已经知道了输入输出管道号,是通过调用
uint32_t USBHCDPipeRead(uint32_t ui32Pipe, uint8_t *pui8Data, uint32_t ui32Size)
uint32_t USBHCDPipeWrite(uint32_t ui32Pipe, uint8_t *pui8Data, uint32_t ui32Size)
来收发数据的吗?
已经知道了输入输出管道号,是通过调用
来收发数据的吗?
不外乎就是把数据放在usb的数据缓冲区中,然后开启中断自动就发送出去了。可以参考官方的usb转串口的代码看看
// usb_dev_serial.c - Main routines for the USB CDC serial example.
// Copyright (c) 2012-2014 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.0.12573 of the EK-TM4C123GXL Firmware Package.
#include <stdbool.h>
#include <stdint.h>
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "inc/hw_gpio.h"
#include "inc/hw_uart.h"
#include "inc/hw_sysctl.h"
#include "driverlib/debug.h"
#include "driverlib/fpu.h"
#include "driverlib/gpio.h"
#include "driverlib/pin_map.h"
#include "driverlib/interrupt.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "driverlib/timer.h"
#include "driverlib/uart.h"
#include "driverlib/usb.h"
#include "driverlib/rom.h"
#include "usblib/usblib.h"
#include "usblib/usbcdc.h"
#include "usblib/usb-ids.h"
#include "usblib/device/usbdevice.h"
#include "usblib/device/usbdcdc.h"
#include "utils/ustdlib.h"
#include "usb_serial_structs.h"
#include "utils/uartstdio.h"
//! \addtogroup example_list
//! <h1>USB Serial Device (usb_dev_serial)</h1>
//! This example application turns the evaluation kit into a virtual serial
//! port when connected to the USB host system. The application supports the
//! USB Communication Device Class, Abstract Control Model to redirect UART0
//! traffic to and from the USB host system.
//! Assuming you installed TivaWare C Series in the default directory, a
//! driver information (INF) file for use with Windows XP, Windows Vista and
//! Windows7 can be found in C:/ti/TivaWare-for-C-Series/windows_drivers. For
//! Windows 2000, the required INF file is in
//! C:/ti/TivaWare-for-C-Series/windows_drivers/win2K.
// Note:
// This example is intended to run on Tiva C Series evaluation kit hardware
// where the UARTs are wired solely for TX and RX, and do not have GPIOs
// connected to act as handshake signals. As a result, this example mimics
// the case where communication is always possible. It reports DSR, DCD
// and CTS as high to ensure that the USB host recognizes that data can be
// sent and merely ignores the host's requested DTR and RTS states. "TODO"
// comments in the code indicate where code would be required to add support
// for real handshakes.
// Configuration and tuning parameters.
// The system tick rate expressed both as ticks per second and a millisecond
// period.
#define SYSTICKS_PER_SECOND 100
#define SYSTICK_PERIOD_MS (1000 / SYSTICKS_PER_SECOND)
// Variables tracking transmit and receive counts.
volatile uint32_t g_ui32UARTTxCount = 0;
volatile uint32_t g_ui32UARTRxCount = 0;
#ifdef DEBUG
uint32_t g_ui32UARTRxErrors = 0;
#endif
// The base address, peripheral ID and interrupt ID of the UART that is to
// be redirected.
// Defines required to redirect UART0 via USB.
#define USB_UART_BASE UART0_BASE
#define USB_UART_PERIPH SYSCTL_PERIPH_UART0
#define USB_UART_INT INT_UART0
// Default line coding settings for the redirected UART.
#define DEFAULT_BIT_RATE 115200
#define DEFAULT_UART_CONFIG (UART_CONFIG_WLEN_8 | UART_CONFIG_PAR_NONE | \
UART_CONFIG_STOP_ONE)
// GPIO peripherals and pins muxed with the redirected UART. These will depend
// upon the IC in use and the UART selected in USB_UART_BASE. Be careful that
// these settings all agree with the hardware you are using.
