BQ40Z50-R1: runtime degrade
Part Number: BQ40Z50-R1
runtime degrade
  • Hi,
    We have received your post and the investigation will take some time. Thank you for your patience.
  • Hi,
    Runtime Degrade is updated to data flash every Runtime Update Interval and tracks the runtime after CycleCount() ≥ Cycle Count Start Runtime.
    The degrade mode can be used to reduce the charging voltages and/or the charging currents based on measured parameters that reflect the aging of the cells. This is an optional feature.
