Hello!
Regarding the VCELL_ACT_SUM_HI register on the BQ79758 chip:
- Do I need any special configuration to read this register, or can I directly read it after normal ADC configuration?
- Are any hardware modifications required?
- The final voltage value of the battery cells is multiplied by 0.0001. Is the same multiplier (0.0001) applicable to VCELL_ACT_SUM_HI?
Thank you!
