msp-gang报错err23
一切按说明接好,编程器自检报3个错误,读写也出错,麻烦管理员给看看怎么情况
  • === MSP-GANG Self test results ( Wednesday, April 24, 2024, 00:25:10 ) ===
    Adapter SN ------: 11080286
    Hardware --------: G430: 01.01
    Access key ------: MSP-GANG Programmer
    Silicon Number --: 2216 9046 0700 2700
    API Firmware ----: MSP-Gang A430: 01.03.08.00
    BOOT Firmware ---: G430BOOT B430: 01.00.01.00
    GUI Software ----: MSP-Gang-GUI G430: 01.03.08.00
    DLL Software ----: MSP-Gang-DLL D430: 01.03.08.00
    ================ Test results =============
    No. name parameter limits result status
    1: Data Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
    2: Data Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK <<
    3: Data Bus (D-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK <<
    4: Data Bus (D-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK <<
    5: Data Bus (D-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK <<
    6: Data Bus (D-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK <<
    7: Data Bus (D-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK <<
    8: Data Bus (D-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK <<
    9: Data Bus (D-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK <<
    10: Data Bus (D-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK <<
    11: Data-2 Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
    12: Data-2 Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK <<
    13: Data-2 Bus (D2-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK <<
    14: Data-2 Bus (D2-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK <<
    15: Data-2 Bus (D2-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK <<
    16: Data-2 Bus (D2-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK <<
    17: Data-2 Bus (D2-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK <<
    18: Data-2 Bus (D2-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK <<
    19: Data-2 Bus (D2-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK <<
    20: Data-2 Bus (D2-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK <<
    21: Vcc Target-1 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.02 V ... >> OK <<
    22: Vcc Target-2 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
    23: Vcc Target-3 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
    24: Vcc Target-4 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
    25: Vcc Target-5 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
    26: Vcc Target-6 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
    27: Vcc Target-7 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
    28: Vcc Target-8 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
    29: Translators VT (OFF) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK <<
    30: Translators VT (ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.77 V ... >> OK <<
    31: Translators VT (ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.67 V ... >> OK <<
    32: Translators VT (ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.25 V ... >> ERROR <<
    33: Vpp Voltage-in 10.00 V ( 8.00 to 12.00) Result: 10.64 V ... >> OK <<
    34: Vpp Voltage 7.00 V ( 6.50 to 7.30) Result: 6.93 V ... >> OK <<
    35: Internal Vcc-3.3V 3.30 V ( 3.20 to 3.40) Result: 3.30 V ... >> OK <<
    36: Vcc Target-1 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.80 V ... >> OK <<
    37: Vcc Target-2 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.78 V ... >> OK <<
    38: Vcc Target-3 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.80 V ... >> OK <<
    39: Vcc Target-4 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.82 V ... >> OK <<
    40: Vcc Target-5 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.79 V ... >> OK <<
    41: Vcc Target-6 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.76 V ... >> OK <<
    42: Vcc Target-7 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.79 V ... >> OK <<
    43: Vcc Target-8 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.81 V ... >> OK <<
    44: Vcc Target-1 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.69 V ... >> OK <<
    45: Vcc Target-2 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.69 V ... >> OK <<
    46: Vcc Target-3 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.72 V ... >> OK <<
    47: Vcc Target-4 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.72 V ... >> OK <<
    48: Vcc Target-5 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.69 V ... >> OK <<
    49: Vcc Target-6 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.66 V ... >> OK <<
    50: Vcc Target-7 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.70 V ... >> OK <<
    51: Vcc Target-8 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.71 V ... >> OK <<
    52: Vcc Target-1 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.59 V ... >> OK <<
    53: Vcc Target-2 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.60 V ... >> OK <<
    54: Vcc Target-3 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.66 V ... >> OK <<
    55: Vcc Target-4 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.62 V ... >> OK <<
    56: Vcc Target-5 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.59 V ... >> OK <<
    57: Vcc Target-6 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.56 V ... >> OK <<
    58: Vcc Target-7 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.61 V ... >> OK <<
    59: Vcc Target-8 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.61 V ... >> OK <<
    60: Vcc discharge (100ms)Target-1 3.60 V ( 1.00 to 2.70) Result: 1.31 V ... >> OK <<
    61: Vcc discharge (100ms)Target-2 3.60 V ( 1.00 to 2.70) Result: 1.31 V ... >> OK <<
    62: Vcc discharge (100ms)Target-3 3.60 V ( 1.00 to 2.70) Result: 1.27 V ... >> OK <<
    63: Vcc discharge (100ms)Target-4 3.60 V ( 1.00 to 2.70) Result: 1.34 V ... >> OK <<
    64: Vcc discharge (100ms)Target-5 3.60 V ( 1.00 to 2.70) Result: 1.30 V ... >> OK <<
    65: Vcc discharge (100ms)Target-6 3.60 V ( 1.00 to 2.70) Result: 1.31 V ... >> OK <<
    66: Vcc discharge (100ms)Target-7 3.60 V ( 1.00 to 2.70) Result: 1.28 V ... >> OK <<
