// gpio_jtag.c - Example to demonstrate recovering the JTAG interface.
// Copyright (c) 2012 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 9453 of the EK-LM4F120XL Firmware Package.
#include "inc/hw_gpio.h"
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/debug.h"
#include "driverlib/fpu.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/pin_map.h"
#include "driverlib/rom.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "utils/uartstdio.h"
#include "drivers/buttons.h"
//! \addtogroup example_list
//! <h1>GPIO JTAG Recovery (gpio_jtag)</h1>
//! This example demonstrates changing the JTAG pins into GPIOs, along with a
//! mechanism to revert them to JTAG pins. When first run, the pins remain in
//! JTAG mode. Pressing the left button will toggle the pins between JTAG mode
//! and GPIO mode. Because there is no debouncing of the push button (either
//! in hardware or software), a button press will occasionally result in more
//! than one mode change.
//! In this example, four pins (PC0, PC1, PC2, and PC3) are switched.
//! UART0, connected to the ICDI virtual COM port and running at 115,200,
//! 8-N-1, is used to display messages from this application.
// The current mode of pins PC0, PC1, PC2, and PC3. When zero, the pins
// are in JTAG mode; when non-zero, the pins are in GPIO mode.
volatile unsigned long g_ulMode;
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, unsigned long ulLine)
#endif
// The interrupt handler for the PB4 pin interrupt. When triggered, this will
// toggle the JTAG pins between JTAG and GPIO mode.
void
SysTickIntHandler(void)
unsigned char ucButtons;
unsigned char ucButtonsChanged;
// Grab the current, debounced state of the buttons.
ucButtons = ButtonsPoll(&ucButtonsChanged, 0);
// If the left button has been pressed, and was previously not pressed,
// start the process of changing the behavior of the JTAG pins.
if(BUTTON_PRESSED(LEFT_BUTTON, ucButtons, ucButtonsChanged))
// Toggle the pin mode.
g_ulMode ^= 1;
// See if the pins should be in JTAG or GPIO mode.
if(g_ulMode == 0)
else
// Toggle the JTAG pins between JTAG and GPIO mode with a push button selecting
// between the two.
int
main(void)
unsigned long ulMode;
// Enable lazy stacking for interrupt handlers. This allows floating-point
// instructions to be used within interrupt handlers, but at the expense of
// extra stack usage.
ROM_FPULazyStackingEnable();
// Set the clocking to run directly from the crystal.
ROM_SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_XTAL_16MHZ |
SYSCTL_OSC_MAIN);
// Enable the peripherals used by this application.
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART2);
// Initialize the button driver.
ButtonsInit();
// Set up a SysTick Interrupt to handle polling and debouncing for our
// buttons.
SysTickPeriodSet(SysCtlClockGet() / 100);
SysTickIntEnable();
SysTickEnable();
IntMasterEnable();
g_ulMode = 0;
ulMode = 0;
// Configure GPIO.
//ROM_GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_3 | GPIO_PIN_1);
//ROM_GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3 | GPIO_PIN_1, GPIO_PIN_3);
// Set the global and local indicator of pin mode to zero, meaning JTAG.
// Initialize the UART.
GPIOPinConfigure(GPIO_PD6_U2RX);
GPIOPinConfigure(GPIO_PD7_U2TX);
ROM_GPIOPinTypeUART(GPIO_PORTD_BASE, GPIO_PIN_6 | GPIO_PIN_7);
UARTStdioInit(2);
// Loop forever. This loop simply exists to display on the UART the
// current state of PC0-3; the handling of changing the JTAG pins to and
// from GPIO mode is done in GPIO Interrupt Handler.
while(1)
UARTCharPut(UART2_BASE, 0);
//UARTprintf("1");
无法在PD7上检测到数据信号, 用示波器看。
我把ur2改成ur0 对应的io也修改 ,就能在示波器上观察到数据信号。然胡我又改成ur7还是不行。 这是什么问题? 是不是那个地方没有修改? 望高手指点!
