MCF8316AEVM: MCF8316AEVM: the motor suddenly stops automatically in a closed loop
Part Number: MCF8316AEVM
I got an evaluation  board, and after a few days of learning and testing, the motor was able to turn, and there were many problems with it.
The current problem is that the closed-loop control motor automatically stops without any fault alarm. Then the motor state turns to idle, and it can be restarted only after the power is turned off and then turned on again.
 GUI version is V1.1.5.
Configuration file:
"signature": "oneui-register-data",
"data": [
"idx": 0,
"id": "isd_config",
"value": "0x44238C20"
"idx": 1,
"id": "rev_drive_config",
"value": "0x283AF064"
"idx": 2,
"id": "motor_startup1",
"value": "0x6B6807D0"
"idx": 3,
"id": "motor_startup2",
"value": "0x1A846000"
"idx": 4,
"id": "closed_loop1",
"value": "0x145301B0"
"idx": 5,
"id": "closed_loop2",
"value": "0x5AEE8159"
"idx": 6,
"id": "closed_loop3",
"value": "0x2382800E"
"idx": 7,
"id": "closed_loop4",
"value": "0x05C112C0"
"idx": 8,
"id": "speed_profiles1",
"value": "0x00000000"
"idx": 9,
"id": "speed_profiles2",
"idx": 10,
"id": "speed_profiles3",
"idx": 11,
"id": "speed_profiles4",
"idx": 12,
"id": "speed_profiles5",
"idx": 13,
"id": "speed_profiles6",
"idx": 0,
"id": "fault_config1",
"value": "0x5FE82A06"
"idx": 1,
"id": "fault_config2",
"value": "0x74006000"
"idx": 0,
"id": "pin_config",
"value": "0x00000002"
"idx": 1,
"id": "device_config1",
"value": "0x00100000"
"idx": 2,
"id": "device_config2",
"value": "0x0000B000"
"idx": 3,
"id": "peri_config1",
"value": "0x40000000"
"idx": 4,
"id": "gd_config1",
"value": "0x00000500"
"idx": 5,
"id": "gd_config2",
"value": "0x00200000"
"idx": 0,
"id": "ana_trim3",
"value": "0x48004800"
"idx": 1,
"id": "ana_trim4",
"idx": 2,
"id": "ana_trim5",
"value": "0x800003F7"
"idx": 3,
"id": "ana_trim6",
"idx": 4,
"id": "ana_trim7",
"idx": 5,
"id": "ana_trim8",
"value": "0x000056A5"
"idx": 6,
"id": "ana_trim9",
"value": "0x80B9D7A3"
"idx": 7,
"id": "ana_trim10",
"value": "0xD3680036"
"idx": 0,
"id": "int_algo_1",
"value": "0x00B3407D"
"idx": 1,
"id": "int_algo_2",
"value": "0x000002A1"
"idx": 0,
"id": "gate_driver_fault_status",
"idx": 1,
"id": "controller_fault_status",
"idx": 0,
"id": "algo_status",
"value": "0x7FFF0000"
"idx": 1,
"id": "mtr_params",
"value": "0x00370000"
"idx": 2,
"id": "algo_status_mpet",
"value": "0x24000000"
"idx": 0,
"id": "dev_ctrl",
"idx": 0,
"id": "algo_ctrl1",
"value": "0x80000000"
"idx": 1,
"id": "algo_ctrl2",
"idx": 2,
"id": "current_pi",
"value": "0x000991C8"
"idx": 3,
"id": "speed_pi",
"idx": 4,
"id": "dac_1",
"idx": 5,
"id": "dac_2",
"idx": 0,
"id": "algorithm_state",
"idx": 1,
"id": "fg_speed_fdbk",
"value": "0x084E6C20"
"idx": 2,
"id": "bus_current",
"value": "0xFDBF8B77"
"idx": 3,
"id": "phase_current_a",
"value": "0xFFF00000"
"idx": 4,
"id": "phase_current_b",
"idx": 5,
"id": "phase_current_c",
"idx": 6,
"id": "csa_gain_feedback",
"value": "0x00010003"
"idx": 7,
"id": "voltage_gain_feedback",
"value": "0x00000001"
"idx": 8,
"id": "vm_voltage",
"value": "0x03488000"
"idx": 9,
"id": "phase_voltage_va",
"value": "0x00006ED9"
"idx": 10,
"id": "phase_voltage_vb",
"value": "0x0000DDB3"
"idx": 11,
"id": "phase_voltage_vc",
"idx": 12,
"id": "sin_commutation_angle",
"value": "0xF9976138"
"idx": 13,
"id": "cos_commutation_angle",
"value": "0xFB382764"
"idx": 14,
"id": "ialpha",
"value": "0x2C680000"
"idx": 15,
"id": "ibeta",
"value": "0xEAC3AB82"
"idx": 16,
"id": "valpha",
"value": "0xFCD39083"
"idx": 17,
"id": "vbeta",
"value": "0xFF2FF0ED"
"idx": 18,
"id": "id",
"value": "0xF63C1379"
"idx": 19,
"id": "iq",
"value": "0x3034A7F5"
"idx": 20,
"id": "vd",
"value": "0x028CED48"
"idx": 21,
"id": "vq",
"value": "0xFDF0E413"
"idx": 22,
"id": "iq_ref_rotor_align",
"idx": 23,
"id": "speed_ref_open_loop",
"idx": 24,
"id": "iq_ref_open_loop",
"value": "0x09997560"
"idx": 25,
"id": "speed_ref_closed_loop",
"idx": 26,
"id": "id_ref_closed_loop",
"idx": 27,
"id": "iq_ref_closed_loop",
"value": "0x044F4706"
"idx": 28,
"id": "isd_state",
"value": "0x00000005"
"idx": 29,
"id": "isd_speed",
"value": "0x000001BB"
"idx": 30,
"id": "ipd_state",
"idx": 31,
"id": "ipd_angle",
"idx": 32,
"id": "ed",
"idx": 33,
"id": "eq",
"idx": 34,
"id": "speed_fdbk",
"idx": 35,
"id": "theta_est",
Thanks
