080u) /* Flash clock select: 2 - SMCLK */
#define FSSEL_3 (0x00C0u) /* Flash clock select: 3 - SMCLK */
#define BUSY (0x0001u) /* Flash busy: 1 */
#define KEYV (0x0002u) /* Flash Key violation flag */
#define ACCVIFG (0x0004u) /* Flash Access violation flag */
#define WAIT (0x0008u) /* Wait flag for segment write */
#define LOCK (0x0010u) /* Lock bit: 1 - Flash is locked (read only) */
#define EMEX (0x0020u) /* Flash Emergency Exit */
#define LOCKA (0x0040u) /* Segment A Lock bit: read = 1 - Segment is locked (read only) */
#define FAIL (0x0080u) /* Last Program or Erase failed */
#define MGR0 (0x0010u) /* Marginal read 0 mode. */
#define MGR1 (0x0020u) /* Marginal read 1 mode. */
* HARDWARE MULTIPLIER
#define __MSP430_HAS_MPY__ /* Definition to show that Module is available */
#define MPY_ (0x0130u) /* Multiply Unsigned/Operand 1 */
DEFW( MPY , MPY_)
#define MPYS_ (0x0132u) /* Multiply Signed/Operand 1 */
DEFW( MPYS , MPYS_)
#define MAC_ (0x0134u) /* Multiply Unsigned and Accumulate/Operand 1 */
DEFW( MAC , MAC_)
#define MACS_ (0x0136u) /* Multiply Signed and Accumulate/Operand 1 */
DEFW( MACS , MACS_)
#define OP2_ (0x0138u) /* Operand 2 */
DEFW( OP2 , OP2_)
#define RESLO_ (0x013Au) /* Result Low Word */
DEFW( RESLO , RESLO_)
#define RESHI_ (0x013Cu) /* Result High Word */
DEFW( RESHI , RESHI_)
#define SUMEXT_ (0x013Eu) /* Sum Extend */
READ_ONLY DEFW( SUMEXT , SUMEXT_)
* DIGITAL I/O Port1/2 Pull up / Pull down Resistors
#define __MSP430_HAS_PORT1_R__ /* Definition to show that Module is available */
#define __MSP430_HAS_PORT2_R__ /* Definition to show that Module is available */
#define P1IN_ (0x0020u) /* Port 1 Input */
READ_ONLY DEFC( P1IN , P1IN_)
#define P1OUT_ (0x0021u) /* Port 1 Output */
DEFC( P1OUT , P1OUT_)
#define P1DIR_ (0x0022u) /* Port 1 Direction */
DEFC( P1DIR , P1DIR_)
#define P1IFG_ (0x0023u) /* Port 1 Interrupt Flag */
DEFC( P1IFG , P1IFG_)
#define P1IES_ (0x0024u) /* Port 1 Interrupt Edge Select */
DEFC( P1IES , P1IES_)
#define P1IE_ (0x0025u) /* Port 1 Interrupt Enable */
DEFC( P1IE , P1IE_)
#define P1SEL_ (0x0026u) /* Port 1 Selection */
DEFC( P1SEL , P1SEL_)
#define P1REN_ (0x0027u) /* Port 1 Resistor Enable */
DEFC( P1REN , P1REN_)
#define P2IN_ (0x0028u) /* Port 2 Input */
READ_ONLY DEFC( P2IN , P2IN_)
#define P2OUT_ (0x0029u) /* Port 2 Output */
DEFC( P2OUT , P2OUT_)
#define P2DIR_ (0x002Au) /* Port 2 Direction */
DEFC( P2DIR , P2DIR_)
#define P2IFG_ (0x002Bu) /* Port 2 Interrupt Flag */
DEFC( P2IFG , P2IFG_)
#define P2IES_ (0x002Cu) /* Port 2 Interrupt Edge Select */
DEFC( P2IES , P2IES_)
#define P2IE_ (0x002Du) /* Port 2 Interrupt Enable */
DEFC( P2IE , P2IE_)
#define P2SEL_ (0x002Eu) /* Port 2 Selection */
DEFC( P2SEL , P2SEL_)
#define P2REN_ (0x002Fu) /* Port 2 Resistor Enable */
DEFC( P2REN , P2REN_)
* DIGITAL I/O Port3/4 Pull up / Pull down Resistors
#define __MSP430_HAS_PORT3_R__ /* Definition to show that Module is available */
#define __MSP430_HAS_PORT4_R__ /* Definition to show that Module is available */
#define P3IN_ (0x0018u) /* Port 3 Input */
READ_ONLY DEFC( P3IN , P3IN_)
#define P3OUT_ (0x0019u) /* Port 3 Output */
DEFC( P3OUT , P3OUT_)
#define P3DIR_ (0x001Au) /* Port 3 Direction */
DEFC( P3DIR , P3DIR_)
#define P3SEL_ (0x001Bu) /* Port 3 Selection */
DEFC( P3SEL , P3SEL_)
#define P3REN_ (0x0010u) /* Port 3 Resistor Enable */
DEFC( P3REN , P3REN_)
#define P4IN_ (0x001Cu) /* Port 4 Input */
READ_ONLY DEFC( P4IN , P4IN_)
#define P4OUT_ (0x001Du) /* Port 4 Output */
DEFC( P4OUT , P4OUT_)
#define P4DIR_ (0x001Eu) /* Port 4 Direction */
DEFC( P4DIR , P4DIR_)
#define P4SEL_ (0x001Fu) /* Port 4 Selection */
DEFC( P4SEL , P4SEL_)
#define P4REN_ (0x0011u) /* Port 4 Resistor Enable */
DEFC( P4REN , P4REN_)
* DIGITAL I/O Port5/6 Pull up / Pull down Resistors
#define __MSP430_HAS_PORT5_R__ /* Definition to show that Module is available */
#define __MSP430_HAS_PORT6_R__ /* Definition to show that Module is available */
#define P5IN_ (0x0030u) /* Port 5 Input */
READ_ONLY DEFC( P5IN , P5IN_)
#define P5OUT_ (0x0031u) /* Port 5 Output */
DEFC( P5OUT , P5OUT_)
#define P5DIR_ (0x0032u) /* Port 5 Direction */
DEFC( P5DIR , P5DIR_)
#define P5SEL_ (0x0033u) /* Port 5 Selection */
DEFC( P5SEL , P5SEL_)
#define P5REN_ (0x0012u) /* Port 5 Resistor Enable */
DEFC( P5REN , P5REN_)
#define P6IN_ (0x0034u) /* Port 6 Input */
READ_ONLY DEFC( P6IN , P6IN_)
#define P6OUT_ (0x0035u) /* Port 6 Output */
DEFC( P6OUT , P6OUT_)
#define P6DIR_ (0x0036u) /* Port 6 Direction */
DEFC( P6DIR , P6DIR_)
#define P6SEL_ (0x0037u) /* Port 6 Selection */
DEFC( P6SEL , P6SEL_)
#define P6REN_ (0x0013u) /* Port 6 Resistor Enable */
DEFC( P6REN , P6REN_)
* DIGITAL I/O Port7/8 Pull up / Pull down Resistors
#define __MSP430_HAS_PORT7_R__ /* Definition to show that Module is available */
#define __MSP430_HAS_PORT8_R__ /* Definition to show that Module is available */
#define __MSP430_HAS_PORTA_R__ /* Definition to show that Module is available */