#define TX_GPIO_BASE GPIO_PORTA_BASE
#define TX_GPIO_PERIPH SYSCTL_PERIPH_GPIOA
#define TX_GPIO_PIN GPIO_PIN_1
#define RX_GPIO_BASE GPIO_PORTA_BASE
#define RX_GPIO_PERIPH SYSCTL_PERIPH_GPIOA
#define RX_GPIO_PIN GPIO_PIN_0
// Flag indicating whether or not we are currently sending a Break condition.
static bool g_bSendingBreak = false;
// Global system tick counter
volatile uint32_t g_ui32SysTickCount = 0;
// Flags used to pass commands from interrupt context to the main loop.
#define COMMAND_PACKET_RECEIVED 0x00000001
#define COMMAND_STATUS_UPDATE 0x00000002
volatile uint32_t g_ui32Flags = 0;
char *g_pcStatus;
// Global flag indicating that a USB configuration has been set.
static volatile bool g_bUSBConfigured = false;
// Internal function prototypes.
static void USBUARTPrimeTransmit(uint32_t ui32Base);
static void CheckForSerialStateChange(const tUSBDCDCDevice *psDevice,
int32_t i32Errors);
static void SetControlLineState(uint16_t ui16State);
static bool SetLineCoding(tLineCoding *psLineCoding);
static void GetLineCoding(tLineCoding *psLineCoding);
static void SendBreak(bool bSend);
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, uint32_t ui32Line)
while(1)
#endif
// This function is called whenever serial data is received from the UART.
// It is passed the accumulated error flags from each character received in
// this interrupt and determines from them whether or not an interrupt
// notification to the host is required.
// If a notification is required and the control interrupt endpoint is idle,
// we send the notification immediately. If the endpoint is not idle, we
// accumulate the errors in a global variable which will be checked on
// completion of the previous notification and used to send a second one
// if necessary.
static void
CheckForSerialStateChange(const tUSBDCDCDevice *psDevice, int32_t i32Errors)
uint16_t ui16SerialState;
// Clear our USB serial state. Since we are faking the handshakes, always
// set the TXCARRIER (DSR) and RXCARRIER (DCD) bits.
ui16SerialState = USB_CDC_SERIAL_STATE_TXCARRIER |
USB_CDC_SERIAL_STATE_RXCARRIER;
// Are any error bits set?
if(i32Errors)
// At least one error is being notified so translate from our hardware
// error bits into the correct state markers for the USB notification.
if(i32Errors & UART_DR_OE)
ui16SerialState |= USB_CDC_SERIAL_STATE_OVERRUN;
if(i32Errors & UART_DR_PE)
ui16SerialState |= USB_CDC_SERIAL_STATE_PARITY;
if(i32Errors & UART_DR_FE)
ui16SerialState |= USB_CDC_SERIAL_STATE_FRAMING;
if(i32Errors & UART_DR_BE)
ui16SerialState |= USB_CDC_SERIAL_STATE_BREAK;
// Call the CDC driver to notify the state change.
USBDCDCSerialStateChange((void *)psDevice, ui16SerialState);
// Read as many characters from the UART FIFO as we can and move them into
// the CDC transmit buffer.
// \return Returns UART error flags read during data reception.
static int32_t
ReadUARTData(void)
int32_t i32Char, i32Errors;
uint8_t ui8Char;
uint32_t ui32Space;
// Clear our error indicator.
i32Errors = 0;
// How much space do we have in the buffer?
ui32Space = USBBufferSpaceAvailable((tUSBBuffer *)&g_sTxBuffer);
// Read data from the UART FIFO until there is none left or we run
// out of space in our receive buffer.
while(ui32Space && ROM_UARTCharsAvail(USB_UART_BASE))
// Read a character from the UART FIFO into the ring buffer if no
// errors are reported.
i32Char = ROM_UARTCharGetNonBlocking(USB_UART_BASE);
// If the character did not contain any error notifications,
// copy it to the output buffer.
if(!(i32Char & ~0xFF))
ui8Char = (uint8_t)(i32Char & 0xFF);
USBBufferWrite((tUSBBuffer *)&g_sTxBuffer,
(uint8_t *)&ui8Char, 1);
// Decrement the number of bytes we know the buffer can accept.
ui32Space--;
else
#ifdef DEBUG
// Increment our receive error counter.
