在做bootloader项目中,在void _c_int00(void)函数中调用_copyAPI2RAM_(),一直卡在这里无法到达main函数。在通过屏蔽代码测试,发现只要调用void sciInit(void)就一直出现上述问题,关掉就不会出现。
sys_link.cmd
/* Memory Map */
MEMORY
VECTORS (X) : origin=0x00000000 length=0x00000020
FLASH_API (RX) : origin=0x00000020 length=0x000014E0
FLASH0 (RX) : origin=0x00001500 length=0x00180000-0x00001500
// FLASH1 (RX) : origin=0x00180000 length=0x00180000
STACKS (RW) : origin=0x08000000 length=0x00001500
RAM (RW) : origin=0x08001500 length=0x0003EB00
/* USER CODE BEGIN (2) */
/* USER CODE END */
/* USER CODE BEGIN (3) */
/* USER CODE END */
/* Section Configuration */
SECTIONS
.intvecs : {} > VECTORS
flashAPI :
..\Debug\F021\source\Fapi_UserDefinedFunctions.obj (.text)
..\Debug\F021\source\bl_flash.obj (.text)
--library=..\F021\F021_API_CortexR4_BE.lib < FlashStateMachine.IssueFsmCommand.obj
FlashStateMachine.SetActiveBank.obj
FlashStateMachine.InitializeFlashBanks.obj
FlashStateMachine.EnableMainSectors.obj
FlashStateMachine.ScaleFclk.obj
Init.obj
Utilities.CalculateEcc.obj
Utilities.WaitDelay.obj
Utilities.CalculateFletcher.obj
Read.MarginByByte.obj
Read.Common.obj
Read.FlushPipeline.obj
Read.WdService.obj
Async.WithAddress.obj
Program.obj > (.text)
} load = FLASH_API, run = RAM, LOAD_START(api_load), RUN_START(api_run), SIZE(api_size)
.text : {} > FLASH0
.const : {} > FLASH0
.cinit : {} > FLASH0
.pinit : {} > FLASH0
// .text : {} > FLASH0 | FLASH1
// .const : {} > FLASH0 | FLASH1
// .cinit : {} > FLASH0 | FLASH1
// .pinit : {} > FLASH0 | FLASH1
.bss : {} > RAM
.data : {} > RAM
.sysmem : {} > RAM
/* USER CODE BEGIN (4) */
/* USER CODE END */
sys_core.asm
; Copy the Flash API from flash to SRAM.
.def _copyAPI2RAM_
.asmfunc
_copyAPI2RAM_
.ref api_load
flash_load .word api_load
.ref api_run
flash_run .word api_run
.ref api_size
flash_size .word api_size
ldr r0, flash_load
ldr r1, flash_run
ldr r2, flash_size
add r2, r1, r2
copy_loop1:
ldr r3, [r0], #4
str r3, [r1], #4
cmp r1, r2
blt copy_loop1
bx lr
.endasmfunc
sys_startup.c
/* SourceId : STARTUP_SourceId_001 */
/* DesignId : STARTUP_DesignId_001 */
/* Requirements : HL_SR508 */
void _c_int00(void)
/* USER CODE BEGIN (5) */
/* USER CODE END */
/* Initialize Core Registers to avoid CCM Error */
_coreInitRegisters_();
/* USER CODE BEGIN (6) */
/* USER CODE END */
/* Initialize Stack Pointers */
_coreInitStackPointer_();
/* USER CODE BEGIN (7) */
/* USER CODE END */
/* Work Around for Errata DEVICE#140: ( Only on Rev A silicon)
* Errata Description:
* The Core Compare Module(CCM-R4) may cause nERROR to be asserted after a cold power-on
* Workaround:
* Clear ESM Group2 Channel 2 error in ESMSR2 and Compare error in CCMSR register */
if (DEVICE_ID_REV == 0x802AAD05U)
_esmCcmErrorsClear_();
/* USER CODE BEGIN (8) */
/* USER CODE END */
/* Enable CPU Event Export */
/* This allows the CPU to signal any single-bit or double-bit errors detected
* by its ECC logic for accesses to program flash or data RAM.