#define P7IN_ (0x0038) /* Port 7 Input */
READ_ONLY DEFC( P7IN , P7IN_)
#endif
#define P7OUT_ (0x003A) /* Port 7 Output */
DEFC( P7OUT , P7OUT_)
#endif
#define P7DIR_ (0x003C) /* Port 7 Direction */
DEFC( P7DIR , P7DIR_)
#endif
#define P7SEL_ (0x003E) /* Port 7 Selection */
DEFC( P7SEL , P7SEL_)
#endif
#define P7REN_ (0x0014) /* Port 7 Resistor Enable */
DEFC( P7REN , P7REN_)
#endif
#define P8IN_ (0x0039) /* Port 8 Input */
READ_ONLY DEFC( P8IN , P8IN_)
#endif
#define P8OUT_ (0x003B) /* Port 8 Output */
DEFC( P8OUT , P8OUT_)
#endif
#define P8DIR_ (0x003D) /* Port 8 Direction */
DEFC( P8DIR , P8DIR_)
#endif
#define P8SEL_ (0x003F) /* Port 8 Selection */
DEFC( P8SEL , P8SEL_)
#endif
#define P8REN_ (0x0015) /* Port 8 Resistor Enable */
DEFC( P8REN , P8REN_)
#endif
#define PAIN_ (0x0038) /* Port A Input */
READ_ONLY DEFW( PAIN , PAIN_)
#endif
__no_init union
struct
READ_ONLY DEFXC P7IN;
READ_ONLY DEFXC P8IN;
READ_ONLY DEFXW PAIN;
} @ 0x0038;
#endif
#define PAOUT_ (0x003A) /* Port A Output */
DEFW( PAOUT , PAOUT_)
#endif
__no_init union
struct
DEFXC P7OUT;
DEFXC P8OUT;
DEFXW PAOUT;
} @ 0x003A;
#endif
#define PADIR_ (0x003C) /* Port A Direction */
DEFW( PADIR , PADIR_)
#endif
__no_init union
struct
DEFXC P7DIR;
DEFXC P8DIR;
DEFXW PADIR;
} @ 0x003C;
#endif
#define PASEL_ (0x003E) /* Port A Selection */
DEFW( PASEL , PASEL_)
#endif
__no_init union
struct
DEFXC P7SEL;
DEFXC P8SEL;
DEFXW PASEL;
} @ 0x003E;
#endif
#define PAREN_ (0x0014) /* Port A Resistor Enable */
DEFW( PAREN , PAREN_)
#endif
__no_init union
struct
DEFXC P7REN;
DEFXC P8REN;
DEFXW PAREN;
} @ 0x0014;
#endif
* Brown-Out, Supply Voltage Supervision (SVS)
#define __MSP430_HAS_SVS__ /* Definition to show that Module is available */
#define SVSCTL_ (0x0055u) /* SVS Control */
DEFC( SVSCTL , SVSCTL_)
#define SVSFG (0x01) /* SVS Flag */
#define SVSOP (0x02) /* SVS output (read only) */
#define SVSON (0x04) /* Switches the SVS on/off */
#define PORON (0x08) /* Enable POR Generation if Low Voltage */
#define VLD0 (0x10)
#define VLD1 (0x20)
#define VLD2 (0x40)
#define VLD3 (0x80)
#define VLDON (0x10)
#define VLDOFF (0x00)
#define VLD_1_8V (0x10)
* Timer A3
#define __MSP430_HAS_TA3__ /* Definition to show that Module is available */
#define TAIV_ (0x012Eu) /* Timer A Interrupt Vector Word */
READ_ONLY DEFW( TAIV , TAIV_)
#define TACTL_ (0x0160u) /* Timer A Control */
DEFW( TACTL , TACTL_)
#define TACCTL0_ (0x0162u) /* Timer A Capture/Compare Control 0 */
DEFW( TACCTL0 , TACCTL0_)
#define TACCTL1_ (0x0164u) /* Timer A Capture/Compare Control 1 */
DEFW( TACCTL1 , TACCTL1_)
#define TACCTL2_ (0x0166u) /* Timer A Capture/Compare Control 2 */
DEFW( TACCTL2 , TACCTL2_)
#define TAR_ (0x0170u) /* Timer A Counter Register */
DEFW( TAR , TAR_)
#define TACCR0_ (0x0172u) /* Timer A Capture/Compare 0 */
DEFW( TACCR0 , TACCR0_)
#define TACCR1_ (0x0174u) /* Timer A Capture/Compare 1 */
DEFW( TACCR1 , TACCR1_)
#define TACCR2_ (0x0176u) /* Timer A Capture/Compare 2 */
DEFW( TACCR2 , TACCR2_)
/* Alternate register names */
#define CCTL0 TACCTL0 /* Timer A Capture/Compare Control 0 */
#define CCTL1 TACCTL1 /* Timer A Capture/Compare Control 1 */
#define CCTL2 TACCTL2 /* Timer A Capture/Compare Control 2 */
#define CCR0 TACCR0 /* Timer A Capture/Compare 0 */
#define CCR1 TACCR1 /* Timer A Capture/Compare 1 */
#define CCR2 TACCR2 /* Timer A Capture/Compare 2 */
#define CCTL0_ TACCTL0_ /* Timer A Capture/Compare Control 0 */
#define CCTL1_ TACCTL1_ /* Timer A Capture/Compare Control 1 */
#define CCTL2_ TACCTL2_ /* Timer A Capture/Compare Control 2 */
#define CCR0_ TACCR0_ /* Timer A Capture/Compare 0 */
#define CCR1_ TACCR1_ /* Timer A Capture/Compare 1 */
#define CCR2_ TACCR2_ /* Timer A Capture/Compare 2 */
/* Alternate register names - 5xx style */
#define TA0IV TAIV /* Timer A Interrupt Vector Word */
#define TA0CTL TACTL /* Timer A Control */
#define TA0CCTL0 TACCTL0 /* Timer A Capture/Compare Control 0 */
#define TA0CCTL1 TACCTL1 /* Timer A Capture/Compare Control 1 */
#define TA0CCTL2 TACCTL2 /* Timer A Capture/Compare Control 2 */
#define TA0R TAR /* Timer A Counter Register */
#define TA0CCR0 TACCR0 /* Timer A Capture/Compare 0 */
#define TA0CCR1 TACCR1 /* Timer A Capture/Compare 1 */
#define TA0CCR2 TACCR2 /* Timer A Capture/Compare 2 */
#define TA0IV_ TAIV_ /* Timer A Interrupt Vector Word */
#define TA0CTL_ TACTL_ /* Timer A Control */
#define TA0CCTL0_ TACCTL0_ /* Timer A Capture/Compare Control 0 */
#define TA0CCTL1_ TACCTL1_ /* Timer A Capture/Compare Control 1 */
#define TA0CCTL2_ TACCTL2_ /* Timer A Capture/Compare Control 2 */
#define TA0R_ TAR_ /* Timer A Counter Register */
#define TA0CCR0_ TACCR0_ /* Timer A Capture/Compare 0 */
#define TA0CCR1_ TACCR1_ /* Timer A Capture/Compare 1 */
#define TA0CCR2_ TACCR2_ /* Timer A Capture/Compare 2 */
#define TIMER0_A1_VECTOR TIMERA1_VECTOR /* Int. Vector: Timer A CC1-2, TA */
#define TIMER0_A0_VECTOR TIMERA0_VECTOR /* Int. Vector: Timer A CC0 */
