MCF8316D: Need proper Settings to configure the MCF8316D to run on Loan Condition.
Part Number: MCF8316D
We are using MCF8316D Driver to Drive the BLDC Motor mosrac u2515.
Initially its configured to run with PWM, We apply constant 50 percent PWM.
Motor Starts with low speed and runs for 20 to 30 seconds. After that it will run on the PWM frequency.
But when load is applied to BLDC in between those 20 to 30 seconds, Motor stops and never starts again.
I have written a I2C drivers and tried setting resistance, Inductance values to Driver register maps. Still no positive response.
I have uplaoded the motor datasheet also.
Please suggest a steps to configure the driver to run the BLDC (Datasheet is attached).
.mosrac-u2515-motor-catalog.pdf