g_ui32UARTRxErrors++;
#endif
// Update our error accumulator.
i32Errors |= i32Char;
// Update our count of bytes received via the UART.
g_ui32UARTRxCount++;
// Pass back the accumulated error indicators.
return(i32Errors);
// Take as many bytes from the transmit buffer as we have space for and move
// them into the USB UART's transmit FIFO.
static void
uint32_t ui32Read;
uint8_t ui8Char;
// If we are currently sending a break condition, don't receive any
// more data. We will resume transmission once the break is turned off.
if(g_bSendingBreak)
return;
// If there is space in the UART FIFO, try to read some characters
// from the receive buffer to fill it again.
while(ROM_UARTSpaceAvail(ui32Base))
// Get a character from the buffer.
ui32Read = USBBufferRead((tUSBBuffer *)&g_sRxBuffer, &ui8Char, 1);
// Did we get a character?
if(ui32Read)
// Place the character in the UART transmit FIFO.
ROM_UARTCharPutNonBlocking(ui32Base, ui8Char);
// Update our count of bytes transmitted via the UART.
g_ui32UARTTxCount++;
else
// We ran out of characters so exit the function.
return;
// Interrupt handler for the system tick counter.
void
SysTickIntHandler(void)
// Update our system time.
g_ui32SysTickCount++;
// Interrupt handler for the UART which we are redirecting via USB.
void
USBUARTIntHandler(void)
uint32_t ui32Ints;
int32_t i32Errors;
// Get and clear the current interrupt source(s)
ui32Ints = ROM_UARTIntStatus(USB_UART_BASE, true);
ROM_UARTIntClear(USB_UART_BASE, ui32Ints);
// Are we being interrupted because the TX FIFO has space available?
if(ui32Ints & UART_INT_TX)
// Move as many bytes as we can into the transmit FIFO.
USBUARTPrimeTransmit(USB_UART_BASE);
// If the output buffer is empty, turn off the transmit interrupt.
if(!USBBufferDataAvailable(&g_sRxBuffer))
ROM_UARTIntDisable(USB_UART_BASE, UART_INT_TX);
// Handle receive interrupts.
if(ui32Ints & (UART_INT_RX | UART_INT_RT))
// Read the UART's characters into the buffer.
i32Errors = ReadUARTData();
// Check to see if we need to notify the host of any errors we just
// detected.
CheckForSerialStateChange(&g_sCDCDevice, i32Errors);
// Set the state of the RS232 RTS and DTR signals.
static void
// TODO: If configured with GPIOs controlling the handshake lines,
// set them appropriately depending upon the flags passed in the wValue
// field of the request structure passed.
// Set the communication parameters to use on the UART.
static bool
uint32_t ui32Config;
bool bRetcode;
// Assume everything is OK until we detect any problem.
bRetcode = true;
// Word length. For invalid values, the default is to set 8 bits per
// character and return an error.
switch(psLineCoding->ui8Databits)
case 5:
ui32Config = UART_CONFIG_WLEN_5;
break;
case 6:
ui32Config = UART_CONFIG_WLEN_6;
break;
case 7:
ui32Config = UART_CONFIG_WLEN_7;
break;
case 8:
ui32Config = UART_CONFIG_WLEN_8;
break;
default:
bRetcode = false;
break;
// Parity. For any invalid values, we set no parity and return an error.
switch(psLineCoding->ui8Parity)
case USB_CDC_PARITY_NONE:
ui32Config |= UART_CONFIG_PAR_NONE;
break;
case USB_CDC_PARITY_ODD:
ui32Config |= UART_CONFIG_PAR_ODD;
break;
case USB_CDC_PARITY_EVEN:
ui32Config |= UART_CONFIG_PAR_EVEN;
break;
case USB_CDC_PARITY_MARK:
ui32Config |= UART_CONFIG_PAR_ONE;
break;
case USB_CDC_PARITY_SPACE:
ui32Config |= UART_CONFIG_PAR_ZERO;
break;
default:
bRetcode = false;
break;
// Stop bits. Our hardware only supports 1 or 2 stop bits whereas CDC
// allows the host to select 1.5 stop bits. If passed 1.5 (or any other
// invalid or unsupported value of ui8Stop, we set up for 1 stop bit but
// return an error in case the caller needs to Stall or otherwise report
// this back to the host.
