SM470R1B1M-HT: IAR J-Link下载程序失败
Part Number: SM470R1B1M-HT
请帮忙分析一下,谢谢
芯片批次  3BAC  1812A
Debug Log如下:
Fri Oct 22, 2021 08:10:03: IAR Embedded Workbench 8.32.1 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\bin\armproc.dll)
Fri Oct 22, 2021 08:10:03: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\TexasInstruments\FlashSM470R1B1M.mac
Fri Oct 22, 2021 08:10:03: JLINK command: ProjectFile = D:\Workspace\IAR_ARM\SM470_OS_10-02_10-53\Project\settings\SM470_Debug.jlink, return = 0
Fri Oct 22, 2021 08:10:03: Device "SM470R1B1M" selected.
Fri Oct 22, 2021 08:10:03: DLL version: V6.14a, compiled Feb 27 2017 18:41:26
Fri Oct 22, 2021 08:10:03: Firmware: J-Link V9 compiled Dec 13 2019 11:14:50
Fri Oct 22, 2021 08:10:03: JTAG speed is initially set to: 1000 kHz
Fri Oct 22, 2021 08:10:03: TotalIRLen = 4, IRPrint = 0x01
Fri Oct 22, 2021 08:10:03: Hardware reset with strategy 0 was performed
Fri Oct 22, 2021 08:10:03: Initial reset was performed
Fri Oct 22, 2021 08:10:03: Found 1 JTAG device, Total IRLen = 4:
Fri Oct 22, 2021 08:10:03: #0 Id: 0x3100E02F, IRLen: 4, IRPrint: 0x1 ARM7TDMI Core
Fri Oct 22, 2021 08:10:03: J-Link found 1 JTAG device(s). ARM core Id: 3100E02F ARM7
Fri Oct 22, 2021 08:10:03: execUserFlashInit
Fri Oct 22, 2021 08:10:03: Executing memory setup macro dddd B1M Flash
Fri Oct 22, 2021 08:10:03: Adaptive clocking not supported for selected CPU core. Only supported for -S cores.
Fri Oct 22, 2021 08:10:03: Auto JTAG speed: 8000 kHz
Fri Oct 22, 2021 08:10:03: 3456 bytes downloaded and verified (35.90 Kbytes/sec)
Fri Oct 22, 2021 08:10:03: Warning:
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400080, target byte: 0xCF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400081, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400082, target byte: 0xDB, byte in file: 0x0C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400083, target byte: 0xFF, byte in file: 0xDD
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400084, target byte: 0xCF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400085, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400086, target byte: 0xDB, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400087, target byte: 0xFF, byte in file: 0x04
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400088, target byte: 0xCF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400089, target byte: 0xDD, byte in file: 0x40
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008A, target byte: 0xDB, byte in file: 0xFD
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008B, target byte: 0xFF, byte in file: 0x7C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008C, target byte: 0xCF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008D, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008E, target byte: 0xDB, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008F, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400090, target byte: 0xCF, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400091, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400092, target byte: 0xDB, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400093, target byte: 0xFF, byte in file: 0x6C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400094, target byte: 0xCF, byte in file: 0x61
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400095, target byte: 0xDD, byte in file: 0x73
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400096, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400097, target byte: 0xFF, byte in file: 0x6B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400098, target byte: 0xCF, byte in file: 0x65
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400099, target byte: 0xDD, byte in file: 0x79
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009A, target byte: 0xDB, byte in file: 0x30
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009B, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009C, target byte: 0xCF, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009D, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009E, target byte: 0xDB, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009F, target byte: 0xFF, byte in file: 0x6C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A0, target byte: 0xCF, byte in file: 0x61
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A1, target byte: 0xDD, byte in file: 0x73
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A2, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A3, target byte: 0xFF, byte in file: 0x6B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A4, target byte: 0xCF, byte in file: 0x65
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A5, target byte: 0xDD, byte in file: 0x79
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A6, target byte: 0xDB, byte in file: 0x31
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A7, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A8, target byte: 0xCF, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A9, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AA, target byte: 0xDB, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AB, target byte: 0xFF, byte in file: 0x6C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AC, target byte: 0xCF, byte in file: 0x61
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AD, target byte: 0xDD, byte in file: 0x73
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AE, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AF, target byte: 0xFF, byte in file: 0x6B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B0, target byte: 0xCF, byte in file: 0x65
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B1, target byte: 0xDD, byte in file: 0x79
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B2, target byte: 0xDB, byte in file: 0x32
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B3, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B4, target byte: 0xCF, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B5, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B6, target byte: 0xDB, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B7, target byte: 0xFF, byte in file: 0x6C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B8, target byte: 0xCF, byte in file: 0x61
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B9, target byte: 0xDD, byte in file: 0x73
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BA, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BB, target byte: 0xFF, byte in file: 0x6B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BC, target byte: 0xCF, byte in file: 0x65
