CC2540 osal 串口通信延迟太大
Other Parts Discussed in Thread: CC2540, TPS62730
2540 用osal 进行串口通信,很多例子为什么延迟比较大,如传感器 MPU6050 实 现 DMP 输出,延迟超过5秒?
  • 你看的是什么例子? 宏定义里面POWER_SAVING了没有啊?
      Filename:       simpleBLEPeripheral.c
      Revised:        $Date: 2010-08-06 08:56:11 -0700 (Fri, 06 Aug 2010) $
      Revision:       $Revision: 23333 $
      Description:    This file contains the Simple BLE Peripheral sample application
                      for use with the CC2540 Bluetooth Low Energy Protocol Stack.
      Copyright 2010 - 2013 Texas Instruments Incorporated. All rights reserved.
      IMPORTANT: Your use of this Software is limited to those specific rights
      granted under the terms of a software license agreement between the user
      who downloaded the software, his/her employer (which must be your employer)
      and Texas Instruments Incorporated (the "License").  You may not use this
      Software unless you agree to abide by the terms of the License. The License
      limits your use, and you acknowledge, that the Software may not be modified,
      copied or distributed unless embedded on a Texas Instruments microcontroller
      or used solely and exclusively in conjunction with a Texas Instruments radio
      frequency transceiver, which is integrated into your product.  Other than for
      the foregoing purpose, you may not use, reproduce, copy, prepare derivative
      works of, modify, distribute, perform, display or sell this Software and/or
      its documentation for any purpose.
      YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
      PROVIDED 揂S IS?WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
      INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
      NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
      TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
      NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
      LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
      INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
      OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
      OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
      (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
      Should you have any questions regarding your right to use this Software,
      contact Texas Instruments Incorporated at www.TI.com.
     * INCLUDES
    #include "bcomdef.h"
    #include "OSAL.h"
    #include "OSAL_PwrMgr.h"
    #include "OnBoard.h"
    #include "hal_adc.h"
    #include "hal_led.h"
    #include "hal_key.h"
    #include "hal_lcd.h"
    #include "gatt.h"
    #include "hci.h"
    #include "gapgattserver.h"
    #include "gattservapp.h"
    #include "devinfoservice.h"
    #include "simpleGATTprofile.h"
    #if defined( CC2540_MINIDK )
      #include "simplekeys.h"
    #endif
    #if defined ( PLUS_BROADCASTER )
      #include "peripheralBroadcaster.h"
    #else
      #include "peripheral.h"
    #endif
    #include "gapbondmgr.h"
    #include "simpleBLEPeripheral.h"
    #if defined FEATURE_OAD
      #include "oad.h"
      #include "oad_target.h"
    #endif
    #include "Npi.h"
    #include "stdio.h"
    //AmoMcu add for SENSOR_MPU6050
    #if defined( SENSOR_MPU6050 )
    #include "Mpu6050.h"
    #endif
    #if defined( SENSOR_MPU6050_DMP  )
    #include "anbt_dmp_fun.h"
    #include "anbt_i2c.h"
    #include "anbt_dmp_mpu6050.h"
    #include "anbt_dmp_driver.h"
    #endif
     * MACROS
     * CONSTANTS
    // How often to perform periodic event
    #define SBP_PERIODIC_EVT_PERIOD                   50//5000
    // What is the advertising interval when device is discoverable (units of 625us, 160=100ms)
    #define DEFAULT_ADVERTISING_INTERVAL          160
    // Limited discoverable mode advertises for 30.72s, and then stops
    // General discoverable mode advertises indefinitely
    #if defined ( CC2540_MINIDK )
    #define DEFAULT_DISCOVERABLE_MODE             GAP_ADTYPE_FLAGS_LIMITED
    #else
    #define DEFAULT_DISCOVERABLE_MODE             GAP_ADTYPE_FLAGS_GENERAL
    #endif  // defined ( CC2540_MINIDK )
    // Minimum connection interval (units of 1.25ms, 80=100ms) if automatic parameter update request is enabled
    #define DEFAULT_DESIRED_MIN_CONN_INTERVAL     20
    // Maximum connection interval (units of 1.25ms, 800=1000ms) if automatic parameter update request is enabled
    #define DEFAULT_DESIRED_MAX_CONN_INTERVAL     20
    // Slave latency to use if automatic parameter update request is enabled
    #define DEFAULT_DESIRED_SLAVE_LATENCY         0
