问一下CC1310的触摸功能怎么实现?
/* * Copyright (c) 2015-2016, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* * ======== gpiointerrupt.c ======== */ #include <stdint.h> #include <stddef.h> /* Driver Header files */ #include <ti/drivers/GPIO.h> /* Example/Board Header files */ #include "Board.h" /* variable to be read by GUI Composer */ int count = 0; /* * ======== gpioButtonFxn0 ======== * Callback function for the GPIO interrupt on Board_GPIO_BUTTON0. */ void gpioButtonFxn0(uint_least8_t index) { /* Clear the GPIO interrupt and toggle an LED */ GPIO_toggle(Board_GPIO_LED0); if (count++ == 100) { count = 0; } } /* * ======== gpioButtonFxn1 ======== * Callback function for the GPIO interrupt on Board_GPIO_BUTTON1. * This may not be used for all boards. */ void gpioButtonFxn1(uint_least8_t index) { /* Clear the GPIO interrupt and toggle an LED */ GPIO_toggle(Board_GPIO_LED1); if (count++ == 100) { count = 0; } } /* * ======== mainThread ======== */ void *mainThread(void *arg0) { /* Call driver init functions */ GPIO_init(); /* Turn on user LED */ GPIO_write(Board_GPIO_LED0, Board_GPIO_LED_ON); /* install Button callback */ GPIO_setCallback(Board_GPIO_BUTTON0, gpioButtonFxn0); /* Enable interrupts */ GPIO_enableInt(Board_GPIO_BUTTON0); /* * If more than one input pin is available for your device, interrupts * will be enabled on Board_GPIO_BUTTON1. */ if (Board_GPIO_BUTTON0 != Board_GPIO_BUTTON1) { /* Install Button callback */ GPIO_setCallback(Board_GPIO_BUTTON1, gpioButtonFxn1); GPIO_enableInt(Board_GPIO_BUTTON1); } return (NULL); }
你可能没有理解我的意思,我现在想用CC1310这个芯片来做一个新产品,这个新产品需要1~3个电容式触摸按键,我不知道程序上需要怎么做才能实现用CC1310这个芯片的IO口去检测电容式触摸按键
