可以固定电机转速转动吗,目前我发现一旦加了负载之后速度就突然变大了(有的时候速度变大,电流也变高,还会报ABnormal BEMF错误),这是我的一份参数json,麻烦能提供点意见,非常感谢
"signature": "oneui-register-data",
"data": [
"idx": 0,
"id": "isd_config",
"value": "0x40000000"
"idx": 1,
"id": "rev_drive_config",
"value": "0x2835917F"
"idx": 2,
"id": "motor_startup1",
"value": "0x0B6A07D0"
"idx": 3,
"id": "motor_startup2",
"value": "0x2B066A90"
"idx": 4,
"id": "closed_loop1",
"value": "0x0C318134"
"idx": 5,
"id": "closed_loop2",
"value": "0x1AADA57D"
"idx": 6,
"id": "closed_loop3",
"value": "0x1C800003"
"idx": 7,
"id": "closed_loop4",
"value": "0x0EA3831E"
"idx": 8,
"id": "speed_profiles1",
"value": "0x00000000"
"idx": 9,
"id": "speed_profiles2",
"idx": 10,
"id": "speed_profiles3",
"idx": 11,
"id": "speed_profiles4",
"idx": 12,
"id": "speed_profiles5",
"idx": 13,
"id": "speed_profiles6",
"idx": 0,
"id": "fault_config1",
"value": "0x5FE80204"
"idx": 1,
"id": "fault_config2",
"value": "0x74000088"
"idx": 0,
"id": "pin_config",
"value": "0x00000002"
"idx": 1,
"id": "device_config1",
"value": "0x00100000"
"idx": 2,
"id": "device_config2",
"value": "0x0000B000"
"idx": 3,
"id": "peri_config1",
"idx": 4,
"id": "gd_config1",
"value": "0x00000100"
"idx": 5,
"id": "gd_config2",
"value": "0x00200000"
"idx": 0,
"id": "ana_trim3",
"value": "0x48004800"
"idx": 1,
"id": "ana_trim4",
"idx": 2,
"id": "ana_trim5",
"value": "0x8000002A"
"idx": 3,
"id": "ana_trim6",
"idx": 4,
"id": "ana_trim7",
"idx": 5,
"id": "ana_trim8",
"value": "0x00001433"
"idx": 6,
"id": "ana_trim9",
"value": "0x0049F7E1"
"idx": 7,
"id": "ana_trim10",
"value": "0x5374113C"
"idx": 0,
"id": "int_algo_1",
"value": "0x00B9407D"
"idx": 1,
"id": "int_algo_2",
"value": "0x000001A7"
"idx": 0,
"id": "gate_driver_fault_status",
"idx": 1,
"id": "controller_fault_status",
"idx": 0,
"id": "algo_status",
"idx": 1,
"id": "mtr_params",
"idx": 2,
"id": "algo_status_mpet",
"value": "0x06000000"
"idx": 0,
"id": "dev_ctrl",
"value": "0x20000000"
"idx": 0,
"id": "algo_ctrl1",
"value": "0x9E8D0000"
"idx": 1,
"id": "algo_ctrl2",
"idx": 2,
"id": "current_pi",
"value": "0x00053522"
"idx": 3,
"id": "speed_pi",
"idx": 4,
"id": "dac_1",
"idx": 5,
"id": "dac_2",
"idx": 0,
"id": "algorithm_state",
"idx": 1,
"id": "fg_speed_fdbk",
"value": "0x7FFFFFFF"
"idx": 2,
"id": "bus_current",
"idx": 3,
"id": "phase_current_a",
"idx": 4,
"id": "phase_current_b",
"idx": 5,
"id": "phase_current_c",
"idx": 6,
"id": "csa_gain_feedback",
"value": "0x00010003"
"idx": 7,
"id": "voltage_gain_feedback",
"idx": 8,
"id": "vm_voltage",
"value": "0x01A14000"
"idx": 9,
"id": "phase_voltage_va",
"idx": 10,
"id": "phase_voltage_vb",
"idx": 11,
"id": "phase_voltage_vc",
"idx": 12,
"id": "sin_commutation_angle",
"idx": 13,
"id": "cos_commutation_angle",
"idx": 14,
"id": "ialpha",
"idx": 15,
"id": "ibeta",
"idx": 16,
"id": "valpha",
"idx": 17,
"id": "vbeta",
"idx": 18,
"id": "id",
"idx": 19,
"id": "iq",
"idx": 20,
"id": "vd",
"idx": 21,
"id": "vq",
"idx": 22,
"id": "iq_ref_rotor_align",
"idx": 23,
"id": "speed_ref_open_loop",
"idx": 24,
"id": "iq_ref_open_loop",
"idx": 25,
"id": "speed_ref_closed_loop",
"idx": 26,
"id": "id_ref_closed_loop",
"idx": 27,
"id": "iq_ref_closed_loop",
"idx": 28,
"id": "isd_state",
"idx": 29,
"id": "isd_speed",
"idx": 30,
"id": "ipd_state",
"idx": 31,
"id": "ipd_angle",
"idx": 32,
"id": "ed",
"idx": 33,
"id": "eq",
"idx": 34,
"id": "speed_fdbk",
"idx": 35,
"id": "theta_est",
