ULC1001-DRV290XEVM: The mechanical design of the LCS-FL-RNG15
Part Number: ULC1001-DRV290XEVM
Hello,
1、 Could you please let me know when the LCS-FL-RNG15 will be back in stock?
      It has been listed as out of stock on the website for several months.
2、For the transducer used in the LCS-FL-RNG15, are the positive and negative terminals located on the top and bottom surfaces, on the two ends of the outer wall, or on the inner and outer walls?
     Are the wires soldered directly to the two terminals of the transducer?
Best regards,
Joy
