BQ76952: DSG PIN voltage only 8V
Part Number: BQ76952
The charge and discharge FETs arranged in series, when the charge FET is turn off(the CHG PIN is off ),the DSG PIN voltage is only 8V(P+/P- no load);But when we add a load at P+/P- (Like a 1M resistor),the DSG PIN voltage rise up to 11V.We can not find the reason.
