ARM-CGT: When compiling the tiedl of the evm platform, adding my own compiled opencv library, I encountered a problem executing the make command in the rt directory.
Part Number: ARM-CGT
When compiling the tidl, I want to use the arm platform opencv library obtained by cross-compilation, and when the buildopencv switch is turned on. The following error occurs when executing the make command in the rt directory.