#define TASSEL1 (0x0200u) /* Timer A clock source select 1 */
#define TASSEL0 (0x0100u) /* Timer A clock source select 0 */
#define ID1 (0x0080u) /* Timer A clock input divider 1 */
#define ID0 (0x0040u) /* Timer A clock input divider 0 */
#define MC1 (0x0020u) /* Timer A mode control 1 */
#define MC0 (0x0010u) /* Timer A mode control 0 */
#define TACLR (0x0004u) /* Timer A counter clear */
#define TAIE (0x0002u) /* Timer A counter interrupt enable */
#define TAIFG (0x0001u) /* Timer A counter interrupt flag */
#define MC_0 (0*0x10u) /* Timer A mode control: 0 - Stop */
#define MC_1 (1*0x10u) /* Timer A mode control: 1 - Up to CCR0 */
#define MC_2 (2*0x10u) /* Timer A mode control: 2 - Continous up */
#define MC_3 (3*0x10u) /* Timer A mode control: 3 - Up/Down */
#define ID_0 (0*0x40u) /* Timer A input divider: 0 - /1 */
#define ID_1 (1*0x40u) /* Timer A input divider: 1 - /2 */
#define ID_2 (2*0x40u) /* Timer A input divider: 2 - /4 */
#define ID_3 (3*0x40u) /* Timer A input divider: 3 - /8 */
#define TASSEL_0 (0*0x100u) /* Timer A clock source select: 0 - TACLK */
#define TASSEL_1 (1*0x100u) /* Timer A clock source select: 1 - ACLK */
#define TASSEL_2 (2*0x100u) /* Timer A clock source select: 2 - SMCLK */
#define TASSEL_3 (3*0x100u) /* Timer A clock source select: 3 - INCLK */
#define CM1 (0x8000u) /* Capture mode 1 */
#define CM0 (0x4000u) /* Capture mode 0 */
#define CCIS1 (0x2000u) /* Capture input select 1 */
#define CCIS0 (0x1000u) /* Capture input select 0 */
#define SCS (0x0800u) /* Capture sychronize */
#define SCCI (0x0400u) /* Latched capture signal (read) */
#define CAP (0x0100u) /* Capture mode: 1 /Compare mode : 0 */
#define OUTMOD2 (0x0080u) /* Output mode 2 */
#define OUTMOD1 (0x0040u) /* Output mode 1 */
#define OUTMOD0 (0x0020u) /* Output mode 0 */
#define CCIE (0x0010u) /* Capture/compare interrupt enable */
#define CCI (0x0008u) /* Capture input signal (read) */
#define OUT (0x0004u) /* PWM Output signal if output mode 0 */
#define COV (0x0002u) /* Capture/compare overflow flag */
#define CCIFG (0x0001u) /* Capture/compare interrupt flag */
#define OUTMOD_0 (0*0x20u) /* PWM output mode: 0 - output only */
#define OUTMOD_1 (1*0x20u) /* PWM output mode: 1 - set */
#define OUTMOD_2 (2*0x20u) /* PWM output mode: 2 - PWM toggle/reset */
#define OUTMOD_3 (3*0x20u) /* PWM output mode: 3 - PWM set/reset */
#define OUTMOD_4 (4*0x20u) /* PWM output mode: 4 - toggle */
#define OUTMOD_5 (5*0x20u) /* PWM output mode: 5 - Reset */
#define OUTMOD_6 (6*0x20u) /* PWM output mode: 6 - PWM toggle/set */
#define OUTMOD_7 (7*0x20u) /* PWM output mode: 7 - PWM reset/set */
#define CCIS_0 (0*0x1000u) /* Capture input select: 0 - CCIxA */
#define CCIS_1 (1*0x1000u) /* Capture input select: 1 - CCIxB */
#define CCIS_2 (2*0x1000u) /* Capture input select: 2 - GND */
#define CCIS_3 (3*0x1000u) /* Capture input select: 3 - Vcc */
#define CM_0 (0*0x4000u) /* Capture mode: 0 - disabled */
#define CM_1 (1*0x4000u) /* Capture mode: 1 - pos. edge */
#define CM_2 (2*0x4000u) /* Capture mode: 1 - neg. edge */
#define CM_3 (3*0x4000u) /* Capture mode: 1 - both edges */
/* TA3IV Definitions */
#define TAIV_NONE (0x0000u) /* No Interrupt pending */
#define TAIV_TACCR1 (0x0002u) /* TACCR1_CCIFG */
#define TAIV_TACCR2 (0x0004u) /* TACCR2_CCIFG */
#define TAIV_6 (0x0006u) /* Reserved */
#define TAIV_8 (0x0008u) /* Reserved */
#define TAIV_TAIFG (0x000Au) /* TAIFG */
#define TA0IV_NONE (0x0000u) /* No Interrupt pending */
#define TA0IV_TACCR1 (0x0002u) /* TA0CCR1_CCIFG */
#define TA0IV_TACCR2 (0x0004u) /* TA0CCR2_CCIFG */
#define TA0IV_6 (0x0006u) /* Reserved */
#define TA0IV_8 (0x0008u) /* Reserved */
#define TA0IV_TAIFG (0x000Au) /* TA0IFG */
* Timer B7
#define __MSP430_HAS_TB7__ /* Definition to show that Module is available */
#define TBIV_ (0x011Eu) /* Timer B Interrupt Vector Word */
READ_ONLY DEFW( TBIV , TBIV_)
#define TBCTL_ (0x0180u) /* Timer B Control */
DEFW( TBCTL , TBCTL_)
#define TBCCTL0_ (0x0182u) /* Timer B Capture/Compare Control 0 */
DEFW( TBCCTL0 , TBCCTL0_)
#define TBCCTL1_ (0x0184u) /* Timer B Capture/Compare Control 1 */
DEFW( TBCCTL1 , TBCCTL1_)
#define TBCCTL2_ (0x0186u) /* Timer B Capture/Compare Control 2 */
DEFW( TBCCTL2 , TBCCTL2_)
#define TBCCTL3_ (0x0188u) /* Timer B Capture/Compare Control 3 */
DEFW( TBCCTL3 , TBCCTL3_)
#define TBCCTL4_ (0x018Au) /* Timer B Capture/Compare Control 4 */
DEFW( TBCCTL4 , TBCCTL4_)
#define TBCCTL5_ (0x018Cu) /* Timer B Capture/Compare Control 5 */
DEFW( TBCCTL5 , TBCCTL5_)
#define TBCCTL6_ (0x018Eu) /* Timer B Capture/Compare Control 6 */
DEFW( TBCCTL6 , TBCCTL6_)
#define TBR_ (0x0190u) /* Timer B Counter Register */
DEFW( TBR , TBR_)
#define TBCCR0_ (0x0192u) /* Timer B Capture/Compare 0 */
DEFW( TBCCR0 , TBCCR0_)
#define TBCCR1_ (0x0194u) /* Timer B Capture/Compare 1 */
DEFW( TBCCR1 , TBCCR1_)
#define TBCCR2_ (0x0196u) /* Timer B Capture/Compare 2 */
DEFW( TBCCR2 , TBCCR2_)
