Hello everyone,
I have a question to ask everyone
What would happen if the seventh pin SS is directly grounded or suspended?
Hello everyone,
您好
Soft-start pin. A capacitor connected on this pin to ground sets the start-up time. If this pin is left unconnected, the regulator output soft-start ramp time is typically 200 μs.
软启动引脚。 启动时间可通过在该引脚上连接到接地端的电容器来设置。 如该引脚所示 在未连接状态下、稳压器输出软启动斜坡时间通常为200 μs。
这个管脚接电容为了调整软起动时间的。
