AM2732: AM2732 CSI2
Part Number: AM2732
Hello,
I would like to ask whether the FIFO depth of the AM732x CSI2-RX module can be configured by the user.
I am using dual cascade CSI2, the clock is 320Mbps, the data rate is 640M, the FIFO will overflow. Reduce the rate or change to a single board, the FIFO will be normal。
CSI2_GNQ Register only indicates the fifo depth, no register for configuring the fifo depth is found。
