Part Number: TPS22996H-Q1
Other Parts Discussed in Thread: TPS22996, TPS22997,
We need a load switch with Ron <= 5mohm and whose input voltage supports 0.75V. We are currently achieving this by connecting two TPS22996 in parallel (4 channel in parallel). We want to confirm whether the TPS22996 can be used in parallel. If not, are there any other recommended solution? Thank you!
