Other Parts Discussed in Thread: CC3100
http://processors.wiki.ti.com/index.php/Creating_TI-RTOS_Applications_in_IAR_Embedded_Workbench
这个链接无法打开,能否提供下其他方式?
这个链接无法打开,能否提供下其他方式?
这个链接是E2E论坛帖子的链接,而且不是内部论坛,可以打开的。打开之后如下截图:
Please refer to the Quick Start Guide and/or User Guide documents in the SDK for instructions on how to import, build, and run TI-RTOS based examples on your device.
按照文档操作,Build工程的时候提示如下错误:
Error while running "d:/ti/xdctools_3_31_01_33_core/xs"
--xdcpath="d:/ti/tirtos_tivac_2_14_04_31/packages;d:/ti/tirtos_tivac_2_14_04_31/products/bios_6_42_03_35/packages;d:/ti/tirtos_tivac_2_14_04_31/products/ndk_2_2
4_03_35/packages;d:/ti/tirtos_tivac_2_14_04_31/products/uia_2_00_02_39/packages" iar.tools.configuro -c "C:\IAR\arm" --cc "C:\IAR\arm\bin\iccarm.exe" --device
"TM4C123GH6PM" --compileOptions "dummy.c -o E:\04Sensor\Project\Debug\Obj --no_cse --no_unroll --no_inline --no_code_motion --no_tbaa --no_clustering
--no_scheduling --debug --endian=little --cpu=Cortex-M4 -f E:\04Sensor\Project/configPkg/compiler.opt.defs --diag_suppress=Pa050
-Id:/ti/tirtos_tivac_2_14_04_31/products/TivaWare_C_Series-2.1.1.71b -Id:/ti/tirtos_tivac_2_14_04_31/packages/ti/drivers/wifi/cc3100/Simplelink
-Id:/ti/tirtos_tivac_2_14_04_31/packages/ti/drivers/wifi/cc3100/Simplelink/Include -DPART_TM4C123GH6PM -Dewarm -DTIVAWARE --debug --silent -e
--fpu=VFPv4_sp --dlib_config C:\IAR\arm\inc\c\DLib_Config_Normal.h -Ol" --linkOptions "--no_out_extension -o E:\04Sensor\Project\Debug\Exe\Sensor.out --map E:\
04Sensor\Project\Debug\List\Sensor.map --config C:\IAR\arm\config\linker\TexasInstruments\TM4C123GH6.icf -f E:\04Sensor\Project/configPkg/linker.cmd
d:/ti/tirtos_tivac_2_14_04_31/products/TivaWare_C_Series-2.1.1.71b/grlib/ewarm/Exe/grlib.a
d:/ti/tirtos_tivac_2_14_04_31/products/TivaWare_C_Series-2.1.1.71b/usblib/ewarm/Exe/usblib.a
d:/ti/tirtos_tivac_2_14_04_31/products/TivaWare_C_Series-2.1.1.71b/driverlib/ewarm/Exe/driverlib.a --silent --cpu=Cortex-M4F --entry=__iar_program_start --redirect
_Printf=_PrintfSmall --redirect _Scanf=_ScanfSmall --semihosting --entry __iar_program_start --vfe --text_out locale" --profile release --projFile "E:\04Sensor\Project\
Sensor.ewp"
查找了相关资料未解决该问题,请问如何解决这个问题?谢谢。
Building configuration: Sensor - Debug
Updating build tree...
Performing Pre-Build Action
Error while running "D:\ti\xdctools_3_51_01_18_core/xs"
Sensor.ewp"
Total number of errors: 1
Total number of warnings: 0
这就是Build时输出的所有信息
你好,已经为你升级英文E2E了,还请留意以下帖子回复:e2e.ti.com/.../tm4c123gh6pm-creating-ti-rtos-examples-with-iar-embedded-workbench
