DRV8306的三个霍尔传感器如何连接? 我选择了一个三针霍尔传感器,应该如何连接? 还是三针霍尔传感器不可接受? 使用带四个引脚的霍尔传感器? 如果是这样,四针霍尔传感器的推荐型号是什么? 如何连接,请回答,很着急,谢谢!
How to connect the three Hall sensors of DRV8306? I chose a three-pin hall sensor, how should I connect it? Or is the three-pin Hall sensor not acceptable? To use a hall sensor with four pins? If so what is the recommended model for a four pin hall sensor? How to connect, please answer, very anxious, thank you!