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BD, target byte: 0xDD, byte in file: 0x79
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BE, target byte: 0xDB, byte in file: 0x33
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BF, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C0, target byte: 0xCF, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C1, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C2, target byte: 0xDB, byte in file: 0x63
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C3, target byte: 0xFF, byte in file: 0x6C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C4, target byte: 0xCF, byte in file: 0x6F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C5, target byte: 0xDD, byte in file: 0x63
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C6, target byte: 0xDB, byte in file: 0x6B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C7, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C8, target byte: 0xCF, byte in file: 0xB5
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C9, target byte: 0xDD, byte in file: 0xF1
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CA, target byte: 0xDB, byte in file: 0x9F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CB, target byte: 0xFF, byte in file: 0x06
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CC, target byte: 0xCF, byte in file: 0xF0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CD, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CE, target byte: 0xDB, byte in file: 0xF9
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CF, target byte: 0xFF, byte in file: 0x16
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D0, target byte: 0xCF, byte in file: 0x24
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D1, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D2, target byte: 0xDB, byte in file: 0x2F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D3, target byte: 0xFF, byte in file: 0x01
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D4, target byte: 0xCF, byte in file: 0xDB
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D5, target byte: 0xDD, byte in file: 0x1B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D6, target byte: 0xDB, byte in file: 0x9D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D7, target byte: 0xFF, byte in file: 0x07
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D8, target byte: 0xCF, byte in file: 0x1C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D9, target byte: 0xDD, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DA, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DB, target byte: 0xFF, byte in file: 0x29
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DC, target byte: 0xCF, byte in file: 0x48
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DD, target byte: 0xDD, byte in file: 0x7F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DE, target byte: 0xDB, byte in file: 0xF0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DF, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E0, target byte: 0xCF, byte in file: 0xF9
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E1, target byte: 0xDD, byte in file: 0x1D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E2, target byte: 0xDB, byte in file: 0x28
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E3, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E4, target byte: 0xCF, byte in file: 0xD1
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E5, target byte: 0xDD, byte in file: 0x0F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E6, target byte: 0xDB, byte in file: 0x42
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E7, target byte: 0xFF, byte in file: 0xBE
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E8, target byte: 0xCF, byte in file: 0xDA
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E9, target byte: 0xDD, byte in file: 0x11
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000EA, target byte: 0xDB, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000EB, target byte: 0xFF, byte in file: 0xA0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000EC, target byte: 0xCF, byte in file: 0x99
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000ED, target byte: 0xDD, byte in file: 0x07
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000EE, target byte: 0xDB, byte in file: 0x18
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000EF, target byte: 0xFF, byte in file: 0x08
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F0, target byte: 0xCF, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F1, target byte: 0xDD, byte in file: 0x40
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F2, target byte: 0xDB, byte in file: 0x28
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F3, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F4, target byte: 0xCF, byte in file: 0xD0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F5, target byte: 0xDD, byte in file: 0x0B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F6, target byte: 0xDB, byte in file: 0x22
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F7, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F8, target byte: 0xCF, byte in file: 0x21
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F9, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FA, target byte: 0xDB, byte in file: 0xF0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FB, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FC, target byte: 0xCF, byte in file: 0xF9
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FD, target byte: 0xDD, byte in file: 0xE3
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FE, target byte: 0xDB, byte in file: 0x49
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FF, target byte: 0xFF, byte in file: 0x78
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400100, target byte: 0xCF, byte in file: 0x60
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400101, target byte: 0xDD, byte in file: 0x08
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400102, target byte: 0xDB, byte in file: 0x24
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400103, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400104, target byte: 0xCF, byte in file: 0xE0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400105, target byte: 0xDD, byte in file: 0x0A
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400106, target byte: 0xDB, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400107, target byte: 0xFF, byte in file: 0x34