#define TBCCR3_ (0x0198u) /* Timer B Capture/Compare 3 */
DEFW( TBCCR3 , TBCCR3_)
#define TBCCR4_ (0x019Au) /* Timer B Capture/Compare 4 */
DEFW( TBCCR4 , TBCCR4_)
#define TBCCR5_ (0x019Cu) /* Timer B Capture/Compare 5 */
DEFW( TBCCR5 , TBCCR5_)
#define TBCCR6_ (0x019Eu) /* Timer B Capture/Compare 6 */
DEFW( TBCCR6 , TBCCR6_)
#define TB0IV TBIV /* Timer B Interrupt Vector Word */
#define TB0CTL TBCTL /* Timer B Control */
#define TB0CCTL0 TBCCTL0 /* Timer B Capture/Compare Control 0 */
#define TB0CCTL1 TBCCTL1 /* Timer B Capture/Compare Control 1 */
#define TB0CCTL2 TBCCTL2 /* Timer B Capture/Compare Control 2 */
#define TB0CCTL3 TBCCTL3 /* Timer B Capture/Compare Control 3 */
#define TB0CCTL4 TBCCTL4 /* Timer B Capture/Compare Control 4 */
#define TB0CCTL5 TBCCTL5 /* Timer B Capture/Compare Control 5 */
#define TB0CCTL6 TBCCTL6 /* Timer B Capture/Compare Control 6 */
#define TB0R TBR /* Timer B Counter Register */
#define TB0CCR0 TBCCR0 /* Timer B Capture/Compare 0 */
#define TB0CCR1 TBCCR1 /* Timer B Capture/Compare 1 */
#define TB0CCR2 TBCCR2 /* Timer B Capture/Compare 2 */
#define TB0CCR3 TBCCR3 /* Timer B Capture/Compare 3 */
#define TB0CCR4 TBCCR4 /* Timer B Capture/Compare 4 */
#define TB0CCR5 TBCCR5 /* Timer B Capture/Compare 5 */
#define TB0CCR6 TBCCR6 /* Timer B Capture/Compare 6 */
#define TB0IV_ TBIV_ /* Timer B Interrupt Vector Word */
#define TB0CTL_ TBCTL_ /* Timer B Control */
#define TB0CCTL0_ TBCCTL0_ /* Timer B Capture/Compare Control 0 */
#define TB0CCTL1_ TBCCTL1_ /* Timer B Capture/Compare Control 1 */
#define TB0CCTL2_ TBCCTL2_ /* Timer B Capture/Compare Control 2 */
#define TB0CCTL3_ TBCCTL3_ /* Timer B Capture/Compare Control 3 */
#define TB0CCTL4_ TBCCTL4_ /* Timer B Capture/Compare Control 4 */
#define TB0CCTL5_ TBCCTL5_ /* Timer B Capture/Compare Control 5 */
#define TB0CCTL6_ TBCCTL6_ /* Timer B Capture/Compare Control 6 */
#define TB0R_ TBR_ /* Timer B Counter Register */
#define TB0CCR0_ TBCCR0_ /* Timer B Capture/Compare 0 */
#define TB0CCR1_ TBCCR1_ /* Timer B Capture/Compare 1 */
#define TB0CCR2_ TBCCR2_ /* Timer B Capture/Compare 2 */
#define TB0CCR3_ TBCCR3_ /* Timer B Capture/Compare 3 */
#define TB0CCR4_ TBCCR4_ /* Timer B Capture/Compare 4 */
#define TB0CCR5_ TBCCR5_ /* Timer B Capture/Compare 5 */
#define TB0CCR6_ TBCCR6_ /* Timer B Capture/Compare 6 */
#define TIMER0_B1_VECTOR TIMERB1_VECTOR /* Int. Vector: Timer B CC1-6, TB */
#define TIMER0_B0_VECTOR TIMERB0_VECTOR /* Int. Vector: Timer B CC0 */
#define TBCLGRP1 (0x4000u) /* Timer B Compare latch load group 1 */
#define TBCLGRP0 (0x2000u) /* Timer B Compare latch load group 0 */
#define CNTL1 (0x1000u) /* Counter lenght 1 */
#define CNTL0 (0x0800u) /* Counter lenght 0 */
#define TBSSEL1 (0x0200u) /* Clock source 1 */
#define TBSSEL0 (0x0100u) /* Clock source 0 */
#define TBCLR (0x0004u) /* Timer B counter clear */
#define TBIE (0x0002u) /* Timer B interrupt enable */
#define TBIFG (0x0001u) /* Timer B interrupt flag */
#define SHR1 (0x4000u) /* Timer B Compare latch load group 1 */
#define SHR0 (0x2000u) /* Timer B Compare latch load group 0 */
#define TBSSEL_0 (0*0x0100u) /* Clock Source: TBCLK */
#define TBSSEL_1 (1*0x0100u) /* Clock Source: ACLK */
#define TBSSEL_2 (2*0x0100u) /* Clock Source: SMCLK */
#define TBSSEL_3 (3*0x0100u) /* Clock Source: INCLK */
#define CNTL_0 (0*0x0800u) /* Counter lenght: 16 bit */
#define CNTL_1 (1*0x0800u) /* Counter lenght: 12 bit */
#define CNTL_2 (2*0x0800u) /* Counter lenght: 10 bit */
#define CNTL_3 (3*0x0800u) /* Counter lenght: 8 bit */
#define SHR_0 (0*0x2000u) /* Timer B Group: 0 - individually */
#define SHR_1 (1*0x2000u) /* Timer B Group: 1 - 3 groups (1-2, 3-4, 5-6) */
#define SHR_2 (2*0x2000u) /* Timer B Group: 2 - 2 groups (1-3, 4-6)*/
#define SHR_3 (3*0x2000u) /* Timer B Group: 3 - 1 group (all) */
#define TBCLGRP_0 (0*0x2000u) /* Timer B Group: 0 - individually */
#define TBCLGRP_1 (1*0x2000u) /* Timer B Group: 1 - 3 groups (1-2, 3-4, 5-6) */
#define TBCLGRP_2 (2*0x2000u) /* Timer B Group: 2 - 2 groups (1-3, 4-6)*/
#define TBCLGRP_3 (3*0x2000u) /* Timer B Group: 3 - 1 group (all) */
/* Additional Timer B Control Register bits are defined in Timer A */
#define CLLD1 (0x0400u) /* Compare latch load source 1 */
#define CLLD0 (0x0200u) /* Compare latch load source 0 */
#define SLSHR1 (0x0400u) /* Compare latch load source 1 */
#define SLSHR0 (0x0200u) /* Compare latch load source 0 */
#define SLSHR_0 (0*0x0200u) /* Compare latch load sourec : 0 - immediate */
#define SLSHR_1 (1*0x0200u) /* Compare latch load sourec : 1 - TBR counts to 0 */
#define SLSHR_2 (2*0x0200u) /* Compare latch load sourec : 2 - up/down */
#define SLSHR_3 (3*0x0200u) /* Compare latch load sourec : 3 - TBR counts to TBCTL0 */
#define CLLD_0 (0*0x0200u) /* Compare latch load sourec : 0 - immediate */
#define CLLD_1 (1*0x0200u) /* Compare latch load sourec : 1 - TBR counts to 0 */
#define CLLD_2 (2*0x0200u) /* Compare latch load sourec : 2 - up/down */