_coreEnableEventBusExport_();
/* USER CODE BEGIN (9) */
/* USER CODE END */
/* Enable response to ECC errors indicated by CPU for accesses to flash */
flashWREG->FEDACCTRL1 = 0x000A060AU;
/* USER CODE BEGIN (10) */
/* USER CODE END */
/* Enable CPU ECC checking for ATCM (flash accesses) */
_coreEnableFlashEcc_();
/* USER CODE BEGIN (11) */
/* USER CODE END */
/* Workaround for Errata CORTEXR4 66 */
_errata_CORTEXR4_66_();
/* Workaround for Errata CORTEXR4 57 */
_errata_CORTEXR4_57_();
/* Reset handler: the following instructions read from the system exception status register
* to identify the cause of the CPU reset.
/* check for power-on reset condition */
/*SAFETYMCUSW 139 S MR:13.7 <APPROVED> "Hardware status bit read check" */
if ((SYS_EXCEPTION & POWERON_RESET) != 0U)
/* USER CODE BEGIN (12) */
/* USER CODE END */
/* clear all reset status flags */
SYS_EXCEPTION = 0xFFFFU;
/* USER CODE BEGIN (13) */
/* USER CODE END */
/* USER CODE BEGIN (14) */
/* USER CODE END */
/* USER CODE BEGIN (15) */
/* USER CODE END */
/* continue with normal start-up sequence */
else if ((SYS_EXCEPTION & OSC_FAILURE_RESET) != 0U)
/* Reset caused due to oscillator failure.
Add user code here to handle oscillator failure */
/* USER CODE BEGIN (16) */
/* USER CODE END */
else if ((SYS_EXCEPTION & WATCHDOG_RESET) !=0U)
/* Reset caused due
* 1) windowed watchdog violation - Add user code here to handle watchdog violation.
* 2) ICEPICK Reset - After loading code via CCS / System Reset through CCS
/* Check the WatchDog Status register */
if(WATCHDOG_STATUS != 0U)
/* Add user code here to handle watchdog violation. */
/* USER CODE BEGIN (17) */
/* USER CODE END */
/* Clear the Watchdog reset flag in Exception Status register */
SYS_EXCEPTION = WATCHDOG_RESET;
/* USER CODE BEGIN (18) */
/* USER CODE END */
else
/* Clear the ICEPICK reset flag in Exception Status register */
SYS_EXCEPTION = ICEPICK_RESET;
/* USER CODE BEGIN (19) */
/* USER CODE END */
else if ((SYS_EXCEPTION & CPU_RESET) !=0U)
/* Reset caused due to CPU reset.
CPU reset can be caused by CPU self-test completion, or
by toggling the "CPU RESET" bit of the CPU Reset Control Register. */
/* USER CODE BEGIN (20) */
/* USER CODE END */
SYS_EXCEPTION = CPU_RESET;
/* USER CODE BEGIN (21) */
/* USER CODE END */
else if ((SYS_EXCEPTION & SW_RESET) != 0U)
/* Reset caused due to software reset.
Add user code to handle software reset. */
/* USER CODE BEGIN (22) */
/* USER CODE END */
else
/* Reset caused by nRST being driven low externally.
Add user code to handle external reset. */
/* USER CODE BEGIN (23) */
/* USER CODE END */
/* Check if there were ESM group3 errors during power-up.
* These could occur during eFuse auto-load or during reads from flash OTP
* during power-up. Device operation is not reliable and not recommended
* in this case.
