关于CC3200温度传感器的问题,读不出来值
我学习书籍上的程序, 可是我读不到0x41的值,程序执行到if(!iRetVal)之后 直接跳转到MAP那边 ,请问这是怎么回事呢?
此外,加速度传感器的值可以读取,是硬件问题吗?
  • 看不出来啊,给你个官方的例程
    // Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
    //  Redistribution and use in source and binary forms, with or without
    //  modification, are permitted provided that the following conditions
    //  are met:
    //    Redistributions of source code must retain the above copyright
    //    notice, this list of conditions and the following disclaimer.
    //    Redistributions in binary form must reproduce the above copyright
    //    notice, this list of conditions and the following disclaimer in the
    //    documentation and/or other materials provided with the
    //    distribution.
    //    Neither the name of Texas Instruments Incorporated nor the names of
    //    its contributors may be used to endorse or promote products derived
    //    from this software without specific prior written permission.
    //  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    //  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    //  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    //  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    //  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    //  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    //  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    //  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    //  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    //  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    //  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // Application Name     - I2C
    // Application Overview - The objective of this application is act as an I2C
    //                        diagnostic tool. The demo application is a generic
    //                        implementation that allows the user to communicate
    //                        with any I2C device over the lines.
    // Application Details  -
    // http://processors.wiki.ti.com/index.php/CC32xx_I2C_Application
    // or
    // docs\examples\CC32xx_I2C_Application.pdf
    //! \addtogroup i2c_demo
    // Standard includes
    #include <stdio.h>
    #include <string.h>
    #include <stdlib.h>
    // Driverlib includes
    #include "hw_types.h"
    #include "hw_ints.h"
    #include "hw_memmap.h"
    #include "hw_common_reg.h"
    #include "rom.h"
    #include "rom_map.h"
    #include "interrupt.h"
    #include "prcm.h"
    #include "utils.h"
    #include "uart.h"
    // Common interface includes
    #include "uart_if.h"
    #include "i2c_if.h"
    #include "pinmux.h"
    //                      MACRO DEFINITIONS
    #define APPLICATION_VERSION     "1.1.1"
    #define APP_NAME                "I2C Demo"
    #define UART_PRINT              Report
    #define FOREVER                 1
    #define CONSOLE                 UARTA0_BASE
    #define FAILURE                 -1
    #define SUCCESS                 0
    #define RETERR_IF_TRUE(condition) {if(condition) return FAILURE;}
    #define RET_IF_ERR(Func)          {int iRetVal = (Func); \
                                       if (SUCCESS != iRetVal) \
                                         return  iRetVal;}
    //                 GLOBAL VARIABLES -- Start
    #if defined(ccs)
    extern void (* const g_pfnVectors[])(void);
    #endif
    #if defined(ewarm)
    extern uVectorEntry __vector_table;
    #endif
    //                 GLOBAL VARIABLES -- End
    //                      LOCAL FUNCTION DEFINITIONS
    //! Display a prompt for the user to enter command
    //! \param  none
    //! \return none
    void
    DisplayPrompt()
        UART_PRINT("\n\rcmd#");
    //! Display the usage of the I2C commands supported
    //! \param  none
    //! \return none
    void
    DisplayUsage()
        UART_PRINT("Command Usage \n\r");
        UART_PRINT("------------- \n\r");
        UART_PRINT("write <dev_addr> <wrlen> <<byte0> [<byte1> ... ]> <stop>\n\r");
        UART_PRINT("\t - Write data to the specified i2c device\n\r");
        UART_PRINT("read  <dev_addr> <rdlen> \n\r\t - Read data frpm the specified "
                    "i2c device\n\r");
        UART_PRINT("writereg <dev_addr> <reg_offset> <wrlen> <<byte0> [<byte1> ... "
                    "]> \n\r");
        UART_PRINT("\t - Write data to the specified register of the i2c device\n\r");
        UART_PRINT("readreg <dev_addr> <reg_offset> <rdlen> \n\r");
        UART_PRINT("\t - Read data from the specified register of the i2c device\n\r");
        UART_PRINT("\n\r");
        UART_PRINT("Parameters \n\r");
        UART_PRINT("---------- \n\r");
        UART_PRINT("dev_addr - slave address of the i2c device, a hex value "
