TDA4VM: Inquiry About Online Debugging Support for DCCSetup_2023_10_10.exe and Alternative ISP Tuning Tools
Part Number: TDA4VM
Hi TI Team,
I’m currently working with the TDA4VM ISP pipeline and using the DCCSetup_2023_10_10.exe tool to generate DCC configuration files for image tuning.
I have two questions:
  1. Does DCCSetup_2023_10_10.exe support online (real-time) debugging?
    Specifically, can I adjust ISP parameters (e.g., GLBCE, noise reduction, color correction) in real time while the system is running, and see the changes reflected immediately in the output video stream?
  2. Are there other recommended tools or methods for online ISP tuning on TDA4VM?
    I’ve heard about the TI Image Tuning Tool (ITT) and ti_tuning_app, but I’m not sure if they are compatible with this version of DCCSetup or the latest Processor SDK (e.g., PSDK 8.x or 9.x). Could you please clarify the current best practice for real-time ISP parameter tuning?
Any guidance or documentation links would be greatly appreciated!
Best regards,
Shenzhen Jueming Artificial Intelligence Co., Ltd.
