Part Number: TIDA-01606
Other Parts Discussed in Thread: OPA4350
hello:
I am currently running Experiment 5 with the following conditions: a 30 V three-phase input, no load, and the HV board is not connected. Whether I apply AC power or not, the waveform of TINV_vGrid_A_sensed_pu never changes—it stays completely noisy. Measuring the OPA4350 op-amp output pin shows a steady 1.65 V with almost no variation. What is the most likely cause of this behavior?
thanks