    // Supervision timeout value (units of 10ms, 1000=10s) if automatic parameter update request is enabled
    #define DEFAULT_DESIRED_CONN_TIMEOUT          500
    // Whether to enable automatic parameter update request when a connection is formed
    #define DEFAULT_ENABLE_UPDATE_REQUEST         TRUE
    // Connection Pause Peripheral time value (in seconds)
    #define DEFAULT_CONN_PAUSE_PERIPHERAL         6
    // Company Identifier: Texas Instruments Inc. (13)
    #define TI_COMPANY_ID                         0x000D
    #define INVALID_CONNHANDLE                    0xFFFF
    // Length of bd addr as a string
    #define B_ADDR_STR_LEN                        15
      #define ADV_IN_CONN_WAIT                    500 // delay 500 ms
    #endif
     * TYPEDEFS
     * GLOBAL VARIABLES
     * EXTERNAL VARIABLES
     * EXTERNAL FUNCTIONS
     * LOCAL VARIABLES
    static uint8 simpleBLEPeripheral_TaskID;   // Task ID for internal task/event processing
    static gaprole_States_t gapProfileState = GAPROLE_INIT;
    // GAP - SCAN RSP data (max size = 31 bytes)
    static uint8 scanRspData[] =
      // complete name
      0x14,   // length of this data
      GAP_ADTYPE_LOCAL_NAME_COMPLETE,
      0x53,   // 'S'
      0x69,   // 'i'
      0x6d,   // 'm'
      0x70,   // 'p'
      0x6c,   // 'l'
      0x65,   // 'e'
      0x42,   // 'B'
      0x4c,   // 'L'
      0x45,   // 'E'
      0x50,   // 'P'
      0x65,   // 'e'
      0x72,   // 'r'
      0x69,   // 'i'
      0x70,   // 'p'
      0x68,   // 'h'
      0x65,   // 'e'
      0x72,   // 'r'
      0x61,   // 'a'
      0x6c,   // 'l'
      // connection interval range
      0x05,   // length of this data
      GAP_ADTYPE_SLAVE_CONN_INTERVAL_RANGE,
      LO_UINT16( DEFAULT_DESIRED_MIN_CONN_INTERVAL ),   // 100ms
      HI_UINT16( DEFAULT_DESIRED_MIN_CONN_INTERVAL ),
      LO_UINT16( DEFAULT_DESIRED_MAX_CONN_INTERVAL ),   // 1s
      HI_UINT16( DEFAULT_DESIRED_MAX_CONN_INTERVAL ),
      // Tx power level
      0x02,   // length of this data
      GAP_ADTYPE_POWER_LEVEL,
      0       // 0dBm
    // GAP - Advertisement data (max size = 31 bytes, though this is
    // best kept short to conserve power while advertisting)
    static uint8 advertData[] =
      // Flags; this sets the device to use limited discoverable
      // mode (advertises for 30 seconds at a time) instead of general
      // discoverable mode (advertises indefinitely)
      GAP_ADTYPE_FLAGS,
      DEFAULT_DISCOVERABLE_MODE | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED,
      // service UUID, to notify central devices what services are included
      // in this peripheral
      0x03,   // length of this data
      GAP_ADTYPE_16BIT_MORE,      // some of the UUID's, but not all
      LO_UINT16( SIMPLEPROFILE_SERV_UUID ),
      HI_UINT16( SIMPLEPROFILE_SERV_UUID ),
    // GAP GATT Attributes
    static uint8 attDeviceName[GAP_DEVICE_NAME_LEN] = "AmoMcu-Mpu6050-Peri";
     * LOCAL FUNCTIONS
    static void simpleBLEPeripheral_ProcessOSALMsg( osal_event_hdr_t *pMsg );
    static void peripheralStateNotificationCB( gaprole_States_t newState );
    static void performPeriodicTask( void );
    static void simpleProfileChangeCB( uint8 paramID );
    static void simpleBLEPeripheral_HandleKeys( uint8 shift, uint8 keys );
    #endif
    #if (defined HAL_LCD) && (HAL_LCD == TRUE)
    static char *bdAddr2Str ( uint8 *pAddr );
    #endif // (defined HAL_LCD) && (HAL_LCD == TRUE)
    // 发送数据到主机
    void simpleBLE_SendData(uint8* buffer, uint8 sendBytes);
    // 串口回调函数
    static void simpleBLE_NpiSerialCallback( uint8 port, uint8 events );
     * PROFILE CALLBACKS
    // GAP Role Callbacks
    static gapRolesCBs_t simpleBLEPeripheral_PeripheralCBs =
      peripheralStateNotificationCB,  // Profile State Change Callbacks
      NULL                            // When a valid RSSI is read from controller (not used by application)
    // GAP Bond Manager Callbacks
    static gapBondCBs_t simpleBLEPeripheral_BondMgrCBs =
      NULL,                     // Passcode callback (not used by application)
      NULL                      // Pairing / Bonding state Callback (not used by application)
    // Simple GATT Profile Callbacks
    static simpleProfileCBs_t simpleBLEPeripheral_SimpleProfileCBs =
      simpleProfileChangeCB    // Charactersitic value change callback
     * PUBLIC FUNCTIONS
     * @fn      SimpleBLEPeripheral_Init
     * @brief   Initialization function for the Simple BLE Peripheral App Task.
