Part Number: BQ20Z40
Hi,
The bq20Z95DBT has reached end of life (EOL). However, battery packs using the bq20Z95DBT have been in production for many years, and we need a replacement chip to maintain continuity.
Could you please recommend a suitable replacement for the bq20Z95DBT that meets the following requirements:
- Functionally compatible with the original bq20Z95DBT
- Communication protocol compatible (no protocol changes required)
- Supports 3S3P Li-ion battery packs
- Does not impact existing battery software for basic functions (capacity monitoring, voltage/current sensing, LED indication, etc.)
Thank you for your support.
Best regards,
Pan
