开发环境用的CCS6.1,复制了TI给的fpu的例程,里边用到了一个P1.1口按键的中断,在例程里直接运行时没有问题的,但是复制到我自己建的工程里,只要一按触发中断的按键程序就自动跳到一个死循环里,求助。。。。
/* This is the code that gets called when the processor receives an unexpected */
/* interrupt. This simply enters an infinite loop, preserving the system state */
/* for examination by a debugger. */
static void defaultISR(void)
/* Fault trap exempt from ULP advisor */
#pragma diag_push
#pragma CHECK_ULP("-2.1")
/* Enter an infinite loop. */
while(1)
#pragma diag_pop
