Hello, I would like to consult about the idea of logarithmic conversion, this is the table provided before, I have two questions, one is whether the table is comprehensive, because the data only reaches 36 of the input, the second question is that my input is an 8bit data, the table does not reflect the process and result of the conversion from 8bit to 12bit, which makes me a little confused, I hope to get an answer, thank you