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400108, target byte: 0xCF, byte in file: 0x1D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400109, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010A, target byte: 0xDB, byte in file: 0x42
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010B, target byte: 0xFF, byte in file: 0xBC
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010C, target byte: 0xCF, byte in file: 0xDB
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010D, target byte: 0xDD, byte in file: 0xE4
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010E, target byte: 0xDB, byte in file: 0x48
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010F, target byte: 0xFF, byte in file: 0x74
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400110, target byte: 0xCF, byte in file: 0x21
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400111, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400112, target byte: 0xDB, byte in file: 0x43
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400113, target byte: 0xFF, byte in file: 0xC9
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400114, target byte: 0xCF, byte in file: 0x60
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400115, target byte: 0xDD, byte in file: 0x01
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400116, target byte: 0xDB, byte in file: 0x24
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400117, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400118, target byte: 0xCF, byte in file: 0x2F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400119, target byte: 0xDD, byte in file: 0x01
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040011B, target byte: 0xFF, byte in file: 0x1B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040011C, target byte: 0xCF, byte in file: 0x9D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040011D, target byte: 0xDD, byte in file: 0x07
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040011E, target byte: 0xDB, byte in file: 0x1C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040011F, target byte: 0xFF, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400120, target byte: 0xCF, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400121, target byte: 0xDD, byte in file: 0x29
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400122, target byte: 0xDB, byte in file: 0x48
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400123, target byte: 0xFF, byte in file: 0x70
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400124, target byte: 0xCF, byte in file: 0xF0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400125, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400126, target byte: 0xDB, byte in file: 0xF8
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400127, target byte: 0xFF, byte in file: 0xFA
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400128, target byte: 0xCF, byte in file: 0x28
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400129, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012A, target byte: 0xDB, byte in file: 0xD1
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012B, target byte: 0xFF, byte in file: 0x0F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012C, target byte: 0xCF, byte in file: 0x42
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012D, target byte: 0xDD, byte in file: 0xBE
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012E, target byte: 0xDB, byte in file: 0xDA
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012F, target byte: 0xFF, byte in file: 0x11
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400130, target byte: 0xCF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400131, target byte: 0xDD, byte in file: 0xA0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400132, target byte: 0xDB, byte in file: 0x99
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400133, target byte: 0xFF, byte in file: 0x07
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400134, target byte: 0xCF, byte in file: 0x18
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400135, target byte: 0xDD, byte in file: 0x08
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400136, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400137, target byte: 0xFF, byte in file: 0x40
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400138, target byte: 0xCF, byte in file: 0x28
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400139, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013A, target byte: 0xDB, byte in file: 0xD0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013B, target byte: 0xFF, byte in file: 0x0B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013C, target byte: 0xCF, byte in file: 0x22
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013D, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013E, target byte: 0xDB, byte in file: 0x21
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013F, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400140, target byte: 0xCF, byte in file: 0xF0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400141, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400142, target byte: 0xDB, byte in file: 0xF9
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400143, target byte: 0xFF, byte in file: 0xC0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400144, target byte: 0xCF, byte in file: 0x49
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400145, target byte: 0xDD, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400146, target byte: 0xDB, byte in file: 0x60
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400147, target byte: 0xFF, byte in file: 0x48
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400148, target byte: 0xCF, byte in file: 0x24
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400149, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Warning: Too many verify errors, only the first 200 are displayed
Fri Oct 22, 2021 08:10:05: Fatal error: There were warnings during download of FLASH loader, see Log Window Session aborted!
Fri Oct 22, 2021 08:10:05: Failed to load flash loader: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\TexasInstruments\FlashSM470R1B1M.out
Fri Oct 22, 2021 08:10:05: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\TexasInstruments\FlashSM470R1B1M.mac
Fri Oct 22, 2021 08:10:05: IAR Embedded Workbench 8.32.1 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\bin\armproc.dll)