* An ESM group3 error only drives the nERROR pin low. An external circuit
* that monitors the nERROR pin must take the appropriate action to ensure that
* the system is placed in a safe state, as determined by the application.
if ((esmREG->SR1[2]) != 0U)
/* USER CODE BEGIN (24) */
/* USER CODE END */
/*SAFETYMCUSW 5 C MR:NA <APPROVED> "for(;;) can be removed by adding "# if 0" and "# endif" in the user codes above and below" */
/*SAFETYMCUSW 26 S MR:NA <APPROVED> "for(;;) can be removed by adding "# if 0" and "# endif" in the user codes above and below" */
/*SAFETYMCUSW 28 D MR:NA <APPROVED> "for(;;) can be removed by adding "# if 0" and "# endif" in the user codes above and below" */
// for(;;)
// }/* Wait */
/* USER CODE BEGIN (25) */
/* USER CODE END */
/* USER CODE BEGIN (26) */
/* USER CODE END */
/* Initialize System - Clock, Flash settings with Efuse self check */
systemInit();
/* Workaround for Errata PBIST#4 */
errata_PBIST_4();
/* Run a diagnostic check on the memory self-test controller.
* This function chooses a RAM test algorithm and runs it on an on-chip ROM.
* The memory self-test is expected to fail. The function ensures that the PBIST controller
* is capable of detecting and indicating a memory self-test failure.
pbistSelfCheck();
/* Run PBIST on STC ROM */
pbistRun((uint32)STC_ROM_PBIST_RAM_GROUP,
((uint32)PBIST_TripleReadSlow | (uint32)PBIST_TripleReadFast));
/* Wait for PBIST for STC ROM to be completed */
/*SAFETYMCUSW 28 D MR:NA <APPROVED> "Hardware status bit read check" */
while(pbistIsTestCompleted() != TRUE)
}/* Wait */
/* Check if PBIST on STC ROM passed the self-test */
if( pbistIsTestPassed() != TRUE)
/* PBIST and STC ROM failed the self-test.
* Need custom handler to check the memory failure
* and to take the appropriate next step.
pbistFail();
/* Disable PBIST clocks and disable memory self-test mode */
pbistStop();
/* Run PBIST on PBIST ROM */
pbistRun((uint32)PBIST_ROM_PBIST_RAM_GROUP,
/* Wait for PBIST for PBIST ROM to be completed */
}/* Wait */
/* Check if PBIST ROM passed the self-test */
pbistFail();
pbistStop();
/* USER CODE BEGIN (29) */
/* USER CODE END */
/* USER CODE BEGIN (31) */
/* USER CODE END */
/* Disable RAM ECC before doing PBIST for Main RAM */
_coreDisableRamEcc_();
/* Run PBIST on CPU RAM.
* The PBIST controller needs to be configured separately for single-port and dual-port SRAMs.
* The CPU RAM is a single-port memory. The actual "RAM Group" for all on-chip SRAMs is defined in the
* device datasheet.
pbistRun(0x08300020U, /* ESRAM Single Port PBIST */
(uint32)PBIST_March13N_SP);
/* USER CODE BEGIN (32) */
/* USER CODE END */
/* Wait for PBIST for CPU RAM to be completed */
}/* Wait */
/* USER CODE BEGIN (33) */
/* USER CODE END */
/* Check if CPU RAM passed the self-test */
/* CPU RAM failed the self-test.
/* USER CODE BEGIN (34) */
/* USER CODE END */
pbistFail();
/* USER CODE BEGIN (35) */
/* USER CODE END */
/* USER CODE BEGIN (36) */
/* USER CODE END */
pbistStop();
/* USER CODE BEGIN (37) */
/* USER CODE END */
/* Initialize CPU RAM.
* This function uses the system module's hardware for auto-initialization of memories and their
* associated protection schemes. The CPU RAM is initialized by setting bit 0 of the MSIENA register.
* Hence the value 0x1 passed to the function.
* This function will initialize the entire CPU RAM and the corresponding ECC locations.
memoryInit(0x1U);
/* USER CODE BEGIN (38) */
/* USER CODE END */
/* Enable ECC checking for TCRAM accesses.
* This function enables the CPU's ECC logic for accesses to B0TCM and B1TCM.
_coreEnableRamEcc_();
/* USER CODE BEGIN (39) */
/* USER CODE END */
/* Start PBIST on all dual-port memories */
/* NOTE : Please Refer DEVICE DATASHEET for the list of Supported Dual port Memories.
