如果要定时相应的时间定时器该怎么配置?
可以参考这个例程
// periodic_16bit.c - Example demonstrating a periodic 16-bit timer.
// Copyright (c) 2010-2015 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// This is part of revision 2.1.1.71 of the Tiva Firmware Development Package.
#include <stdbool.h>
#include <stdint.h>
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/pin_map.h"
#include "driverlib/sysctl.h"
#include "driverlib/timer.h"
#include "driverlib/uart.h"
#include "utils/uartstdio.h"
//! \addtogroup timer_examples_list
//! <h1>16-Bit Periodic Timer (periodic_16bit)</h1>
//! This example shows how to configure Timer0B as a periodic timer with an
//! interrupt triggering every 1ms. After a certain number of interrupts, the
//! Timer0B interrupt will be disabled.
//! This example uses the following peripherals and I/O signals. You must
//! review these and change as needed for your own board:
//! - TIMER0 peripheral
//! The following UART signals are configured only for displaying console
//! messages for this example. These are not required for operation of
//! Timer0.
//! - UART0 peripheral
//! - GPIO Port A peripheral (for UART0 pins)
//! - UART0RX - PA0
//! - UART0TX - PA1
//! This example uses the following interrupt handlers. To use this example
//! in your own application you must add these interrupt handlers to your
//! vector table.
//! - INT_TIMER0B - Timer0BIntHandler
// Number of interrupts before the timer gets turned off.
#define NUMBER_OF_INTS 1000
// Counter to count the number of interrupts that have been called.
static volatile uint32_t g_ui32Counter = 0;
// This function sets up UART0 to be used for a console to display information
// as the example is running.
void
InitConsole(void)
// Enable GPIO port A which is used for UART0 pins.
// TODO: change this to whichever GPIO port you are using.
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
// Configure the pin muxing for UART0 functions on port A0 and A1.
// This step is not necessary if your part does not support pin muxing.
// TODO: change this to select the port/pin you are using.
GPIOPinConfigure(GPIO_PA0_U0RX);
GPIOPinConfigure(GPIO_PA1_U0TX);
// Enable UART0 so that we can configure the clock.
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
// Use the internal 16MHz oscillator as the UART clock source.
UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC);
// Select the alternate (UART) function for these pins.
GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
// Initialize the UART for console I/O.
UARTStdioConfig(0, 115200, 16000000);
// The interrupt handler for the Timer0B interrupt.
void
Timer0BIntHandler(void)
// Clear the timer interrupt flag.
TimerIntClear(TIMER0_BASE, TIMER_TIMB_TIMEOUT);
// Update the periodic interrupt counter.
g_ui32Counter++;
// Once NUMBER_OF_INTS interrupts have been received, turn off the
// TIMER0B interrupt.
if(g_ui32Counter == NUMBER_OF_INTS)
// Disable the Timer0B interrupt.
IntDisable(INT_TIMER0B);
// Turn off Timer0B interrupt.
TimerIntDisable(TIMER0_BASE, TIMER_TIMB_TIMEOUT);
// Clear any pending interrupt flag.
// Configure Timer0B as a 16-bit periodic counter with an interrupt
// every 1ms.
int
main(void)
#if defined(TARGET_IS_TM4C129_RA0) || \
defined(TARGET_IS_TM4C129_RA1) || \
defined(TARGET_IS_TM4C129_RA2)
uint32_t ui32SysClock;
#endif
uint32_t ui32PrevCount = 0;
// Set the clocking to run directly from the external crystal/oscillator.
// TODO: The SYSCTL_XTAL_ value must be changed to match the value of the
// crystal on your board.
ui32SysClock = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
SYSCTL_OSC_MAIN |
SYSCTL_USE_OSC), 25000000);
#else
SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
SYSCTL_XTAL_16MHZ);
#endif
// The Timer0 peripheral must be enabled for use.
SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);
// Set up the serial console to use for displaying messages. This is
// just for this example program and is not needed for Timer operation.
InitConsole();
// Display the example setup on the console.
UARTprintf("16-Bit Timer Interrupt ->");
UARTprintf("\n Timer = Timer0B");
UARTprintf("\n Mode = Periodic");
UARTprintf("\n Number of interrupts = %d", NUMBER_OF_INTS);
UARTprintf("\n Rate = 1ms\n\n");
// Configure Timer0B as a 16-bit periodic timer.
TimerConfigure(TIMER0_BASE, TIMER_CFG_SPLIT_PAIR | TIMER_CFG_B_PERIODIC);
// Set the Timer0B load value to 1ms.
TimerLoadSet(TIMER0_BASE, TIMER_B, ui32SysClock / 1000);
#else
TimerLoadSet(TIMER0_BASE, TIMER_B, SysCtlClockGet() / 1000);
#endif
// Enable processor interrupts.
IntMasterEnable();
// Configure the Timer0B interrupt for timer timeout.
TimerIntEnable(TIMER0_BASE, TIMER_TIMB_TIMEOUT);
// Enable the Timer0B interrupt on the processor (NVIC).
IntEnable(INT_TIMER0B);
// Initialize the interrupt counter.
g_ui32Counter = 0;
// Enable Timer0B.
TimerEnable(TIMER0_BASE, TIMER_B);
// Loop forever while the Timer0B runs.
while(1)
// If the interrupt count changed, print the new value
if(ui32PrevCount != g_ui32Counter)
// Print the periodic interrupt counter.
UARTprintf("Number of interrupts: %d\r", g_ui32Counter);
ui32PrevCount = g_ui32Counter;
