Other Parts Discussed in Thread: EK-TM4C1294XL
本人第一次搞网络,很多都不懂。下面我的代码以及调试过程,请帮忙看一下是否有问题,谢谢!
// enet_lwip.c - Sample WebServer Application using lwIP.
// Copyright (c) 2013-2016 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.3.156 of the EK-TM4C1294XL Firmware Package.
#include <stdbool.h>
#include <stdint.h>
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "driverlib/flash.h"
#include "driverlib/interrupt.h"
#include "driverlib/gpio.h"
#include "driverlib/rom_map.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "utils/locator.h"
#include "utils/lwiplib.h"
#include "utils/ustdlib.h"
#include "utils/uartstdio.h"
#include "httpserver_raw/httpd.h"
#include "drivers/pinout.h"
#include "udp_echoserver.h"
#include <stdint.h>
//! \addtogroup example_list
//! <h1>Ethernet with lwIP (enet_lwip)</h1>
//! This example application demonstrates the operation of the Tiva
//! Ethernet controller using the lwIP TCP/IP Stack. DHCP is used to obtain
//! an Ethernet address. If DHCP times out without obtaining an address,
//! AutoIP will be used to obtain a link-local address. The address that is
//! selected will be shown on the UART.
//! UART0, connected to the ICDI virtual COM port and running at 115,200,
//! 8-N-1, is used to display messages from this application. Use the
//! following command to re-build the any file system files that change.
//! ../../../../tools/bin/makefsfile -i fs -o enet_fsdata.h -r -h -q
//! For additional details on lwIP, refer to the lwIP web page at:
//! savannah.nongnu.org/.../
// Defines for setting up the system clock.
#define SYSTICKHZ 100
#define SYSTICKMS (1000 / SYSTICKHZ)
// Interrupt priority definitions. The top 3 bits of these values are
// significant with lower values indicating higher priority interrupts.
#define SYSTICK_INT_PRIORITY 0x80
#define ETHERNET_INT_PRIORITY 0xC0
// The current IP address.
uint32_t g_ui32IPAddress;
// The system clock frequency.
uint32_t g_ui32SysClock;
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, uint32_t ui32Line)
#endif
#ifdef DEBUG
void
#endif
// Display an lwIP type IP Address.
void
DisplayIPAddress(uint32_t ui32Addr)
char pcBuf[16];
void
char pcBuf[16];
// Convert the IP Address into a string.
usprintf(pcBuf, "%d.%d.%d.%d", ui32Addr & 0xff, (ui32Addr >> 8) & 0xff,
(ui32Addr >> 16) & 0xff, (ui32Addr >> 24) & 0xff);
// Display the string.
UARTprintf(pcBuf);
UARTprintf(pcBuf);
// Required by lwIP library to support any host-related timer functions.
void
lwIPHostTimerHandler(void)
uint32_t ui32Idx, ui32NewIPAddress;
void
// Get the current IP address.
ui32NewIPAddress = lwIPLocalIPAddrGet();
// See if the IP address has changed.
if(ui32NewIPAddress != g_ui32IPAddress)
// See if there is an IP address assigned.
if(ui32NewIPAddress == 0xffffffff)
// Indicate that there is no link.
UARTprintf("Waiting for link.\n");
else if(ui32NewIPAddress == 0)
// There is no IP address, so indicate that the DHCP process is
// running.
UARTprintf("Waiting for IP address.\n");
else
// Display the new IP address.
UARTprintf("IP Address: ");
DisplayIPAddress(ui32NewIPAddress);
UARTprintf("\nOpen a browser and enter the IP address.\n");
// UARTprintf("ip:%d,%d,%d,%d\r\n",(uint8_t)(ui32NewIPAddress >> 0),
// (uint8_t)(ui32NewIPAddress >> 8),
// (uint8_t)(ui32NewIPAddress >> 16),
// (uint8_t)ui32NewIPAddress>>24);
// running.
else
// Save the new IP address.
g_ui32IPAddress = ui32NewIPAddress;
// Turn GPIO off.
MAP_GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_1, ~GPIO_PIN_1);
// Turn GPIO off.