     *          This is called during initialization and should contain
     *          any application specific initialization (ie. hardware
     *          initialization/setup, table initialization, power up
     *          notificaiton ... ).
     * @param   task_id - the ID assigned by OSAL.  This ID should be
     *                    used to send messages and set timers.
     * @return  none
    void SimpleBLEPeripheral_Init( uint8 task_id )
      simpleBLEPeripheral_TaskID = task_id;
      // 串口初始化
      NPI_InitTransport(simpleBLE_NpiSerialCallback);
      NPI_WriteTransport("SimpleBLEPeripheral_Init\r\n", 26);
      // Setup the GAP
      VOID GAP_SetParamValue( TGAP_CONN_PAUSE_PERIPHERAL, DEFAULT_CONN_PAUSE_PERIPHERAL );
      // Setup the GAP Peripheral Role Profile
          // For the CC2540DK-MINI keyfob, device doesn't start advertising until button is pressed
          uint8 initial_advertising_enable = FALSE;
        #else
          // For other hardware platforms, device starts advertising upon initialization
          uint8 initial_advertising_enable = TRUE;
        #endif
        // By setting this to zero, the device will go into the waiting state after
        // being discoverable for 30.72 second, and will not being advertising again
        // until the enabler is set back to TRUE
        uint16 gapRole_AdvertOffTime = 0;
        uint8 enable_update_request = DEFAULT_ENABLE_UPDATE_REQUEST;
        uint16 desired_min_interval = DEFAULT_DESIRED_MIN_CONN_INTERVAL;
        uint16 desired_max_interval = DEFAULT_DESIRED_MAX_CONN_INTERVAL;
        uint16 desired_slave_latency = DEFAULT_DESIRED_SLAVE_LATENCY;
        uint16 desired_conn_timeout = DEFAULT_DESIRED_CONN_TIMEOUT;
        // Set the GAP Role Parameters
        GAPRole_SetParameter( GAPROLE_ADVERT_ENABLED, sizeof( uint8 ), &initial_advertising_enable );
        GAPRole_SetParameter( GAPROLE_ADVERT_OFF_TIME, sizeof( uint16 ), &gapRole_AdvertOffTime );
        GAPRole_SetParameter( GAPROLE_SCAN_RSP_DATA, sizeof ( scanRspData ), scanRspData );
        GAPRole_SetParameter( GAPROLE_ADVERT_DATA, sizeof( advertData ), advertData );
        GAPRole_SetParameter( GAPROLE_PARAM_UPDATE_ENABLE, sizeof( uint8 ), &enable_update_request );
        GAPRole_SetParameter( GAPROLE_MIN_CONN_INTERVAL, sizeof( uint16 ), &desired_min_interval );
        GAPRole_SetParameter( GAPROLE_MAX_CONN_INTERVAL, sizeof( uint16 ), &desired_max_interval );
        GAPRole_SetParameter( GAPROLE_SLAVE_LATENCY, sizeof( uint16 ), &desired_slave_latency );
        GAPRole_SetParameter( GAPROLE_TIMEOUT_MULTIPLIER, sizeof( uint16 ), &desired_conn_timeout );
      // Set the GAP Characteristics
      GGS_SetParameter( GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName );
      // Set advertising interval
        uint16 advInt = DEFAULT_ADVERTISING_INTERVAL;
        GAP_SetParamValue( TGAP_LIM_DISC_ADV_INT_MIN, advInt );
        GAP_SetParamValue( TGAP_LIM_DISC_ADV_INT_MAX, advInt );
        GAP_SetParamValue( TGAP_GEN_DISC_ADV_INT_MIN, advInt );
        GAP_SetParamValue( TGAP_GEN_DISC_ADV_INT_MAX, advInt );
      // Setup the GAP Bond Manager
        uint32 passkey = 0; // passkey "000000"
        uint8 pairMode = GAPBOND_PAIRING_MODE_WAIT_FOR_REQ;
        uint8 mitm = TRUE;
        uint8 ioCap = GAPBOND_IO_CAP_DISPLAY_ONLY;
        uint8 bonding = TRUE;
        GAPBondMgr_SetParameter( GAPBOND_DEFAULT_PASSCODE, sizeof ( uint32 ), &passkey );
        GAPBondMgr_SetParameter( GAPBOND_PAIRING_MODE, sizeof ( uint8 ), &pairMode );
        GAPBondMgr_SetParameter( GAPBOND_MITM_PROTECTION, sizeof ( uint8 ), &mitm );
        GAPBondMgr_SetParameter( GAPBOND_IO_CAPABILITIES, sizeof ( uint8 ), &ioCap );
        GAPBondMgr_SetParameter( GAPBOND_BONDING_ENABLED, sizeof ( uint8 ), &bonding );
