some GPIOs output high level after boot up with nor flash.
After booting, some GPIOs will output high levels. But we did not set these pins in the code to output high levels. And these GPIOs output high levels are after nor flash content is loaded into the ram.
In the figure, the blue one is the output from the GPIO and the yellow one is the cs of nor flash.
Hi shaojie ma,
Thank you for the query!!
Can you let us know the below details:
If not can you please share the boot image/ application image?
Thanks & Regards,
Lydia
Hi,
May I ask if your problem has been resolved? Do you have any updates regarding this issue?
