我想知道我按照流程通过对bq40z50r2在线GPC工具进行化学ID匹配后,为什么报告的结果总是变成其它的电池id比如bq27621,而且还是锂钴氧化物 ,我的电池是三元锂电池,为什么会推送结果是错误的?我放了我的充放电过程,麻烦各位大佬帮忙解读一下。谢谢。
您好
I believe one the main reason why the customer might not be seeing the CHEMid they want is because they are not programming the CHEMID into their after selecting it. Can they check in the Data Memory if their Ra Table is updating?