      // Initialize GATT attributes
      GGS_AddService( GATT_ALL_SERVICES );            // GAP
      GATTServApp_AddService( GATT_ALL_SERVICES );    // GATT attributes
      DevInfo_AddService();                           // Device Information Service
      SimpleProfile_AddService( GATT_ALL_SERVICES );  // Simple GATT Profile
      VOID OADTarget_AddService();                    // OAD Profile
    #endif
      // Setup the SimpleProfile Characteristic Values
        uint8 charValue1 = 1;
        uint8 charValue2 = 2;
        uint8 charValue3 = 3;
        uint8 charValue4 = 4;
        uint8 charValue5[SIMPLEPROFILE_CHAR5_LEN] = { 1, 2, 3, 4, 5 };
        SimpleProfile_SetParameter( SIMPLEPROFILE_CHAR1, sizeof ( uint8 ), &charValue1 );
        SimpleProfile_SetParameter( SIMPLEPROFILE_CHAR2, sizeof ( uint8 ), &charValue2 );
        SimpleProfile_SetParameter( SIMPLEPROFILE_CHAR3, sizeof ( uint8 ), &charValue3 );
        SimpleProfile_SetParameter( SIMPLEPROFILE_CHAR4, sizeof ( uint8 ), &charValue4 );
        SimpleProfile_SetParameter( SIMPLEPROFILE_CHAR5, SIMPLEPROFILE_CHAR5_LEN, charValue5 );
      SK_AddService( GATT_ALL_SERVICES ); // Simple Keys Profile
      // Register for all key events - This app will handle all key events
      RegisterForKeys( simpleBLEPeripheral_TaskID );
      // makes sure LEDs are off
      HalLedSet( (HAL_LED_1 | HAL_LED_2), HAL_LED_MODE_OFF );
      // For keyfob board set GPIO pins into a power-optimized state
      // Note that there is still some leakage current from the buzzer,
      // accelerometer, LEDs, and buttons on the PCB.
      P0SEL = 0; // Configure Port 0 as GPIO
      P1SEL = 0; // Configure Port 1 as GPIO
      P2SEL = 0; // Configure Port 2 as GPIO
      P0DIR = 0xFC; // Port 0 pins P0.0 and P0.1 as input (buttons),
                    // all others (P0.2-P0.7) as output
      P1DIR = 0xFF; // All port 1 pins (P1.0-P1.7) as output
      P2DIR = 0x1F; // All port 1 pins (P2.0-P2.4) as output
      P0 = 0x03; // All pins on port 0 to low except for P0.0 and P0.1 (buttons)
      P1 = 0;   // All pins on port 1 to low
      P2 = 0;   // All pins on port 2 to low
    #endif // #if defined( CC2540_MINIDK )
      #if defined (HAL_IMAGE_A)
        HalLcdWriteStringValue( "BLE Peri-A", OAD_VER_NUM( _imgHdr.ver ), 16, HAL_LCD_LINE_1 );
      #else
        HalLcdWriteStringValue( "BLE Peri-B", OAD_VER_NUM( _imgHdr.ver ), 16, HAL_LCD_LINE_1 );
      #endif // HAL_IMAGE_A
    #else
      HalLcdWriteString( "BLE Peripheral", HAL_LCD_LINE_1 );
    #endif // FEATURE_OAD
      // Register callback with SimpleGATTprofile
      VOID SimpleProfile_RegisterAppCBs( &simpleBLEPeripheral_SimpleProfileCBs );
      // Enable clock divide on halt
      // This reduces active current while radio is active and CC254x MCU
      // is halted
      HCI_EXT_ClkDivOnHaltCmd( HCI_EXT_ENABLE_CLK_DIVIDE_ON_HALT );
    #if defined ( DC_DC_P0_7 )
      // Enable stack to toggle bypass control on TPS62730 (DC/DC converter)
      HCI_EXT_MapPmIoPortCmd( HCI_EXT_PM_IO_PORT_P0, HCI_EXT_PM_IO_PORT_PIN7 );
    #endif // defined ( DC_DC_P0_7 )
      accInit();
    #endif
        ANBT_I2C_Configuration();        //IIC初始化
        AnBT_DMP_Delay_ms(30);
        AnBT_DMP_MPU6050_Init();            //6050DMP初始化
    #endif
    //10  标志SBP_START_DEVICE_EVT启动该event
      // Setup a delayed profile startup
      osal_set_event( simpleBLEPeripheral_TaskID, SBP_START_DEVICE_EVT );
     * @fn      SimpleBLEPeripheral_ProcessEvent
     * @brief   Simple BLE Peripheral Application Task event processor.  This function
     *          is called to process all events for the task.  Events
     *          include timers, messages and any other user defined events.