// If there is not an IP address.
if((ui32NewIPAddress == 0) || (ui32NewIPAddress == 0xffffffff))
// Loop through the LED animation.
for(ui32Idx = 1; ui32Idx < 17; ui32Idx++)
// Toggle the GPIO
(MAP_GPIOPinRead(GPIO_PORTN_BASE, GPIO_PIN_1) ^
GPIO_PIN_1));
// Toggle the GPIO
GPIO_PIN_1));
SysCtlDelay(g_ui32SysClock/(ui32Idx << 1));
// The interrupt handler for the SysTick interrupt.
void
SysTickIntHandler(void)
// Call the lwIP timer handler.
lwIPTimer(SYSTICKMS);
void
// This example demonstrates the use of the Ethernet Controller.
int
main(void)
uint32_t ui32User0, ui32User1;
uint8_t pui8MACArray[8];
int
main(void)
// Make sure the main oscillator is enabled because this is required by
// the PHY. The system must have a 25MHz crystal attached to the OSC
// pins. The SYSCTL_MOSC_HIGHFREQ parameter is used when the crystal
// frequency is 10MHz or higher.
SysCtlMOSCConfigSet(SYSCTL_MOSC_HIGHFREQ);
// Run from the PLL at 120 MHz.
g_ui32SysClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
SYSCTL_OSC_MAIN |
SYSCTL_USE_PLL |
SYSCTL_CFG_VCO_480), 120000000);
SYSCTL_OSC_MAIN |
SYSCTL_USE_PLL |
// Configure the device pins.
PinoutSet(true, false);
// Configure UART.
UARTStdioConfig(0, 115200, g_ui32SysClock);
// Configure UART.
// Clear the terminal and print banner.
UARTprintf("Ethernet lwIP example\n");
// Configure Port N1 for as an output for the animation LED.
MAP_GPIOPinTypeGPIOOutput(GPIO_PORTN_BASE, GPIO_PIN_1);
// Initialize LED to OFF (0)
// Configure SysTick for a periodic interrupt.
MAP_SysTickPeriodSet(g_ui32SysClock / SYSTICKHZ);
MAP_SysTickEnable();
MAP_SysTickIntEnable();
// Configure the hardware MAC address for Ethernet Controller filtering of
// incoming packets. The MAC address will be stored in the non-volatile
// USER0 and USER1 registers.
MAP_FlashUserGet(&ui32User0, &ui32User1);
if((ui32User0 == 0xffffffff) || (ui32User1 == 0xffffffff))
// We should never get here. This is an error if the MAC address has
// not been programmed into the device. Exit the program.
// Let the user know there is no MAC address
UARTprintf("No MAC programmed!\n");
while(1)
while(1)
// Tell the user what we are doing just now.
UARTprintf("Waiting for IP.\n");
// Convert the 24/24 split MAC address from NV ram into a 32/16 split MAC
// address needed to program the hardware registers, then program the MAC
// address into the Ethernet Controller registers.
pui8MACArray[0] = ((ui32User0 >> 0) & 0xff);
pui8MACArray[1] = ((ui32User0 >> 8) & 0xff);
pui8MACArray[2] = ((ui32User0 >> 16) & 0xff);
pui8MACArray[3] = ((ui32User1 >> 0) & 0xff);
pui8MACArray[4] = ((ui32User1 >> 8) & 0xff);
pui8MACArray[5] = ((ui32User1 >> 16) & 0xff);
// Initialize the lwIP library, using DHCP.
//lwIPInit(g_ui32SysClock, pui8MACArray, 0, 0, 0, IPADDR_USE_DHCP);
lwIPInit(g_ui32SysClock, pui8MACArray, 0xACA80105, 0xFFFFFF00, 0xACA801FE, IPADDR_USE_STATIC);
// Setup the device locator service.
//LocatorInit();
//LocatorMACAddrSet(pui8MACArray);
//LocatorAppTitleSet("EK-TM4C1294XL enet_io");
//LocatorInit();
// Initialize a sample httpd server.
//httpd_init();
//httpd_init();
udp_echoserver_init();
// Set the interrupt priorities. We set the SysTick interrupt to a higher
// priority than the Ethernet interrupt to ensure that the file system
// tick is processed if SysTick occurs while the Ethernet handler is being
// processed. This is very likely since all the TCP/IP and HTTP work is
// done in the context of the Ethernet interrupt.
MAP_IntPrioritySet(INT_EMAC0, ETHERNET_INT_PRIORITY);
MAP_IntPrioritySet(FAULT_SYSTICK, SYSTICK_INT_PRIORITY);
// Loop forever. All the work is done in interrupt handlers.
while(1)
while(1)
