Part Number: AM2432
Hello
I have a question to consult about MLINK and enhancedlink_mable.
1、If I select MLINK Based for MDIO Manual Mode Link Status Update in the syscfg configuration interface, is it necessary to enable enhancedlinkd_enable in the ethercat parameter initialization in the tiecsoc. c file, and why?
2、If I select PHY Polling Based for MDIO Manual Mode Link Status Update in the syscfg configuration interface, is it necessary to disable enhancedlinkd_enable in the ethercat parameter initialization in the tiecsoc. c file, and why?
In PHY Polling Based mode, What is the time from the establishment of phy link to the opening of ESC port, and what is the time from losing phy link to the closing of ESC port.
Thank you.
