tm4c123gxl 延时
tm4c123gxl 延时us、ms的函数谁有,麻烦发一下
  • void delay_Nms(uint n)
        uint i = 0;
        for(i = n;i > 0;i--)
                SysCtlDelay(SysCtlClockGet() / 3000);
  • 需要根据系统的主频率来计算值得,不能死搬硬套。
  • 有的例程用 SysCtlDelay(SysCtlClockGet()/3000); 来延时1ms,是因为他们使用30k的内部振荡器作为系统时钟。
  • 你好,
    我把代码附上,希望对你有帮助 : )
    // project.c - Simple project to use as a starting point for more complex
    // projects.
    // Copyright (c) 2013-2014 Texas Instruments Incorporated. All rights reserved.
    // Software License Agreement
    // Redistribution and use in source and binary forms, with or without
    // modification, are permitted provided that the following conditions
    // are met:
    // Redistributions of source code must retain the above copyright
    // notice, this list of conditions and the following disclaimer.
    // Redistributions in binary form must reproduce the above copyright
    // notice, this list of conditions and the following disclaimer in the
    // documentation and/or other materials provided with the
    // distribution.
    // Neither the name of Texas Instruments Incorporated nor the names of
    // its contributors may be used to endorse or promote products derived
    // from this software without specific prior written permission.
    // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // This is part of revision 2.1.0.12573 of the Tiva Firmware Development Package.
    #include <stdbool.h>
    #include <stdint.h>
    #include "inc/hw_memmap.h"
    #include "driverlib/debug.h"
    #include "driverlib/gpio.h"
    #include "driverlib/rom.h"
    #include "driverlib/sysctl.h"
    //! \addtogroup example_list
    //! <h1>Simple Project (project)</h1>
    //! A very simple example that can be used as a starting point for more complex
    //! projects. Most notably, this project is fully TI BSD licensed, so any and
    //! all of the code (including the startup code) can be used as allowed by that
    //! license.
    //! The provided code simply toggles a GPIO using the Tiva Peripheral Driver
    //! Library.
    // The error routine that is called if the driver library encounters an error.
    #ifdef DEBUG
    void
    __error__(char *pcFilename, uint32_t ui32Line)
    #endif
    // Toggle a GPIO.
    int
    main(void)
    // Enable the GPIO module.
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
    ROM_SysCtlDelay(1);
    // Configure PA1 as an output.
    ROM_GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_1);
    // Loop forever.
    while(1)
    // Set the GPIO high.
    ROM_GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_1, GPIO_PIN_1);
    // Delay for a while.
    ROM_SysCtlDelay(1000000);
    // Set the GPIO low.
    ROM_GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_1, 0);
