TPS922055: 在模拟调制下,是否可以实现PWM的0占空比呢?
Part Number: TPS922055
Hi Team,
If it is possible to achieve a 0% duty cycle for PWM to turn off the output current when using analog modulation mode? (Only considering the use of analog modulation mode)
