MSP432P401R: 如何配置系统时钟为48M HZ
Part Number: MSP432P401R
无
  • 我们有几个演示可供您参考:
    https://dev.ti.com/tirex/explore/node?node=AD7fp0zahQovr1tZ1p6Qbw__z-lQYNj__LATEST
    这些示例使用了我们的一些 Booster Packs,例如 EDUMKII。在main.c中可以找到时钟系统初始化(EDUMKII Accelerometer demo)
    void main(void)
        /* Halting WDT and disabling master interrupts */
        MAP_WDT_A_holdTimer();
        MAP_Interrupt_disableMaster();
        /* Set the core voltage level to VCORE1 */
        MAP_PCM_setCoreVoltageLevel(PCM_VCORE1);
        /* Set 2 flash wait states for Flash bank 0 and 1*/
        MAP_FlashCtl_setWaitState(FLASH_BANK0, 2);
        MAP_FlashCtl_setWaitState(FLASH_BANK1, 2);
        /* Initializes Clock System */
        MAP_CS_setDCOCenteredFrequency(CS_DCO_FREQUENCY_48);
        MAP_CS_initClockSignal(CS_MCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_1 );
        MAP_CS_initClockSignal(CS_HSMCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_1 );
        MAP_CS_initClockSignal(CS_SMCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_1 );
        MAP_CS_initClockSignal(CS_ACLK, CS_REFOCLK_SELECT, CS_CLOCK_DIVIDER_1);