#define CLLD_3 (3*0x0200u) /* Compare latch load sourec : 3 - TBR counts to TBCTL0 */
/* TB7IV Definitions */
#define TBIV_NONE (0x0000u) /* No Interrupt pending */
#define TBIV_TBCCR1 (0x0002u) /* TBCCR1_CCIFG */
#define TBIV_TBCCR2 (0x0004u) /* TBCCR2_CCIFG */
#define TBIV_TBCCR3 (0x0006u) /* TBCCR3_CCIFG */
#define TBIV_TBCCR4 (0x0008u) /* TBCCR4_CCIFG */
#define TBIV_TBCCR5 (0x000Au) /* TBCCR3_CCIFG */
#define TBIV_TBCCR6 (0x000Cu) /* TBCCR4_CCIFG */
#define TBIV_TBIFG (0x000Eu) /* TBIFG */
#define TB0IV_NONE (0x0000u) /* No Interrupt pending */
#define TB0IV_TBCCR1 (0x0002u) /* TB0CCR1_CCIFG */
#define TB0IV_TBCCR2 (0x0004u) /* TB0CCR2_CCIFG */
#define TB0IV_TBCCR3 (0x0006u) /* TB0CCR3_CCIFG */
#define TB0IV_TBCCR4 (0x0008u) /* TB0CCR4_CCIFG */
#define TB0IV_TBCCR5 (0x000Au) /* TB0CCR3_CCIFG */
#define TB0IV_TBCCR6 (0x000Cu) /* TB0CCR4_CCIFG */
#define TB0IV_TBIFG (0x000Eu) /* TB0IFG */
* USCI
#define __MSP430_HAS_USCI__ /* Definition to show that Module is available */
#define __MSP430_HAS_USCI_AB0__ /* Definition to show that Module is available */
#define __MSP430_HAS_USCI_AB1__ /* Definition to show that Module is available */
#define UCA0CTL0_ (0x0060u) /* USCI A0 Control Register 0 */
DEFC( UCA0CTL0 , UCA0CTL0_)
#define UCA0CTL1_ (0x0061u) /* USCI A0 Control Register 1 */
DEFC( UCA0CTL1 , UCA0CTL1_)
#define UCA0BR0_ (0x0062u) /* USCI A0 Baud Rate 0 */
DEFC( UCA0BR0 , UCA0BR0_)
#define UCA0BR1_ (0x0063u) /* USCI A0 Baud Rate 1 */
DEFC( UCA0BR1 , UCA0BR1_)
#define UCA0MCTL_ (0x0064u) /* USCI A0 Modulation Control */
DEFC( UCA0MCTL , UCA0MCTL_)
#define UCA0STAT_ (0x0065u) /* USCI A0 Status Register */
DEFC( UCA0STAT , UCA0STAT_)
#define UCA0RXBUF_ (0x0066u) /* USCI A0 Receive Buffer */
READ_ONLY DEFC( UCA0RXBUF , UCA0RXBUF_)
#define UCA0TXBUF_ (0x0067u) /* USCI A0 Transmit Buffer */
DEFC( UCA0TXBUF , UCA0TXBUF_)
#define UCA0ABCTL_ (0x005Du) /* USCI A0 LIN Control */
DEFC( UCA0ABCTL , UCA0ABCTL_)
#define UCA0IRTCTL_ (0x005Eu) /* USCI A0 IrDA Transmit Control */
DEFC( UCA0IRTCTL , UCA0IRTCTL_)
#define UCA0IRRCTL_ (0x005Fu) /* USCI A0 IrDA Receive Control */
DEFC( UCA0IRRCTL , UCA0IRRCTL_)
#define UCB0CTL0_ (0x0068u) /* USCI B0 Control Register 0 */
DEFC( UCB0CTL0 , UCB0CTL0_)
#define UCB0CTL1_ (0x0069u) /* USCI B0 Control Register 1 */
DEFC( UCB0CTL1 , UCB0CTL1_)
#define UCB0BR0_ (0x006Au) /* USCI B0 Baud Rate 0 */
DEFC( UCB0BR0 , UCB0BR0_)
#define UCB0BR1_ (0x006Bu) /* USCI B0 Baud Rate 1 */
DEFC( UCB0BR1 , UCB0BR1_)
#define UCB0I2CIE_ (0x006Cu) /* USCI B0 I2C Interrupt Enable Register */
DEFC( UCB0I2CIE , UCB0I2CIE_)
#define UCB0STAT_ (0x006Du) /* USCI B0 Status Register */
DEFC( UCB0STAT , UCB0STAT_)
#define UCB0RXBUF_ (0x006Eu) /* USCI B0 Receive Buffer */
READ_ONLY DEFC( UCB0RXBUF , UCB0RXBUF_)
#define UCB0TXBUF_ (0x006Fu) /* USCI B0 Transmit Buffer */
DEFC( UCB0TXBUF , UCB0TXBUF_)
#define UCB0I2COA_ (0x0118u) /* USCI B0 I2C Own Address */
DEFW( UCB0I2COA , UCB0I2COA_)
#define UCB0I2CSA_ (0x011Au) /* USCI B0 I2C Slave Address */
DEFW( UCB0I2CSA , UCB0I2CSA_)
#define UCA1CTL0_ (0x00D0u) /* USCI A1 Control Register 0 */
DEFC( UCA1CTL0 , UCA1CTL0_)
#define UCA1CTL1_ (0x00D1u) /* USCI A1 Control Register 1 */
DEFC( UCA1CTL1 , UCA1CTL1_)
#define UCA1BR0_ (0x00D2u) /* USCI A1 Baud Rate 0 */
DEFC( UCA1BR0 , UCA1BR0_)
#define UCA1BR1_ (0x00D3u) /* USCI A1 Baud Rate 1 */
DEFC( UCA1BR1 , UCA1BR1_)
#define UCA1MCTL_ (0x00D4u) /* USCI A1 Modulation Control */
DEFC( UCA1MCTL , UCA1MCTL_)
#define UCA1STAT_ (0x00D5u) /* USCI A1 Status Register */
DEFC( UCA1STAT , UCA1STAT_)
#define UCA1RXBUF_ (0x00D6u) /* USCI A1 Receive Buffer */
READ_ONLY DEFC( UCA1RXBUF , UCA1RXBUF_)
#define UCA1TXBUF_ (0x00D7u) /* USCI A1 Transmit Buffer */
DEFC( UCA1TXBUF , UCA1TXBUF_)
#define UCA1ABCTL_ (0x00CDu) /* USCI A1 LIN Control */
DEFC( UCA1ABCTL , UCA1ABCTL_)
#define UCA1IRTCTL_ (0x00CEu) /* USCI A1 IrDA Transmit Control */
DEFC( UCA1IRTCTL , UCA1IRTCTL_)
#define UCA1IRRCTL_ (0x00CFu) /* USCI A1 IrDA Receive Control */
DEFC( UCA1IRRCTL , UCA1IRRCTL_)
#define UCB1CTL0_ (0x00D8u) /* USCI B1 Control Register 0 */
DEFC( UCB1CTL0 , UCB1CTL0_)
#define UCB1CTL1_ (0x00D9u) /* USCI B1 Control Register 1 */
DEFC( UCB1CTL1 , UCB1CTL1_)
#define UCB1BR0_ (0x00DAu) /* USCI B1 Baud Rate 0 */
DEFC( UCB1BR0 , UCB1BR0_)
#define UCB1BR1_ (0x00DBu) /* USCI B1 Baud Rate 1 */
DEFC( UCB1BR1 , UCB1BR1_)
#define UCB1I2CIE_ (0x00DCu) /* USCI B1 I2C Interrupt Enable Register */
DEFC( UCB1I2CIE , UCB1I2CIE_)
#define UCB1STAT_ (0x00DDu) /* USCI B1 Status Register */
DEFC( UCB1STAT , UCB1STAT_)
#define UCB1RXBUF_ (0x00DEu) /* USCI B1 Receive Buffer */
READ_ONLY DEFC( UCB1RXBUF , UCB1RXBUF_)
#define UCB1TXBUF_ (0x00DFu) /* USCI B1 Transmit Buffer */
DEFC( UCB1TXBUF , UCB1TXBUF_)
#define UCB1I2COA_ (0x017Cu) /* USCI B1 I2C Own Address */
DEFW( UCB1I2COA , UCB1I2COA_)
#define UCB1I2CSA_ (0x017Eu) /* USCI B1 I2C Slave Address */
DEFW( UCB1I2CSA , UCB1I2CSA_)
// UART-Mode Bits