    67: Vcc discharge (100ms)Target-8 3.60 V ( 1.00 to 2.70) Result: 1.42 V ... >> OK <<
    68: Vcc Target-1 ( #1 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.29 V ... >> OK <<
    69: Vcc Target-2 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    70: Vcc Target-3 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    71: Vcc Target-4 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    72: Vcc Target-5 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    73: Vcc Target-6 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    74: Vcc Target-7 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    75: Vcc Target-8 ( #1 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    76: Vcc Target-1 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    77: Vcc Target-2 ( #2 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.29 V ... >> OK <<
    78: Vcc Target-3 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    79: Vcc Target-4 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    80: Vcc Target-5 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    81: Vcc Target-6 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    82: Vcc Target-7 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    83: Vcc Target-8 ( #2 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    84: Vcc Target-1 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    85: Vcc Target-2 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    86: Vcc Target-3 ( #3 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.34 V ... >> OK <<
    87: Vcc Target-4 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    88: Vcc Target-5 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    89: Vcc Target-6 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    90: Vcc Target-7 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    91: Vcc Target-8 ( #3 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    92: Vcc Target-1 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    93: Vcc Target-2 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    94: Vcc Target-3 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    95: Vcc Target-4 ( #4 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.32 V ... >> OK <<
    96: Vcc Target-5 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    97: Vcc Target-6 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    98: Vcc Target-7 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    99: Vcc Target-8 ( #4 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    100: Vcc Target-1 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    101: Vcc Target-2 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    102: Vcc Target-3 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    103: Vcc Target-4 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    104: Vcc Target-5 ( #5 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.29 V ... >> OK <<
    105: Vcc Target-6 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    106: Vcc Target-7 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    107: Vcc Target-8 ( #5 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    108: Vcc Target-1 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    109: Vcc Target-2 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    110: Vcc Target-3 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    111: Vcc Target-4 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    112: Vcc Target-5 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    113: Vcc Target-6 ( #6 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.26 V ... >> OK <<
    114: Vcc Target-7 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    115: Vcc Target-8 ( #6 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    116: Vcc Target-1 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    117: Vcc Target-2 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    118: Vcc Target-3 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    119: Vcc Target-4 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    120: Vcc Target-5 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    121: Vcc Target-6 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    122: Vcc Target-7 ( #7 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.31 V ... >> OK <<
    123: Vcc Target-8 ( #7 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    124: Vcc Target-1 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK <<
    125: Vcc Target-2 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    126: Vcc Target-3 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    127: Vcc Target-4 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    128: Vcc Target-5 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    129: Vcc Target-6 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    130: Vcc Target-7 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK <<
    131: Vcc Target-8 ( #8 ON ) 3.30 V ( 3.10 to 3.50) Result: 3.31 V ... >> OK <<
    132: SD Power OFF 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
    133: SD Power ON 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    134: SD Discharge - delay 2ms 0x0010 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    135: SD Discharge - delay 50ms 0x0010 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
    136: BSL RX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    137: BSL RX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
    138: BSL RX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
    139: BSL RX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
    140: BSL RX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
    141: BSL RX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
    142: BSL RX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
    143: BSL RX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
    144: BSL TX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    145: BSL TX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
    146: BSL TX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
    147: BSL TX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