PBIST test performed only on the user selected memories in HALCoGen's GUI SAFETY INIT tab.
pbistRun( (uint32)0x00000000U /* EMAC RAM */
| (uint32)0x00000000U /* USB RAM */
| (uint32)0x00000800U /* DMA RAM */
| (uint32)0x00000200U /* VIM RAM */
| (uint32)0x00000040U /* MIBSPI1 RAM */
| (uint32)0x00000080U /* MIBSPI3 RAM */
| (uint32)0x00000100U /* MIBSPI5 RAM */
| (uint32)0x00000004U /* CAN1 RAM */
| (uint32)0x00000008U /* CAN2 RAM */
| (uint32)0x00000010U /* CAN3 RAM */
| (uint32)0x00000400U /* ADC1 RAM */
| (uint32)0x00020000U /* ADC2 RAM */
| (uint32)0x00001000U /* HET1 RAM */
| (uint32)0x00040000U /* HET2 RAM */
| (uint32)0x00002000U /* HTU1 RAM */
| (uint32)0x00080000U /* HTU2 RAM */
| (uint32)0x00004000U /* RTP RAM */
| (uint32)0x00008000U /* FRAY RAM */
,(uint32) PBIST_March13N_DP);
/* USER CODE BEGIN (40) */
/* USER CODE END */
/* Test the CPU ECC mechanism for RAM accesses.
* The checkBxRAMECC functions cause deliberate single-bit and double-bit errors in TCRAM accesses
* by corrupting 1 or 2 bits in the ECC. Reading from the TCRAM location with a 2-bit error
* in the ECC causes a data abort exception. The data abort handler is written to look for
* deliberately caused exception and to return the code execution to the instruction
* following the one that caused the abort.
checkRAMECC();
/* USER CODE BEGIN (41) */
/* USER CODE END */
/* USER CODE BEGIN (43) */
/* USER CODE END */
}/* Wait */
/* USER CODE BEGIN (44) */
/* USER CODE END */
/* USER CODE BEGIN (45) */
/* USER CODE END */
/* USER CODE BEGIN (46) */
/* USER CODE END */
pbistFail();
/* USER CODE BEGIN (47) */
/* USER CODE END */
/* USER CODE BEGIN (48) */
/* USER CODE END */
pbistStop();
/* USER CODE BEGIN (55) */
/* USER CODE END */
/* Release the MibSPI1 modules from local reset.
* This will cause the MibSPI1 RAMs to get initialized along with the parity memory.
mibspiREG1->GCR0 = 0x1U;
/* Release the MibSPI3 modules from local reset.
* This will cause the MibSPI3 RAMs to get initialized along with the parity memory.
mibspiREG3->GCR0 = 0x1U;
/* Release the MibSPI5 modules from local reset.
* This will cause the MibSPI5 RAMs to get initialized along with the parity memory.
mibspiREG5->GCR0 = 0x1U;
/* USER CODE BEGIN (56) */
/* USER CODE END */
/* Enable parity on selected RAMs */
enableParity();
/* Initialize all on-chip SRAMs except for MibSPIx RAMs
* The MibSPIx modules have their own auto-initialization mechanism which is triggered
* as soon as the modules are brought out of local reset.
/* The system module auto-init will hang on the MibSPI RAM if the module is still in local reset.
/* NOTE : Please Refer DEVICE DATASHEET for the list of Supported Memories and their channel numbers.