#define UCPEN (0x80) /* Async. Mode: Parity enable */
#define UCPAR (0x40) /* Async. Mode: Parity 0:odd / 1:even */
#define UCMSB (0x20) /* Async. Mode: MSB first 0:LSB / 1:MSB */
#define UC7BIT (0x10) /* Async. Mode: Data Bits 0:8-bits / 1:7-bits */
#define UCSPB (0x08) /* Async. Mode: Stop Bits 0:one / 1: two */
#define UCMODE1 (0x04) /* Async. Mode: USCI Mode 1 */
#define UCMODE0 (0x02) /* Async. Mode: USCI Mode 0 */
#define UCSYNC (0x01) /* Sync-Mode 0:UART-Mode / 1:SPI-Mode */
// SPI-Mode Bits
#define UCCKPH (0x80) /* Sync. Mode: Clock Phase */
#define UCCKPL (0x40) /* Sync. Mode: Clock Polarity */
#define UCMST (0x08) /* Sync. Mode: Master Select */
// I2C-Mode Bits
#define UCA10 (0x80) /* 10-bit Address Mode */
#define UCSLA10 (0x40) /* 10-bit Slave Address Mode */
#define UCMM (0x20) /* Multi-Master Environment */
//#define res (0x10) /* reserved */
#define UCMODE_0 (0x00) /* Sync. Mode: USCI Mode: 0 */
#define UCMODE_1 (0x02) /* Sync. Mode: USCI Mode: 1 */
#define UCMODE_2 (0x04) /* Sync. Mode: USCI Mode: 2 */
#define UCMODE_3 (0x06) /* Sync. Mode: USCI Mode: 3 */
// UART-Mode Bits
#define UCSSEL1 (0x80) /* USCI 0 Clock Source Select 1 */
#define UCSSEL0 (0x40) /* USCI 0 Clock Source Select 0 */
#define UCRXEIE (0x20) /* RX Error interrupt enable */
#define UCBRKIE (0x10) /* Break interrupt enable */
#define UCDORM (0x08) /* Dormant (Sleep) Mode */
#define UCTXADDR (0x04) /* Send next Data as Address */
#define UCTXBRK (0x02) /* Send next Data as Break */
#define UCSWRST (0x01) /* USCI Software Reset */
// SPI-Mode Bits
//#define res (0x20) /* reserved */
//#define res (0x08) /* reserved */
//#define res (0x04) /* reserved */
//#define res (0x02) /* reserved */
// I2C-Mode Bits
#define UCTR (0x10) /* Transmit/Receive Select/Flag */
#define UCTXNACK (0x08) /* Transmit NACK */
#define UCTXSTP (0x04) /* Transmit STOP */
#define UCTXSTT (0x02) /* Transmit START */
#define UCSSEL_0 (0x00) /* USCI 0 Clock Source: 0 */
#define UCSSEL_1 (0x40) /* USCI 0 Clock Source: 1 */
#define UCSSEL_2 (0x80) /* USCI 0 Clock Source: 2 */
#define UCSSEL_3 (0xC0) /* USCI 0 Clock Source: 3 */
#define UCBRF3 (0x80) /* USCI First Stage Modulation Select 3 */
#define UCBRF2 (0x40) /* USCI First Stage Modulation Select 2 */
#define UCBRF1 (0x20) /* USCI First Stage Modulation Select 1 */
#define UCBRF0 (0x10) /* USCI First Stage Modulation Select 0 */
#define UCBRS2 (0x08) /* USCI Second Stage Modulation Select 2 */
#define UCBRS1 (0x04) /* USCI Second Stage Modulation Select 1 */
#define UCBRS0 (0x02) /* USCI Second Stage Modulation Select 0 */
#define UCOS16 (0x01) /* USCI 16-times Oversampling enable */
#define UCBRF_0 (0x00) /* USCI First Stage Modulation: 0 */
#define UCBRF_1 (0x10) /* USCI First Stage Modulation: 1 */
#define UCBRF_2 (0x20) /* USCI First Stage Modulation: 2 */
#define UCBRF_3 (0x30) /* USCI First Stage Modulation: 3 */
#define UCBRF_4 (0x40) /* USCI First Stage Modulation: 4 */
#define UCBRF_5 (0x50) /* USCI First Stage Modulation: 5 */
#define UCBRF_6 (0x60) /* USCI First Stage Modulation: 6 */
#define UCBRF_7 (0x70) /* USCI First Stage Modulation: 7 */
#define UCBRF_8 (0x80) /* USCI First Stage Modulation: 8 */
#define UCBRF_9 (0x90) /* USCI First Stage Modulation: 9 */
#define UCBRF_10 (0xA0) /* USCI First Stage Modulation: A */
#define UCBRF_11 (0xB0) /* USCI First Stage Modulation: B */
#define UCBRF_12 (0xC0) /* USCI First Stage Modulation: C */
#define UCBRF_13 (0xD0) /* USCI First Stage Modulation: D */
#define UCBRF_14 (0xE0) /* USCI First Stage Modulation: E */
#define UCBRF_15 (0xF0) /* USCI First Stage Modulation: F */
#define UCBRS_0 (0x00) /* USCI Second Stage Modulation: 0 */
#define UCBRS_1 (0x02) /* USCI Second Stage Modulation: 1 */
#define UCBRS_2 (0x04) /* USCI Second Stage Modulation: 2 */
#define UCBRS_3 (0x06) /* USCI Second Stage Modulation: 3 */
#define UCBRS_4 (0x08) /* USCI Second Stage Modulation: 4 */
#define UCBRS_5 (0x0A) /* USCI Second Stage Modulation: 5 */
#define UCBRS_6 (0x0C) /* USCI Second Stage Modulation: 6 */
#define UCBRS_7 (0x0E) /* USCI Second Stage Modulation: 7 */
#define UCLISTEN (0x80) /* USCI Listen mode */
#define UCFE (0x40) /* USCI Frame Error Flag */
#define UCOE (0x20) /* USCI Overrun Error Flag */
#define UCPE (0x10) /* USCI Parity Error Flag */
#define UCBRK (0x08) /* USCI Break received */
#define UCRXERR (0x04) /* USCI RX Error Flag */
#define UCADDR (0x02) /* USCI Address received Flag */
#define UCBUSY (0x01) /* USCI Busy Flag */
#define UCIDLE (0x02) /* USCI Idle line detected Flag */
//#define res (0x80) /* reserved */
//#define res (0x40) /* reserved */
#define UCNACKIE (0x08) /* NACK Condition interrupt enable */
#define UCSTPIE (0x04) /* STOP Condition interrupt enable */
#define UCSTTIE (0x02) /* START Condition interrupt enable */
#define UCALIE (0x01) /* Arbitration Lost interrupt enable */
#define UCSCLLOW (0x40) /* SCL low */
#define UCGC (0x20) /* General Call address received Flag */
