Open the RTOS Object View (ROV)
Go to menu Tools -> RTOS Object View (ROV) to open ROV
In RTOS Object View expand lcdSmartRF06EB_CC2650F128.out这个在ccs中怎么打开?没找到在哪?希望大神给些建议
  • In RTOS Object View expand lcdSmartRF06EB_CC2650F128.out
    你说的是。out文件吗,这个不是打开的,这个是目标代码,就是最后烧录用的文件。是下载进单片机的。
  • 您可以查看 http://www.ti.com/lit/ug/spruhd4l/spruhd4l.pdf    2.5.2 Viewing Log Records in ROV
    The RTOS Object View (ROV) can be used to view log events stored on the target. After you have built and run your application, you can open the ROV tool in the CCS Debug view by selecting Tools > RTOS Object View (ROV) and then navigating to the logging module you want to view (for example, LoggerStopMode or LoggerIdle). When the target is halted, ROV repopulates the data. Select the Records tab to view log events still stored in the buffer. For loggers configured to use JTAG, the records shown here are also uploaded to System Analyzer. If you are using the LoggerIdle module, these are the records that have not yet been sent. See the http://rtsc.eclipse.org/docs-tip/RTSC_Object_Viewer web page for more about using the RTOS Object View (ROV) tool.
