Part Number: BQ76952
i want to use BMS BQ76952 to drive GaN (charge MOS and discharge MOS), and plans to use DDSG and DCHG pins 5V and driver chips to drive it;
1.Can the switch status of Mos be read through registers when DDSG and DCHG pins are configured in GPO state? If not possible, how can I configure it;
2. Will DDSG and DCHG pins automatically turn off under overcurrent or short-circuit protection, and how to configure it?
