DRV8836: DRV8836DSSR timing
Part Number: DRV8836
Hi TI:
we follow the datasheet and go to check timing about AINx to AOUTx or BINx to BOUTx.
we found the timing seems different with datasheet.
is it correctly ??
could you help to check test result ?
have any impact on real application ??
DRV8836_test_result.xlsx