switch(psLineCoding->ui8Stop)
// One stop bit requested.
case USB_CDC_STOP_BITS_1:
ui32Config |= UART_CONFIG_STOP_ONE;
break;
// Two stop bits requested.
case USB_CDC_STOP_BITS_2:
ui32Config |= UART_CONFIG_STOP_TWO;
break;
// Other cases are either invalid values of ui8Stop or values that we
// cannot support so set 1 stop bit but return an error.
default:
bRetcode = false;
break;
// Set the UART mode appropriately.
ROM_UARTConfigSetExpClk(USB_UART_BASE, ROM_SysCtlClockGet(),
psLineCoding->ui32Rate, ui32Config);
// Let the caller know if we had a problem or not.
return(bRetcode);
// Get the communication parameters in use on the UART.
static void
uint32_t ui32Rate;
// Get the current line coding set in the UART.
ROM_UARTConfigGetExpClk(USB_UART_BASE, ROM_SysCtlClockGet(), &ui32Rate,
&ui32Config);
psLineCoding->ui32Rate = ui32Rate;
// Translate the configuration word length field into the format expected
// by the host.
switch(ui32Config & UART_CONFIG_WLEN_MASK)
case UART_CONFIG_WLEN_8:
psLineCoding->ui8Databits = 8;
break;
case UART_CONFIG_WLEN_7:
psLineCoding->ui8Databits = 7;
break;
case UART_CONFIG_WLEN_6:
psLineCoding->ui8Databits = 6;
break;
case UART_CONFIG_WLEN_5:
psLineCoding->ui8Databits = 5;
break;
// Translate the configuration parity field into the format expected
// by the host.
switch(ui32Config & UART_CONFIG_PAR_MASK)
case UART_CONFIG_PAR_NONE:
psLineCoding->ui8Parity = USB_CDC_PARITY_NONE;
break;
case UART_CONFIG_PAR_ODD:
psLineCoding->ui8Parity = USB_CDC_PARITY_ODD;
break;
case UART_CONFIG_PAR_EVEN:
psLineCoding->ui8Parity = USB_CDC_PARITY_EVEN;
break;
case UART_CONFIG_PAR_ONE:
psLineCoding->ui8Parity = USB_CDC_PARITY_MARK;
break;
case UART_CONFIG_PAR_ZERO:
psLineCoding->ui8Parity = USB_CDC_PARITY_SPACE;
break;
// Translate the configuration stop bits field into the format expected
// by the host.
switch(ui32Config & UART_CONFIG_STOP_MASK)
case UART_CONFIG_STOP_ONE:
psLineCoding->ui8Stop = USB_CDC_STOP_BITS_1;
break;
case UART_CONFIG_STOP_TWO:
psLineCoding->ui8Stop = USB_CDC_STOP_BITS_2;
break;
// This function sets or clears a break condition on the redirected UART RX
// line. A break is started when the function is called with \e bSend set to
// \b true and persists until the function is called again with \e bSend set
// to \b false.
static void
// Are we being asked to start or stop the break condition?
if(!bSend)
// Remove the break condition on the line.
ROM_UARTBreakCtl(USB_UART_BASE, false);
else
// Start sending a break condition on the line.
ROM_UARTBreakCtl(USB_UART_BASE, true);
g_bSendingBreak = true;
// Handles CDC driver notifications related to control and setup of the device.
// \param pvCBData is the client-supplied callback pointer for this channel.
// \param ui32Event identifies the event we are being notified about.
// \param ui32MsgValue is an event-specific value.
// \param pvMsgData is an event-specific pointer.
// This function is called by the CDC driver to perform control-related
// operations on behalf of the USB host. These functions include setting
// and querying the serial communication parameters, setting handshake line
// states and sending break conditions.
// \return The return value is event-specific.
uint32_t
ControlHandler(void *pvCBData, uint32_t ui32Event,
uint32_t ui32MsgValue, void *pvMsgData)
uint32_t ui32IntsOff;
// Which event are we being asked to process?
switch(ui32Event)
// We are connected to a host and communication is now possible.
case USB_EVENT_CONNECTED:
g_bUSBConfigured = true;
// Flush our buffers.