     * @param   task_id  - The OSAL assigned task ID.
     * @param   events - events to process.  This is a bit map and can
     *                   contain more than one event.
     * @return  events not processed
    uint16 SimpleBLEPeripheral_ProcessEvent( uint8 task_id, uint16 events )
      VOID task_id; // OSAL required parameter that isn't used in this function
      if ( events & SYS_EVENT_MSG )
        uint8 *pMsg;
        if ( (pMsg = osal_msg_receive( simpleBLEPeripheral_TaskID )) != NULL )
          simpleBLEPeripheral_ProcessOSALMsg( (osal_event_hdr_t *)pMsg );
          // Release the OSAL message
          VOID osal_msg_deallocate( pMsg );
        // return unprocessed events
        return (events ^ SYS_EVENT_MSG);
      if ( events & SBP_START_DEVICE_EVT )
        // Start the Device
        VOID GAPRole_StartDevice( &simpleBLEPeripheral_PeripheralCBs );
        // Start Bond Manager
        VOID GAPBondMgr_Register( &simpleBLEPeripheral_BondMgrCBs );
        // Set timer for first periodic event
        osal_start_timerEx( simpleBLEPeripheral_TaskID, SBP_PERIODIC_EVT, SBP_PERIODIC_EVT_PERIOD );
        return ( events ^ SBP_START_DEVICE_EVT );
      if ( events & SBP_PERIODIC_EVT )
        // Restart timer
        if ( SBP_PERIODIC_EVT_PERIOD )
        // Perform periodic application task
        performPeriodicTask();
        return (events ^ SBP_PERIODIC_EVT);
      if ( events & SBP_ADV_IN_CONNECTION_EVT )
        uint8 turnOnAdv = TRUE;
        // Turn on advertising while in a connection
        GAPRole_SetParameter( GAPROLE_ADVERT_ENABLED, sizeof( uint8 ), &turnOnAdv );
        return (events ^ SBP_ADV_IN_CONNECTION_EVT);
    #endif // PLUS_BROADCASTER
      // Discard unknown events
      return 0;
     * @fn      simpleBLEPeripheral_ProcessOSALMsg
     * @brief   Process an incoming task message.
     * @param   pMsg - message to process
     * @return  none
      switch ( pMsg->event )
        case KEY_CHANGE:
          simpleBLEPeripheral_HandleKeys( ((keyChange_t *)pMsg)->state, ((keyChange_t *)pMsg)->keys );
          break;
      default:
        // do nothing
        break;
     * @fn      simpleBLEPeripheral_HandleKeys
     * @brief   Handles all key events for this device.
     * @param   shift - true if in shift/alt.
     * @param   keys - bit field for key events. Valid entries:
     *                 HAL_KEY_SW_2
     *                 HAL_KEY_SW_1
     * @return  none
      uint8 SK_Keys = 0;
      VOID shift;  // Intentionally unreferenced parameter
      if ( keys & HAL_KEY_SW_1 )
        SK_Keys |= SK_KEY_LEFT;
      if ( keys & HAL_KEY_SW_2 )
        SK_Keys |= SK_KEY_RIGHT;
        // if device is not in a connection, pressing the right key should toggle
        // advertising on and off
        if( gapProfileState != GAPROLE_CONNECTED )
          uint8 current_adv_enabled_status;
          uint8 new_adv_enabled_status;
          //Find the current GAP advertisement status
          GAPRole_GetParameter( GAPROLE_ADVERT_ENABLED, &current_adv_enabled_status );
          if( current_adv_enabled_status == FALSE )
            new_adv_enabled_status = TRUE;
          else
            new_adv_enabled_status = FALSE;
          //change the GAP advertisement status to opposite of current status
          GAPRole_SetParameter( GAPROLE_ADVERT_ENABLED, sizeof( uint8 ), &new_adv_enabled_status );
      // Set the value of the keys state to the Simple Keys Profile;
      // This will send out a notification of the keys state if enabled
      SK_SetParameter( SK_KEY_ATTR, sizeof ( uint8 ), &SK_Keys );
     * @fn      peripheralStateNotificationCB
     * @brief   Notification from the profile of a state change.