Memory Initialization is perfomed only on the user selected memories in HALCoGen's GUI SAFETY INIT tab.
memoryInit( (uint32)((uint32)1U << 1U) /* DMA RAM */
| (uint32)((uint32)1U << 2U) /* VIM RAM */
| (uint32)((uint32)1U << 5U) /* CAN1 RAM */
| (uint32)((uint32)1U << 6U) /* CAN2 RAM */
| (uint32)((uint32)1U << 10U) /* CAN3 RAM */
| (uint32)((uint32)1U << 8U) /* ADC1 RAM */
| (uint32)((uint32)1U << 14U) /* ADC2 RAM */
| (uint32)((uint32)1U << 3U) /* HET1 RAM */
| (uint32)((uint32)1U << 4U) /* HTU1 RAM */
| (uint32)((uint32)1U << 15U) /* HET2 RAM */
| (uint32)((uint32)1U << 16U) /* HTU2 RAM */
/* Disable parity */
disableParity();
/* Test the parity protection mechanism for peripheral RAMs
NOTE : Please Refer DEVICE DATASHEET for the list of Supported Memories with parity.
Parity Self check is perfomed only on the user selected memories in HALCoGen's GUI SAFETY INIT tab.
/* USER CODE BEGIN (57) */
/* USER CODE END */
het1ParityCheck();
/* USER CODE BEGIN (58) */
/* USER CODE END */
htu1ParityCheck();
/* USER CODE BEGIN (59) */
/* USER CODE END */
het2ParityCheck();
/* USER CODE BEGIN (60) */
/* USER CODE END */
htu2ParityCheck();
/* USER CODE BEGIN (61) */
/* USER CODE END */
adc1ParityCheck();
/* USER CODE BEGIN (62) */
/* USER CODE END */
adc2ParityCheck();
/* USER CODE BEGIN (63) */
/* USER CODE END */
can1ParityCheck();
/* USER CODE BEGIN (64) */
/* USER CODE END */
can2ParityCheck();
/* USER CODE BEGIN (65) */
/* USER CODE END */
can3ParityCheck();
/* USER CODE BEGIN (66) */
/* USER CODE END */
vimParityCheck();
/* USER CODE BEGIN (67) */
/* USER CODE END */
dmaParityCheck();
/* USER CODE BEGIN (68) */
/* USER CODE END */
while ((mibspiREG1->FLG & 0x01000000U) == 0x01000000U)
}/* Wait */
/* wait for MibSPI1 RAM to complete initialization */
while ((mibspiREG3->FLG & 0x01000000U) == 0x01000000U)
}/* Wait */
/* wait for MibSPI3 RAM to complete initialization */
while ((mibspiREG5->FLG & 0x01000000U) == 0x01000000U)
}/* Wait */
/* wait for MibSPI5 RAM to complete initialization */
/* USER CODE BEGIN (69) */
/* USER CODE END */
mibspi1ParityCheck();
/* USER CODE BEGIN (70) */
/* USER CODE END */
mibspi3ParityCheck();
/* USER CODE BEGIN (71) */
/* USER CODE END */
mibspi5ParityCheck();
/* USER CODE BEGIN (72) */
/* USER CODE END */
/* Enable IRQ offset via Vic controller */
_coreEnableIrqVicOffset_();
/* USER CODE BEGIN (73) */
/* USER CODE END */
/* Initialize VIM table */
vimInit();
/* USER CODE BEGIN (74) */
/* USER CODE END */
/* Configure system response to error conditions signaled to the ESM group1 */
/* This function can be configured from the ESM tab of HALCoGen */
esmInit();
/* initialize copy table */
__TI_auto_init();
/* USER CODE BEGIN (75) */
_copyAPI2RAM_();
/* USER CODE END */
/* call the application */
/*SAFETYMCUSW 296 S MR:8.6 <APPROVED> "Startup code(library functions at block scope)" */
/*SAFETYMCUSW 326 S MR:8.2 <APPROVED> "Startup code(Declaration for main in library)" */
/*SAFETYMCUSW 60 D MR:8.8 <APPROVED> "Startup code(Declaration for main in library;Only doing an extern for the same)" */
main();
/* USER CODE BEGIN (76) */
/* USER CODE END */
/*SAFETYMCUSW 122 S MR:20.11 <APPROVED> "Startup code(exit and abort need to be present)" */
exit(0);
/* USER CODE BEGIN (77) */
/* USER CODE END */
/* USER CODE BEGIN (78) */
/* USER CODE END */