USBBufferFlush(&g_sTxBuffer);
USBBufferFlush(&g_sRxBuffer);
// Tell the main loop to update the display.
ui32IntsOff = ROM_IntMasterDisable();
g_pcStatus = "Connected";
g_ui32Flags |= COMMAND_STATUS_UPDATE;
if(!ui32IntsOff)
ROM_IntMasterEnable();
break;
// The host has disconnected.
case USB_EVENT_DISCONNECTED:
g_pcStatus = "Disconnected";
if(!ui32IntsOff)
break;
// Return the current serial communication parameters.
case USBD_CDC_EVENT_GET_LINE_CODING:
GetLineCoding(pvMsgData);
break;
// Set the current serial communication parameters.
case USBD_CDC_EVENT_SET_LINE_CODING:
SetLineCoding(pvMsgData);
break;
case USBD_CDC_EVENT_SET_CONTROL_LINE_STATE:
SetControlLineState((uint16_t)ui32MsgValue);
break;
// Send a break condition on the serial line.
case USBD_CDC_EVENT_SEND_BREAK:
SendBreak(true);
break;
// Clear the break condition on the serial line.
case USBD_CDC_EVENT_CLEAR_BREAK:
SendBreak(false);
break;
// Ignore SUSPEND and RESUME for now.
case USB_EVENT_SUSPEND:
case USB_EVENT_RESUME:
break;
// We don't expect to receive any other events. Ignore any that show
// up in a release build or hang in a debug build.
default:
#ifdef DEBUG
while(1);
#else
break;
#endif
return(0);
// Handles CDC driver notifications related to the transmit channel (data to
// the USB host).
// \param ui32CBData is the client-supplied callback pointer for this channel.
// This function is called by the CDC driver to notify us of any events
// related to operation of the transmit data channel (the IN channel carrying
// data to the USB host).
uint32_t
TxHandler(void *pvCBData, uint32_t ui32Event, uint32_t ui32MsgValue,
void *pvMsgData)
// Which event have we been sent?
switch(ui32Event)
case USB_EVENT_TX_COMPLETE:
// Since we are using the USBBuffer, we don't need to do anything
// here.
break;
default:
#ifdef DEBUG
while(1);
#else
break;
#endif
return(0);
// Handles CDC driver notifications related to the receive channel (data from
// the USB host).
// \param ui32CBData is the client-supplied callback data value for this channel.
// related to operation of the receive data channel (the OUT channel carrying
// data from the USB host).
uint32_t
RxHandler(void *pvCBData, uint32_t ui32Event, uint32_t ui32MsgValue,
void *pvMsgData)
uint32_t ui32Count;
// Which event are we being sent?
switch(ui32Event)
// A new packet has been received.
case USB_EVENT_RX_AVAILABLE:
// Feed some characters into the UART TX FIFO and enable the
// interrupt so we are told when there is more space.
ROM_UARTIntEnable(USB_UART_BASE, UART_INT_TX);
break;
// We are being asked how much unprocessed data we have still to
// process. We return 0 if the UART is currently idle or 1 if it is
// in the process of transmitting something. The actual number of
// bytes in the UART FIFO is not important here, merely whether or
// not everything previously sent to us has been transmitted.
case USB_EVENT_DATA_REMAINING:
// Get the number of bytes in the buffer and add 1 if some data
// still has to clear the transmitter.
ui32Count = ROM_UARTBusy(USB_UART_BASE) ? 1 : 0;
return(ui32Count);
// We are being asked to provide a buffer into which the next packet
// can be read. We do not support this mode of receiving data so let
// the driver know by returning 0. The CDC driver should not be sending
// this message but this is included just for illustration and
// completeness.
case USB_EVENT_REQUEST_BUFFER:
return(0);
default:
#ifdef DEBUG
while(1);
#else
break;
#endif
return(0);
// This is the main application entry function.
int
main(void)
uint32_t ui32TxCount;
uint32_t ui32RxCount;
// Enable lazy stacking for interrupt handlers. This allows floating-point
// instructions to be used within interrupt handlers, but at the expense of
// extra stack usage.