     * @param   newState - new state
     * @return  none
      switch ( newState )
        case GAPROLE_STARTED:
            uint8 ownAddress[B_ADDR_LEN];
            uint8 systemId[DEVINFO_SYSTEM_ID_LEN];
            GAPRole_GetParameter(GAPROLE_BD_ADDR, ownAddress);
            // use 6 bytes of device address for 8 bytes of system ID value
            systemId[0] = ownAddress[0];
            systemId[1] = ownAddress[1];
            systemId[2] = ownAddress[2];
            // set middle bytes to zero
            systemId[4] = 0x00;
            systemId[3] = 0x00;
            // shift three bytes up
            systemId[7] = ownAddress[5];
            systemId[6] = ownAddress[4];
            systemId[5] = ownAddress[3];
            DevInfo_SetParameter(DEVINFO_SYSTEM_ID, DEVINFO_SYSTEM_ID_LEN, systemId);
              // Display device address
              HalLcdWriteString( bdAddr2Str( ownAddress ),  HAL_LCD_LINE_2 );
              HalLcdWriteString( "Initialized",  HAL_LCD_LINE_3 );
          break;
        case GAPROLE_ADVERTISING:
              HalLcdWriteString( "Advertising",  HAL_LCD_LINE_3 );
          break;
        case GAPROLE_CONNECTED:
              HalLcdWriteString( "Connected",  HAL_LCD_LINE_3 );
          break;
        case GAPROLE_WAITING:
              HalLcdWriteString( "Disconnected",  HAL_LCD_LINE_3 );
          break;
        case GAPROLE_WAITING_AFTER_TIMEOUT:
              HalLcdWriteString( "Timed Out",  HAL_LCD_LINE_3 );
          break;
        case GAPROLE_ERROR:
              HalLcdWriteString( "Error",  HAL_LCD_LINE_3 );
          break;
        default:
              HalLcdWriteString( "",  HAL_LCD_LINE_3 );
          break;
      gapProfileState = newState;
    #if !defined( CC2540_MINIDK )
      VOID gapProfileState;     // added to prevent compiler warning with
                                // "CC2540 Slave" configurations
    #endif
    #define BYTE0(x)   (x&0xff)
    #define BYTE1(x)   (x>>8)
    /*函数功能:根据匿名最新上位机协议写的显示姿态的程序
     *具体原理看匿名的讲解视频
    void Data_Send_Status(float Pitch,float Roll,float Yaw,short *gyro,short *accel)
        unsigned char i=0;
        unsigned char _cnt=0,sum = 0;
        unsigned int _temp;
        u8 data_to_send[50];
        data_to_send[_cnt++]=0xAA;
        data_to_send[_cnt++]=0x01;
        data_to_send[_cnt++]=0;
        _temp = (int)(Roll*100);
        data_to_send[_cnt++]=BYTE1(_temp);
        data_to_send[_cnt++]=BYTE0(_temp);
        _temp = 0-(int)(Pitch*100);
        _temp = (int)(Yaw*100);
        data_to_send[3] = _cnt-4;
        //和校验
        for(i=0;i<_cnt;i++)
            sum+= data_to_send[i];
        data_to_send[_cnt++]=sum;
        //串口发送数据
        //for(i=0;i<_cnt;i++)
        //    AnBT_Uart1_Send_Char(data_to_send[i]);
        //NPI_WriteTransport(data_to_send, _cnt);
        sprintf(data_to_send, "%.2f,%.2f,%.2f\r\n", Pitch,Roll,Yaw);
        NPI_PrintString(data_to_send);
    #endif
     * @fn      performPeriodicTask
     * @brief   Perform a periodic application task. This function gets
     *          called every five seconds as a result of the SBP_PERIODIC_EVT
     *          OSAL event. In this example, the value of the third
     *          characteristic in the SimpleGATTProfile service is retrieved
     *          from the profile, and then copied into the value of the
     *          the fourth characteristic.
