Part Number: BQ4050
I am trying to retrieve the accumulated charge capacity data from the BQ4050 battery management IC. According to TI documentation, the Lifetime Data Block (addresses 0x60-0x64) does not explicitly provide this information. An AI assistant (DeepSeek) suggested that registers 0x68-0x6B might store this data. Could TI's BQ experts confirm: Whether registers 0x68-0x6B are valid for reading lifetime accumulated charge capacity? If not, what is the correct method to obtain this metric using the BQ4050? I have reviewed relevant application notes (including SLUUBD1C) but found no reference to these registers. Any guidance would be greatly appreciated.
