I tested the TL431IPK at the company and found that the voltage is usually between 2.486 and 2.489. After the user received the product, there was an abnormality and it was returned. The measured TL431IPK reference voltages were 2.501V and 2.509V, respectively. After replacing the new IC, the voltage was normal. May I ask what is the reason for this? Are there any measures to avoid this situation?