     * @param   none
     * @return  none
        //uint8 returnBytes;
            uint16 numBytes;
            char pktBuffer[64];
            int8 XAcc, YAcc, ZAcc;
            int8 XGro, YGro, ZGro;
            HAL_DISABLE_INTERRUPTS(); //关中断
            accReadAccGro(&XAcc, &YAcc, &ZAcc, &XGro, &YGro, &ZGro);
            HAL_ENABLE_INTERRUPTS();  //开中断
            sprintf((char *)pktBuffer, "%d,%d,%d,%d,%d,%d", XAcc, YAcc, ZAcc, XGro, YGro, ZGro);
    #if (HAL_UART==TRUE)  // 串口打印
            NPI_PrintString((uint8*)pktBuffer);
            NPI_PrintString("\r\n");
    #endif
            // 发送数据到主机
            if(gapProfileState == GAPROLE_CONNECTED)
                numBytes = osal_strlen((char *)pktBuffer);
                if(numBytes > SIMPLEPROFILE_CHAR6_LEN)
                    numBytes = SIMPLEPROFILE_CHAR6_LEN;
                simpleBLE_SendData((uint8*)pktBuffer, numBytes);
    #else
     // uint8 valueToCopy;
     // uint8 stat;
      // Call to retrieve the value of the third characteristic in the profile
      //stat = SimpleProfile_GetParameter( SIMPLEPROFILE_CHAR3, &valueToCopy, &returnBytes);
      //if( stat == SUCCESS )
         * Call to set that value of the fourth characteristic in the profile. Note
         * that if notifications of the fourth characteristic have been enabled by
         * a GATT client device, then a notification will be sent every time this
         * function is called.
        //SimpleProfile_SetParameter( SIMPLEPROFILE_CHAR4, sizeof(uint8), &valueToCopy);
    #endif
        if(1)
    #define q30  1073741824.0f
            unsigned long sensor_timestamp;
            short gyro[3], accel[3], sensors = INV_WXYZ_QUAT;//陀螺仪存放数组,加速度存放数组,返回状态量
            unsigned char more;
            long quat[4];//四元数存放数组
            float Yaw=0.00,Roll,Pitch;//欧拉角
            float q0=1.0f,q1=0.0f,q2=0.0f,q3=0.0f;//计算姿态过程用到的变量
            dmp_read_fifo(gyro, accel, quat, &sensor_timestamp, &sensors,&more);
    #if 1
            if(sensors&INV_WXYZ_QUAT)
                q0=quat[0] / q30;
                q1=quat[1] / q30;
                q2=quat[2] / q30;
                q3=quat[3] / q30;
                Pitch = asin(-2 * q1 * q3 + 2 * q0* q2)* 57.3; // pitch
                Roll = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2* q2 + 1)* 57.3; // roll
                Yaw =     atan2(2*(q1*q2 + q0*q3),q0*q0+q1*q1-q2*q2-q3*q3) * 57.3;        //感觉没有价值,注掉
                //printf("pitch: %.2f    roll:%.2f        yaw:%.2f\r\n",Pitch,Roll,Yaw);        //普通串口输出
                //Data_Send_Status(Pitch,Roll,Yaw,gyro,accel);
                //delay_init(72);
                    sprintf(data_to_send, "++%.2f,%.2f,%.2f\r\n", Pitch,Roll,Yaw);
                    // 打印到串口
                    // 发送数据到主机
                        int numBytes = osal_strlen((char *)data_to_send);
                        simpleBLE_SendData((uint8*)data_to_send, numBytes);
    #else
                // below calculations unnecessary for orientation only using toxilibs
                //long quaternion[4];    //我传给你的四元数 整型
                float gravity[3];
                float euler[3];
                float ypr[3];
                float q[3];
                q[0]=quat[0] / 16384.0f;
                q[1]=quat[1] / 16384.0f;
                q[2]=quat[2] / 16384.0f;
                q[3]=quat[3] / 16384.0f;
                // calculate gravity vector
                gravity[0] = 2 * (q[1]*q[3] - q[0]*q[2]);
                gravity[1] = 2 * (q[0]*q[1] + q[2]*q[3]);
                gravity[2] = q[0]*q[0] - q[1]*q[1] - q[2]*q[2] + q[3]*q[3];
                // calculate Euler angles
                euler[0] = atan2(2*q[1]*q[2] - 2*q[0]*q[3], 2*q[0]*q[0] + 2*q[1]*q[1] - 1);
                euler[1] = -asin(2*q[1]*q[3] + 2*q[0]*q[2]);
                euler[2] = atan2(2*q[2]*q[3] - 2*q[0]*q[1], 2*q[0]*q[0] + 2*q[3]*q[3] - 1);
                // calculate yaw/pitch/roll angles
                ypr[0] = atan2(2*q[1]*q[2] - 2*q[0]*q[3], 2*q[0]*q[0] + 2*q[1]*q[1] - 1);
                ypr[1] = atan(gravity[0] / sqrt(gravity[1]*gravity[1] + gravity[2]*gravity[2]));
                ypr[2] = atan(gravity[1] / sqrt(gravity[0]*gravity[0] + gravity[2]*gravity[2]));
                    uint8 str[128];
                    sprintf(str, "ypr[0]: %.2f, ypr[1]:%.2f, ypr[2]:%.2f\r\n",ypr[0], ypr[1],ypr[2]);        //普通串口输出
                    NPI_PrintString((uint8*)str);
    #endif
    #endif
     * @fn      simpleProfileChangeCB
     * @brief   Callback from SimpleBLEProfile indicating a value change
     * @param   paramID - parameter ID of the value that was changed.