    148: BSL TX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
    149: BSL TX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
    150: BSL TX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
    151: BSL TX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
    152: TDI bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    153: TDI bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
    154: TDI bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
    155: TDI bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
    156: TDI bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
    157: TDI bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
    158: TDI bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
    159: TDI bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
    160: TDOI Tx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    161: TDOI Tx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
    162: TDOI Tx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
    163: TDOI Tx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
    164: TDOI Tx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
    165: TDOI Tx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
    166: TDOI Tx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
    167: TDOI Tx-bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
    168: TDOI Tx-Rx (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    169: TDOI Tx-Rx (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
    170: TDOI Tx-Rx (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
    171: TDOI Tx-Rx (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
    172: TDOI Tx-Rx (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
    173: TDOI Tx-Rx (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
    174: TDOI Tx-Rx (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
    175: TDOI Tx-Rx (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
    176: TDOI Rx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    177: TDOI Rx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
    178: TDOI Rx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
    179: TDOI Rx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
    180: TDOI Rx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
    181: TDOI Rx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
    182: TDOI Rx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
    183: TDOI Rx-bus (#84 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
    184: TMS bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK <<
    185: TMS bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
    186: TMS bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    187: TMS bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
    188: TMS bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
    189: TMS bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
    190: TMS bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
    191: TMS bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
    192: TMS bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
    193: TMS bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
    194: RST bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK <<
    195: RST bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
    196: RST bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    197: RST bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
    198: RST bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
    199: RST bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
    200: RST bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
    201: RST bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
    202: RST bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
    203: RST bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
    204: Keys buffer (All pull-up) 0x001F (0x001F - 0x001F) Result: 0x1F ... >> OK <<
    205: Access to LCD RAM (0xAA) 0x00AA (0x00AA - 0x00AA) Result: 0x04 ... >> ERROR <<
    206: Access to LCD RAM (0x99) 0x0099 (0x0099 - 0x0099) Result: 0x04 ... >> ERROR <<
    207: Image Flash Access (get ID) 0x0002 (0x0001 - 0x0004) Result: 0x02 ... >> OK <<
    208: TDI Fuse keys (#1 ON) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
    209: TDI Fuse keys (#2 ON) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
    210: TDI Fuse keys (#3 ON) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
    211: TDI Fuse keys (#4 ON) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
    212: TDI Fuse keys (#5 ON) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
    213: TDI Fuse keys (#6 ON) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
    214: TDI Fuse keys (#7 ON) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
    215: TDI Fuse keys (#8 ON) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
    216: TEST Fuse keys (All OFF ) 0.00 ( 0.00 to 0.30) Result: 0.00 ... >> OK <<
    217: TEST Fuse keys (#1 ON) 1.10 ( 0.80 to 3.00) Result: 0.85 ... >> OK <<
    218: TEST Fuse keys (#2 ON) 1.10 ( 0.80 to 3.00) Result: 0.82 ... >> OK <<
    219: TEST Fuse keys (#3 ON) 1.10 ( 0.80 to 3.00) Result: 0.80 ... >> OK <<
    220: TEST Fuse keys (#4 ON) 1.10 ( 0.80 to 3.00) Result: 0.81 ... >> OK <<
    221: TEST Fuse keys (#5 ON) 1.10 ( 0.80 to 3.00) Result: 0.78 ... >> ERROR <<
    222: TEST Fuse keys (#6 ON) 1.10 ( 0.80 to 3.00) Result: 0.81 ... >> OK <<
    223: TEST Fuse keys (#7 ON) 1.10 ( 0.80 to 3.00) Result: 0.79 ... >> ERROR <<
    224: TEST Fuse keys (#8 ON) 1.10 ( 0.80 to 3.00) Result: 0.78 ... >> ERROR <<
    ============== Finished =================================
    * Test failed!! 6 error(s).
  • 感谢您对TI产品的关注!
    关于你的咨询, 下面的图片是error23的发生原因。
    你自行排除下。
    我看你的test result。
    看起来, translators VT电压低了。
    另外,你去我们英文论坛看看类似的报错是如何解决了。那里类似问题的帖子较多。
    msp-gang error 23 MCU device initialization failed
    e2e.ti.com/search
  • 感谢,我发现报电压问题,通过外接供电,已经可以读和擦除查空等操作,不过写入报370错误,也在英文论坛搜索过,没有这个报错代码,麻烦给看看
  • 对于新的error,你新建个帖子,我为你处理。
    我们一帖处理一个问题,这个帖子,我给您关闭了。
  • 报错370已经解决,是擦除内存设置问题,现在就是有个疑问,为什么目标板用编程器供电会报错,外置供电正常,是不是91670系列读写程序单纯45脚供电不能工作?
  • 有可能编程器供电带载不足,看你的负载。
