TM4C CAN 模块怎么设置接收滤波的?
如题,我实在是比较笨的,看ti的datashet的也是云里雾里,请了解的指点一下。先谢过了。
  • 可以看看库文档中的这个例程,应该是定义一个
    tCANMsgObject sMsgObjectRx;
    tCANMsgObject sMsgObjectTx;
    然后赋值就可以了
    // Configure a receive object.
    sMsgObjectRx.ulMsgID = (0x400);
    sMsgObjectRx.ulMsgIDMask = 0x7f8;
    sMsgObjectRx.ulFlags = MSG_OBJ_USE_ID_FILTER | MSG_OBJ_FIFO;
    // The first three message objects have the MSG_OBJ_FIFO set to indicate // that they are part of a FIFO.
    CANMessageSet(CAN0_BASE, 1, &sMsgObjectRx, MSG_OBJ_TYPE_RX); CANMessageSet(CAN0_BASE, 2, &sMsgObjectRx, MSG_OBJ_TYPE_RX); CANMessageSet(CAN0_BASE, 3, &sMsgObjectRx, MSG_OBJ_TYPE_RX);
  • 您可以看一下
    e2e.ti.com/.../532199
    给出的代码
