Part Number: BQ76952
If all Enabled Protections A/B/C are 0 but Enabled PF register and configured to enable permanent failures. Does the Enabled Protections A/B/C = 0 prohibit permanent failures to trigger so fx. a FUSE will never blow ?
Example ( will this enable FUSE blow when permanent faiilure occur ?):
| Permanent Failure | Enabled PF A | 5f | Hex |
| Permanent Failure | Enabled PF B | 1b | Hex |
| Permanent Failure | Enabled PF C | ff | Hex |
| Permanent Failure | Enabled PF D | 0 | Hex |
| Protection | Protection Configuration | 12 |
| Protection | Enabled Protections A | 0 |
| Protection | Enabled Protections B | 0 |
| Protection | Enabled Protections C | 0 |
