各位求解啊:
我的工作环境:win7+CCSv5.1,现在运行OMAPL138的ARM端代码,代码就是网上发布的quickStartOMAPL1x_rCSL-2.0里的ARM2DSP_integration_armL138代码,
1.用这个命令时:
"${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/ARMofd" "${CG_TOOL_ROOT}/bin/ARMhex" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin"
我的CCS5.1路径下没有ARMofd和ARMhex工具,bin文件生成不了;
2.用这个命令时:
"${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin.bat" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/ofd470.exe" "${CG_TOOL_ROOT}/bin/hex470.exe" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin.exe"
生成的bin文件有2G大小,这是什么原因啊?
我在加载quickStartOMAPL1x_rCSL的工程后,工程的配置自动为tms470编译器,这是正常的吗?
十分困惑,请指教,
