LM51770 breakdown
Other Parts Discussed in Thread: LM51770
The LM51770 will be damaged.
Both the input and output voltages are within a reasonable range, but VCC shorts with other pins.
I also designed it by referring to the design manual. The ISNSP and ISNSN pins on my side are grounded.