#define UCBBUSY (0x10) /* Bus Busy Flag */
#define UCNACKIFG (0x08) /* NAK Condition interrupt Flag */
#define UCSTPIFG (0x04) /* STOP Condition interrupt Flag */
#define UCSTTIFG (0x02) /* START Condition interrupt Flag */
#define UCALIFG (0x01) /* Arbitration Lost interrupt Flag */
#define UCIRTXPL5 (0x80) /* IRDA Transmit Pulse Length 5 */
#define UCIRTXPL4 (0x40) /* IRDA Transmit Pulse Length 4 */
#define UCIRTXPL3 (0x20) /* IRDA Transmit Pulse Length 3 */
#define UCIRTXPL2 (0x10) /* IRDA Transmit Pulse Length 2 */
#define UCIRTXPL1 (0x08) /* IRDA Transmit Pulse Length 1 */
#define UCIRTXPL0 (0x04) /* IRDA Transmit Pulse Length 0 */
#define UCIRTXCLK (0x02) /* IRDA Transmit Pulse Clock Select */
#define UCIREN (0x01) /* IRDA Encoder/Decoder enable */
#define UCIRRXFL5 (0x80) /* IRDA Receive Filter Length 5 */
#define UCIRRXFL4 (0x40) /* IRDA Receive Filter Length 4 */
#define UCIRRXFL3 (0x20) /* IRDA Receive Filter Length 3 */
#define UCIRRXFL2 (0x10) /* IRDA Receive Filter Length 2 */
#define UCIRRXFL1 (0x08) /* IRDA Receive Filter Length 1 */
#define UCIRRXFL0 (0x04) /* IRDA Receive Filter Length 0 */
#define UCIRRXPL (0x02) /* IRDA Receive Input Polarity */
#define UCIRRXFE (0x01) /* IRDA Receive Filter enable */
#define UCDELIM1 (0x20) /* Break Sync Delimiter 1 */
#define UCDELIM0 (0x10) /* Break Sync Delimiter 0 */
#define UCSTOE (0x08) /* Sync-Field Timeout error */
#define UCBTOE (0x04) /* Break Timeout error */
#define UCABDEN (0x01) /* Auto Baud Rate detect enable */
#define UCGCEN (0x8000u) /* I2C General Call enable */
#define UCOA9 (0x0200u) /* I2C Own Address 9 */
#define UCOA8 (0x0100u) /* I2C Own Address 8 */
#define UCOA7 (0x0080u) /* I2C Own Address 7 */
#define UCOA6 (0x0040u) /* I2C Own Address 6 */
#define UCOA5 (0x0020u) /* I2C Own Address 5 */
#define UCOA4 (0x0010u) /* I2C Own Address 4 */
#define UCOA3 (0x0008u) /* I2C Own Address 3 */
#define UCOA2 (0x0004u) /* I2C Own Address 2 */
#define UCOA1 (0x0002u) /* I2C Own Address 1 */
#define UCOA0 (0x0001u) /* I2C Own Address 0 */
#define UCSA9 (0x0200u) /* I2C Slave Address 9 */
#define UCSA8 (0x0100u) /* I2C Slave Address 8 */
#define UCSA7 (0x0080u) /* I2C Slave Address 7 */
#define UCSA6 (0x0040u) /* I2C Slave Address 6 */
#define UCSA5 (0x0020u) /* I2C Slave Address 5 */
#define UCSA4 (0x0010u) /* I2C Slave Address 4 */
#define UCSA3 (0x0008u) /* I2C Slave Address 3 */
#define UCSA2 (0x0004u) /* I2C Slave Address 2 */
#define UCSA1 (0x0002u) /* I2C Slave Address 1 */
#define UCSA0 (0x0001u) /* I2C Slave Address 0 */
* WATCHDOG TIMER
#define __MSP430_HAS_WDT__ /* Definition to show that Module is available */
#define WDTCTL_ (0x0120u) /* Watchdog Timer Control */
DEFW( WDTCTL , WDTCTL_)
/* The bit names have been prefixed with "WDT" */
#define WDTIS0 (0x0001u)
#define WDTIS1 (0x0002u)
#define WDTSSEL (0x0004u)
#define WDTCNTCL (0x0008u)
#define WDTTMSEL (0x0010u)
#define WDTNMI (0x0020u)
#define WDTNMIES (0x0040u)
#define WDTHOLD (0x0080u)
#define WDTPW (0x5A00u)
/* WDT-interval times [1ms] coded with Bits 0-2 */
/* WDT is clocked by fSMCLK (assumed 1MHz) */
#define WDT_MDLY_32 (WDTPW+WDTTMSEL+WDTCNTCL) /* 32ms interval (default) */
#define WDT_MDLY_8 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS0) /* 8ms " */
#define WDT_MDLY_0_5 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1) /* 0.5ms " */
#define WDT_MDLY_0_064 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms " */
/* WDT is clocked by fACLK (assumed 32KHz) */
#define WDT_ADLY_1000 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL) /* 1000ms " */
#define WDT_ADLY_250 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms " */
#define WDT_ADLY_16 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms " */
#define WDT_ADLY_1_9 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms " */
/* Watchdog mode -> reset after expired time */
#define WDT_MRST_32 (WDTPW+WDTCNTCL) /* 32ms interval (default) */
#define WDT_MRST_8 (WDTPW+WDTCNTCL+WDTIS0) /* 8ms " */
#define WDT_MRST_0_5 (WDTPW+WDTCNTCL+WDTIS1) /* 0.5ms " */
#define WDT_MRST_0_064 (WDTPW+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms " */
#define WDT_ARST_1000 (WDTPW+WDTCNTCL+WDTSSEL) /* 1000ms " */
#define WDT_ARST_250 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms " */
#define WDT_ARST_16 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms " */
#define WDT_ARST_1_9 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms " */
/* INTERRUPT CONTROL */
/* These two bits are defined in the Special Function Registers */
/* #define WDTIE 0x01 */
/* #define WDTIFG 0x01 */
* Calibration Data in Info Mem
/* TLV Calibration Data Structure */
#define TAG_DCO_30 (0x01) /* Tag for DCO30 Calibration Data */
#define TAG_ADC12_1 (0x08) /* Tag for ADC12_1 Calibration Data */
#define TAG_EMPTY (0xFE) /* Tag for Empty Data Field in Calibration Data */
#ifndef __DisableCalData
#define TLV_CHECKSUM_ (0x10C0u) /* TLV CHECK SUM */