ROM_FPULazyStackingEnable();
// Set the clocking to run from the PLL at 50MHz
ROM_SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |
SYSCTL_XTAL_16MHZ);
// Configure the required pins for USB operation.
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
ROM_GPIOPinTypeUSBAnalog(GPIO_PORTD_BASE, GPIO_PIN_5 | GPIO_PIN_4);
// Enable the GPIO port that is used for the on-board LED.
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
// Enable the GPIO pins for the LED (PF2 & PF3).
ROM_GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_3|GPIO_PIN_2);
// Not configured initially.
// Enable the UART that we will be redirecting.
ROM_SysCtlPeripheralEnable(USB_UART_PERIPH);
// Enable and configure the UART RX and TX pins
ROM_SysCtlPeripheralEnable(TX_GPIO_PERIPH);
ROM_SysCtlPeripheralEnable(RX_GPIO_PERIPH);
ROM_GPIOPinTypeUART(TX_GPIO_BASE, TX_GPIO_PIN);
ROM_GPIOPinTypeUART(RX_GPIO_BASE, RX_GPIO_PIN);
// TODO: Add code to configure handshake GPIOs if required.
// Set the default UART configuration.
DEFAULT_BIT_RATE, DEFAULT_UART_CONFIG);
ROM_UARTFIFOLevelSet(USB_UART_BASE, UART_FIFO_TX4_8, UART_FIFO_RX4_8);
// Configure and enable UART interrupts.
ROM_UARTIntClear(USB_UART_BASE, ROM_UARTIntStatus(USB_UART_BASE, false));
ROM_UARTIntEnable(USB_UART_BASE, (UART_INT_OE | UART_INT_BE | UART_INT_PE |
UART_INT_FE | UART_INT_RT | UART_INT_TX | UART_INT_RX));
// Enable the system tick.
ROM_SysTickPeriodSet(ROM_SysCtlClockGet() / SYSTICKS_PER_SECOND);
ROM_SysTickIntEnable();
ROM_SysTickEnable();
// Initialize the transmit and receive buffers.
USBBufferInit(&g_sTxBuffer);
USBBufferInit(&g_sRxBuffer);
// Set the USB stack mode to Device mode with VBUS monitoring.
USBStackModeSet(0, eUSBModeForceDevice, 0);
// Pass our device information to the USB library and place the device
// on the bus.
USBDCDCInit(0, &g_sCDCDevice);
// Clear our local byte counters.
ui32RxCount = 0;
ui32TxCount = 0;
// Enable interrupts now that the application is ready to start.
ROM_IntEnable(USB_UART_INT);
// Main application loop.
while(1)
// Have we been asked to update the status display?
if(g_ui32Flags & COMMAND_STATUS_UPDATE)
// Clear the command flag
g_ui32Flags &= ~COMMAND_STATUS_UPDATE;
// Has there been any transmit traffic since we last checked?
if(ui32TxCount != g_ui32UARTTxCount)
// Turn on the Green LED.
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3, GPIO_PIN_3);
// Delay for a bit.
SysCtlDelay(ROM_SysCtlClockGet() / 3 / 20);
// Turn off the Green LED.
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3, 0);
// Take a snapshot of the latest transmit count.
ui32TxCount = g_ui32UARTTxCount;
// Has there been any receive traffic since we last checked?
if(ui32RxCount != g_ui32UARTRxCount)
// Turn on the Blue LED.
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, GPIO_PIN_2);
// Delay for a bit.
// Turn off the Blue LED.
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, 0);
// Take a snapshot of the latest receive count.
ui32RxCount = g_ui32UARTRxCount;
谢谢。那再请问一下,我用TM4C129读取一块其他厂家自定义的USB设备时需要在传输控制函数USBHCDControlTransfer()内断点运行才能正确读取出信息,如果没有断点调试运行的话就会进入这个状态错误if(g_sUSBHEP0State.iState == eEP0StateError),同样的程序如果是键盘、鼠标等设备插入是没有问题的。通过把那个厂家USB设备插入电脑发现它是usb1.1版本的,不知是否跟这个有关系?