                    "preceeded by '0x'\n\r");
        UART_PRINT("reg_offset - register address in the i2c device, a hex value "
        UART_PRINT("wrlen - number of bytes to be written, a decimal value \n\r");
        UART_PRINT("rdlen - number of bytes to be read, a decimal value \n\r");
        UART_PRINT("bytex - value of the data to be written, a hex value preceeded "
                    "by '0x'\n\r");
        UART_PRINT("stop - number of stop bits, 0 or 1\n\r");
        UART_PRINT("--------------------------------------------------------------"
                    "--------------- \n\r\n\r");
    //! Display the buffer contents over I2C
    //! \param  pucDataBuf is the pointer to the data store to be displayed
    //! \param  ucLen is the length of the data to be displayed
    //! \return none
    void
    DisplayBuffer(unsigned char *pucDataBuf, unsigned char ucLen)
        unsigned char ucBufIndx = 0;
        UART_PRINT("Read contents");
        UART_PRINT("\n\r");
        while(ucBufIndx < ucLen)
            UART_PRINT(" 0x%x, ", pucDataBuf[ucBufIndx]);
            ucBufIndx++;
            if((ucBufIndx % 8) == 0)
                UART_PRINT("\n\r");
        UART_PRINT("\n\r");
    //! Application startup display on UART
    //! \param  none
    //! \return none
    static void
    DisplayBanner(char * AppName)
        Report("\n\n\n\r");
        Report("\t\t *************************************************\n\r");
        Report("\t\t      CC3200 %s Application       \n\r", AppName);
        Report("\n\n\n\r");
    //! Parses the read command parameters and invokes the I2C APIs
    //! \param pcInpString pointer to the user command parameters
    //! This function
    //!    1. Parses the read command parameters.
    //!    2. Invokes the corresponding I2C APIs
    //! \return 0: Success, < 0: Failure.
    int
    ProcessReadCommand(char *pcInpString)
        unsigned char ucDevAddr, ucLen;
        unsigned char aucDataBuf[256];
        char *pcErrPtr;
        int iRetVal;
        // Get the device address
        pcInpString = strtok(NULL, " ");
        RETERR_IF_TRUE(pcInpString == NULL);
        ucDevAddr = (unsigned char)strtoul(pcInpString+2, &pcErrPtr, 16);
        // Get the length of data to be read
        ucLen = (unsigned char)strtoul(pcInpString, &pcErrPtr, 10);
        //RETERR_IF_TRUE(ucLen > sizeof(aucDataBuf));
        // Read the specified length of data
        iRetVal = I2C_IF_Read(ucDevAddr, aucDataBuf, ucLen);
        if(iRetVal == SUCCESS)
            UART_PRINT("I2C Read complete\n\r");
            // Display the buffer over UART on successful write
            DisplayBuffer(aucDataBuf, ucLen);
        else
            UART_PRINT("I2C Read failed\n\r");
            return FAILURE;
        return SUCCESS;
    //! Parses the readreg command parameters and invokes the I2C APIs
    //! i2c readreg 0x<dev_addr> 0x<reg_offset> <rdlen>
    //! \param pcInpString pointer to the readreg command parameters
    //! This function
    //!    1. Parses the readreg command parameters.
    int
    ProcessReadRegCommand(char *pcInpString)
        unsigned char ucDevAddr, ucRegOffset, ucRdLen;
        unsigned char aucRdDataBuf[256];
        char *pcErrPtr;
        // Get the register offset address
        ucRegOffset = (unsigned char)strtoul(pcInpString+2, &pcErrPtr, 16);
        ucRdLen = (unsigned char)strtoul(pcInpString, &pcErrPtr, 10);
        // Write the register address to be read from.
        // Stop bit implicitly assumed to be 0.
        RET_IF_ERR(I2C_IF_Write(ucDevAddr,&ucRegOffset,1,0));
        RET_IF_ERR(I2C_IF_Read(ucDevAddr, &aucRdDataBuf[0], ucRdLen));
        UART_PRINT("I2C Read From address complete\n\r");
        // Display the buffer over UART on successful readreg
        DisplayBuffer(aucRdDataBuf, ucRdLen);
        return SUCCESS;
    //! Parses the writereg command parameters and invokes the I2C APIs
    //! i2c writereg 0x<dev_addr> 0x<reg_offset> <wrlen> <0x<byte0> [0x<byte1> ...]>
    //! This function
    //!    1. Parses the writereg command parameters.
    int
    ProcessWriteRegCommand(char *pcInpString)
        unsigned char ucDevAddr, ucRegOffset, ucWrLen;
        char *pcErrPtr;
        int iLoopCnt = 0;
        // Get the register offset to be written
        aucDataBuf[iLoopCnt] = ucRegOffset;
        iLoopCnt++;
        // Get the length of data to be written
        ucWrLen = (unsigned char)strtoul(pcInpString, &pcErrPtr, 10);
        //RETERR_IF_TRUE(ucWrLen > sizeof(aucDataBuf));
        // Get the bytes to be written
        for(; iLoopCnt < ucWrLen + 1; iLoopCnt++)
            // Store the data to be written
        // Write the data values.