READ_ONLY DEFW( TLV_CHECKSUM , TLV_CHECKSUM_)
#define TLV_DCO_30_TAG_ (0x10F6u) /* TLV TAG_DCO30 TAG */
READ_ONLY DEFC( TLV_DCO_30_TAG , TLV_DCO_30_TAG_)
#define TLV_DCO_30_LEN_ (0x10F7u) /* TLV TAG_DCO30 LEN */
READ_ONLY DEFC( TLV_DCO_30_LEN , TLV_DCO_30_LEN_)
#define TLV_ADC12_1_TAG_ (0x10DAu) /* TLV ADC12_1 TAG */
READ_ONLY DEFC( TLV_ADC12_1_TAG , TLV_ADC12_1_TAG_)
#define TLV_ADC12_1_LEN_ (0x10DBu) /* TLV ADC12_1 LEN */
READ_ONLY DEFC( TLV_ADC12_1_LEN , TLV_ADC12_1_LEN_)
#endif
#define CAL_ADC_25T85 (0x0007u) /* Index for 2.5V/85Deg Cal. Value */
#define CAL_ADC_25T30 (0x0006u) /* Index for 2.5V/30Deg Cal. Value */
#define CAL_ADC_25VREF_FACTOR (0x0005u) /* Index for 2.5V Ref. Factor */
#define CAL_ADC_15T85 (0x0004u) /* Index for 1.5V/85Deg Cal. Value */
#define CAL_ADC_15T30 (0x0003u) /* Index for 1.5V/30Deg Cal. Value */
#define CAL_ADC_15VREF_FACTOR (0x0002u) /* Index for ADC 1.5V Ref. Factor */
#define CAL_ADC_OFFSET (0x0001u) /* Index for ADC Offset */
#define CAL_ADC_GAIN_FACTOR (0x0000u) /* Index for ADC Gain Factor */
#define CAL_DCO_16MHZ (0x0000u) /* Index for DCOCTL Calibration Data for 16MHz */
#define CAL_BC1_16MHZ (0x0001u) /* Index for BCSCTL1 Calibration Data for 16MHz */
#define CAL_DCO_12MHZ (0x0002u) /* Index for DCOCTL Calibration Data for 12MHz */
#define CAL_BC1_12MHZ (0x0003u) /* Index for BCSCTL1 Calibration Data for 12MHz */
#define CAL_DCO_8MHZ (0x0004u) /* Index for DCOCTL Calibration Data for 8MHz */
#define CAL_BC1_8MHZ (0x0005u) /* Index for BCSCTL1 Calibration Data for 8MHz */
#define CAL_DCO_1MHZ (0x0006u) /* Index for DCOCTL Calibration Data for 1MHz */
#define CAL_BC1_1MHZ (0x0007u) /* Index for BCSCTL1 Calibration Data for 1MHz */
#define CALDCO_16MHZ_ (0x10F8u) /* DCOCTL Calibration Data for 16MHz */
READ_ONLY DEFC( CALDCO_16MHZ , CALDCO_16MHZ_)
#define CALBC1_16MHZ_ (0x10F9u) /* BCSCTL1 Calibration Data for 16MHz */
READ_ONLY DEFC( CALBC1_16MHZ , CALBC1_16MHZ_)
#define CALDCO_12MHZ_ (0x10FAu) /* DCOCTL Calibration Data for 12MHz */
READ_ONLY DEFC( CALDCO_12MHZ , CALDCO_12MHZ_)
#define CALBC1_12MHZ_ (0x10FBu) /* BCSCTL1 Calibration Data for 12MHz */
READ_ONLY DEFC( CALBC1_12MHZ , CALBC1_12MHZ_)
#define CALDCO_8MHZ_ (0x10FCu) /* DCOCTL Calibration Data for 8MHz */
READ_ONLY DEFC( CALDCO_8MHZ , CALDCO_8MHZ_)
#define CALBC1_8MHZ_ (0x10FDu) /* BCSCTL1 Calibration Data for 8MHz */
READ_ONLY DEFC( CALBC1_8MHZ , CALBC1_8MHZ_)
#define CALDCO_1MHZ_ (0x10FEu) /* DCOCTL Calibration Data for 1MHz */
READ_ONLY DEFC( CALDCO_1MHZ , CALDCO_1MHZ_)
#define CALBC1_1MHZ_ (0x10FFu) /* BCSCTL1 Calibration Data for 1MHz */
READ_ONLY DEFC( CALBC1_1MHZ , CALBC1_1MHZ_)
#endif /* #ifndef __DisableCalData */
* Interrupt Vectors (offset from 0xFFC0)
#define RESERVED0_VECTOR (0 * 2u) /* 0xFFC0 Reserved Int. Vector 0 */
#define RESERVED1_VECTOR (1 * 2u) /* 0xFFC2 Reserved Int. Vector 1 */
#define RESERVED2_VECTOR (2 * 2u) /* 0xFFC4 Reserved Int. Vector 2 */
#define RESERVED3_VECTOR (3 * 2u) /* 0xFFC6 Reserved Int. Vector 3 */
#define RESERVED4_VECTOR (4 * 2u) /* 0xFFC8 Reserved Int. Vector 4 */
#define RESERVED5_VECTOR (5 * 2u) /* 0xFFCA Reserved Int. Vector 5 */
#define RESERVED6_VECTOR (6 * 2u) /* 0xFFCC Reserved Int. Vector 6 */
#define RESERVED7_VECTOR (7 * 2u) /* 0xFFCE Reserved Int. Vector 7 */
#define RESERVED8_VECTOR (8 * 2u) /* 0xFFD0 Reserved Int. Vector 8 */
#define RESERVED9_VECTOR (9 * 2u) /* 0xFFD2 Reserved Int. Vector 9 */
#define RESERVED10_VECTOR (10 * 2u) /* 0xFFD4 Reserved Int. Vector 10 */
#define RESERVED11_VECTOR (11 * 2u) /* 0xFFD6 Reserved Int. Vector 11 */
#define RESERVED12_VECTOR (12 * 2u) /* 0xFFD8 Reserved Int. Vector 12 */
#define RESERVED13_VECTOR (13 * 2u) /* 0xFFDA Reserved Int. Vector 13 */
#define RESERVED14_VECTOR (14 * 2u) /* 0xFFDC Reserved Int. Vector 14 */
#define RESERVED15_VECTOR (15 * 2u) /* 0xFFDE Reserved Int. Vector 15 */
#define USCIAB1TX_VECTOR (16 * 2u) /* 0xFFE0 USCI A1/B1 Transmit */
#define USCIAB1RX_VECTOR (17 * 2u) /* 0xFFE2 USCI A1/B1 Receive */
#define PORT1_VECTOR (18 * 2u) /* 0xFFE4 Port 1 */
#define PORT2_VECTOR (19 * 2u) /* 0xFFE6 Port 2 */
#define RESERVED20_VECTOR (20 * 2u) /* 0xFFE8 Reserved Int. Vector 20 */
#define ADC12_VECTOR (21 * 2u) /* 0xFFEA ADC */
#define USCIAB0TX_VECTOR (22 * 2u) /* 0xFFEC USCI A0/B0 Transmit */
#define USCIAB0RX_VECTOR (23 * 2u) /* 0xFFEE USCI A0/B0 Receive */
#define TIMERA1_VECTOR (24 * 2u) /* 0xFFF0 Timer A CC1-2, TA */
#define TIMERA0_VECTOR (25 * 2u) /* 0xFFF2 Timer A CC0 */
#define WDT_VECTOR (26 * 2u) /* 0xFFF4 Watchdog Timer */
#define COMPARATORA_VECTOR (27 * 2u) /* 0xFFF6 Comparator A */
#define TIMERB1_VECTOR (28 * 2u) /* 0xFFF8 Timer B CC1-6, TB */
#define TIMERB0_VECTOR (29 * 2u) /* 0xFFFA Timer B CC0 */
#define NMI_VECTOR (30 * 2u) /* 0xFFFC Non-maskable */
#define RESET_VECTOR (31 * 2u) /* 0xFFFE Reset [Highest Priority] */
* End of Modules
#pragma language=default
#endif /* #ifndef __msp430x241x */
