Part Number: TPS26750
Other Parts Discussed in Thread: BQ25756
If the TPS26750 chip is used to implement USB Type-C functionality, and a PD 3.1 EPR AVS-capable charger is used, is it possible to control the power path without using the BQ25756—relying solely on the TPS26750 for switching?
