Part Number: MSPM0G3507
Hello,
The data has been stored in the designated address of FLASH, but which function should be used to read it? The case provided by your company is to judge after reading. I just want to directly read the data stored in that address, regardless of whether it is correct or incorrect, and which function should be used for operation.
Or which method should I use to read and write data from internal flash memory.
thank you
