Part Number: TLC69614
此颗IC在每个输出通道关闭时,为了保证当前通道快速关闭,是否会对输出通道做一个反向充电,将电位拉高?反向充电电压值会达到多少?
When each output channel of this IC is turned off, in order to ensure that the current channel is quickly turned off, will it perform a reverse charging on the output channel and raise the potential? What is the reverse charging voltage value?