     * @return  none
      uint8 newValue;
      uint8 newValueBuf[20]={0};
      uint8 returnBytes;
      switch( paramID )
        case SIMPLEPROFILE_CHAR1:
          //SimpleProfile_GetParameter( SIMPLEPROFILE_CHAR1, &newValue );
          SimpleProfile_GetParameter( SIMPLEPROFILE_CHAR1, newValueBuf, &returnBytes );
            //HalLcdWriteStringValue( "Char 1:", (uint16)(newValue), 10,  HAL_LCD_LINE_3 );
            HalLcdWriteString((char*)newValueBuf, HAL_LCD_LINE_4 );
          break;
        case SIMPLEPROFILE_CHAR3:
          SimpleProfile_GetParameter( SIMPLEPROFILE_CHAR3, &newValue, &returnBytes );
            HalLcdWriteStringValue( "Char 3:", (uint16)(newValue), 10,  HAL_LCD_LINE_3 );
          break;
        // AmoMcu 添加的代码, 表示收到主机对 CHAR6 特征值发送过来的数据了
        case SIMPLEPROFILE_CHAR6:
              uint8 newChar6Value[SIMPLEPROFILE_CHAR6_LEN];
              SimpleProfile_GetParameter( SIMPLEPROFILE_CHAR6, newChar6Value, &returnBytes );
              if(returnBytes > 0)
                NPI_WriteTransport(newChar6Value,returnBytes);
          break;
        default:
          // should not reach here!
          break;
     * @fn      bdAddr2Str
     * @brief   Convert Bluetooth address to string. Only needed when
     *          LCD display is used.
     * @return  none
    char *bdAddr2Str( uint8 *pAddr )
      uint8       i;
      char        hex[] = "0123456789ABCDEF";
      static char str[B_ADDR_STR_LEN];
      char        *pStr = str;
      *pStr++ = '0';
      *pStr++ = 'x';
      // Start from end of addr
      pAddr += B_ADDR_LEN;
      for ( i = B_ADDR_LEN; i > 0; i-- )
        *pStr++ = hex[*--pAddr >> 4];
        *pStr++ = hex[*pAddr & 0x0F];
      *pStr = 0;
      return str;
    // 发送数据到主机----使用自定义的CHAR6
        if( GAPROLE_CONNECTED == gapProfileState) // 已连接上
    #if 0// 直接通过串口返回
             NPI_WriteTransport(buffer, sendBytes);
    #else// 通过CHAR6 特征值发送出去, 这里有两种方法
    #if 0 // 这种速度慢 SimpleProfile_SetParameter
            //simpleBLEChar6DoWrite2 = FALSE;
            SimpleProfile_SetParameter( SIMPLEPROFILE_CHAR6,numBytes, buf );
    #else // 这种速度快 GATT_Notification
            static attHandleValueNoti_t pReport;
            pReport.len = sendBytes;
    // 也许您会纳闷这个值 0x0035 怎么来的,实际上,Amo我也比较郁闷, 那实际上,
    我是通过 主机连接这个从机后获得的, 然后再写到这里来, 作为通知的handle值,
    -------------AmoMcu   2014.08.17  ---------------------------------------------
            pReport.handle = 0x0035;
            osal_memcpy(pReport.value, buffer, sendBytes);
            GATT_Notification( 0, &pReport, FALSE );
    #endif
    #endif
        else
             NPI_WriteTransport("Not Connected\r\n", 15);
        (void)port;
        if (events & (HAL_UART_RX_TIMEOUT | HAL_UART_RX_FULL))   //串口有数据
            uint8 numBytes = 0;
            numBytes = NPI_RxBufLen();           //读出串口缓冲区有多少字节
            if(numBytes > 0)
                uint8 *buffer = osal_mem_alloc(numBytes);
                if(buffer)
                    NPI_ReadTransport(buffer,numBytes);
                    NPI_WriteTransport(buffer,numBytes);
                    osal_mem_free(buffer);
  • 您可以参考下附件中的
    SerialApp.zip