        RET_IF_ERR(I2C_IF_Write(ucDevAddr,&aucDataBuf[0],ucWrLen+1,1));
        UART_PRINT("I2C Write To address complete\n\r");
        return SUCCESS;
    //! Parses the write command parameters and invokes the I2C APIs
    //! \param pcInpString pointer to the write command parameters
    //! This function
    //!    1. Parses the write command parameters.
    int
    ProcessWriteCommand(char *pcInpString)
        unsigned char ucDevAddr, ucStopBit, ucLen;
        char *pcErrPtr;
        int iRetVal, iLoopCnt;
        for(iLoopCnt = 0; iLoopCnt < ucLen; iLoopCnt++)
        // Get the stop bit
        ucStopBit = (unsigned char)strtoul(pcInpString, &pcErrPtr, 10);
        // Write the data to the specified address
        iRetVal = I2C_IF_Write(ucDevAddr, aucDataBuf, ucLen, ucStopBit);
            UART_PRINT("I2C Write complete\n\r");
        else
            UART_PRINT("I2C Write failed\n\r");
            return FAILURE;
        return SUCCESS;
    //! Parses the user input command and invokes the I2C APIs
    //! \param pcCmdBuffer pointer to the user command
    //! This function
    //!    1. Parses the user command.
    int
    ParseNProcessCmd(char *pcCmdBuffer)
        char *pcInpString;
        int iRetVal = FAILURE;
        pcInpString = strtok(pcCmdBuffer, " \n\r");
        if(pcInpString != NULL)
            if(!strcmp(pcInpString, "read"))
                // Invoke the read command handler
                iRetVal = ProcessReadCommand(pcInpString);
            else if(!strcmp(pcInpString, "readreg"))
                // Invoke the readreg command handler
                iRetVal = ProcessReadRegCommand(pcInpString);
            else if(!strcmp(pcInpString, "writereg"))
                // Invoke the writereg command handler
                iRetVal = ProcessWriteRegCommand(pcInpString);
            else if(!strcmp(pcInpString, "write"))
                // Invoke the write command handler
                iRetVal = ProcessWriteCommand(pcInpString);
            else
                UART_PRINT("Unsupported command\n\r");
                return FAILURE;
        return iRetVal;
    //! Board Initialization & Configuration
    //! \param  None
    //! \return None
    static void
    BoardInit(void)
    /* In case of TI-RTOS vector table is initialize by OS itself */
    #ifndef USE_TIRTOS
        // Set vector table base
    #if defined(ccs)
        MAP_IntVTableBaseSet((unsigned long)&g_pfnVectors[0]);
    #endif
    #if defined(ewarm)
        MAP_IntVTableBaseSet((unsigned long)&__vector_table);
    #endif
    #endif
        // Enable Processor
        MAP_IntMasterEnable();
        MAP_IntEnable(FAULT_SYSTICK);
        PRCMCC3200MCUInit();
    //! Main function handling the I2C example
    //! \param  None
    //! \return None
    void main()
        int iRetVal;
        char acCmdStore[512];
        // Initialize board configurations
        BoardInit();
        // Configure the pinmux settings for the peripherals exercised
        PinMuxConfig();
        // Configuring UART
        InitTerm();
        // I2C Init
        I2C_IF_Open(I2C_MASTER_MODE_FST);
        // Display the banner followed by the usage description
        DisplayBanner(APP_NAME);
        DisplayUsage();
        while(FOREVER)
          // Provide a prompt for the user to enter a command
          DisplayPrompt();
          // Get the user command line
          iRetVal = GetCmd(acCmdStore, sizeof(acCmdStore));
          if(iRetVal < 0)
              // Error in parsing the command as length is exceeded.
              UART_PRINT("Command length exceeded 512 bytes \n\r");
              DisplayUsage();
          else if(iRetVal == 0)
              // No input. Just an enter pressed probably. Display a prompt.
          else
              // Parse the user command and try to process it.
              iRetVal = ParseNProcessCmd(acCmdStore);
              if(iRetVal < 0)
                  UART_PRINT("Error in processing command\n\r");
                  DisplayUsage();
    // Close the Doxygen group.
  • 这个官方例程我也有哦,应该不是I2C出问题了,毕竟加速度传感器可以工作, 可以想想也不可能就坏以个温度传感器啊
